  2. FreeScout
  3. Connection could not be established with host mail.domain.com [Connection timed out #110]
Scheduled Pinned Locked Moved Solved FreeScout
43 Posts 6 Posters 13.0k Views 6 Watching
  • humptyH
    humptyH
    humpty
    #21
    The docs still say to use none if CR mail and FS are on the same server (which they are for my case). I updated it to TLS, but issue persists. I even restarted the app with no effect.
      @humptydumpty the docs are a bit outdated since FS has changed the Encryption options. I will fix that once we resolve this... I am out of ideas now though. Can you send us an email to support@cloudron.io with the domain? It must be something very obvious because our FS works.
      humptyH 1 Reply Last reply
        humptyH
        humptyH
        humpty
        @girish Sent.
        • humptyH
          humptyH
          humpty
          @girish I'm not sure if you got my email as I sent an email (proton email) to my CR email (roundcube) and I didn't receive it. I deleted the Hetzner firewall (as I've had it this whole time) and then sent a new email and then it was received in Roundcube.
            @humptydumpty thanks.
            Just as an update: we found that for some reason, the docker containers (any of them) are unable to reach any port other than port 443/80 using the public IP. From the server itself, all ports of public IP are reachable... Have to debug this further tomorrow.
            • Dave SwiftD
              Dave SwiftD
              Dave Swift
              Any update on this? I'm having the same issue.
              • humptyH
                humptyH
                humpty
                This is happening if the mailserver and freescout are on the same server. You can either move FS to another CR or change the mailbox settings (sending/fetching) to what's shown in the screenshots below until a perm fix is released and then you can revert to the previous settings.
                SENDING
                FETCHING
                  Right, the issue here was related to disabling the userland proxy in Docker. This breaks setups where containers in UDN are unable to connect to each other via public IP. Will investigate this coming week for a proper fix. Until then, simply use what @humptydumpty said
                    I pushed a fixed in the firewall for this. It's part of 8.2.3, you have to update Cloudron and hopefully that fixes this.
                    • bmannB
                      bmannB
                      bmann
                      I am on 8.2.3 on a Hostinger VPS and also having trouble fetching.
                      This is an old FS that I had stopped and just now turned on again. Previous settings worked (group shared mailbox) -- in that it fetched the IMAP folders and said the connection was working, and the email arrives in snappymail. Tried humptydumpty settings, also "worked", still not fetching.
                      Sending works fine from FS, from Snappy, etc.
                        #31
                        Can you try openssl s_client -connect <mailsever>:993 -crlf from web terminal of FS? Does it connect?
                        bmannB 1 Reply Last reply
                          bmannB
                          bmannB
                          bmann
                          @girish said in Connection could not be established with host mail.domain.com [Connection timed out #110]:
                          Since I'm using the localhost settings that HD said, I used this (note host name and alt port):
                          openssl s_client -connect mail:9393 -crlf
                          Got this response:
                          CONNECTED(00000003)
                          40A74365227F0000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../ssl/record/ssl3_record.c:354:
                          no peer certificate available
                          No client certificate CA names sent
                          SSL handshake has read 5 bytes and written 293 bytes
                          Verification: OK
                          New, (NONE), Cipher is (NONE)
                          Secure Renegotiation IS NOT supported
                          Compression: NONE
                          Expansion: NONE
                          No ALPN negotiated
                          Early data was not sent
                          Verify return code: 0 (ok)
                            #33
                            Is it possible that there is port typo? It would be 9993 not 9393. So tripple 9
                              humptyH
                              humptyH
                              humpty
                              #34
                              @nebulon I've been using it as 9393, and that's how Girish has it also in the screenshots he sent me during our troubleshooting. Sending and fetching are working with 9393.
                              Edit: I'll try reverting to the original settings soon to test with v8.2.3.
                                #35
                                9393 is the internal IMAP port that does not offer TLS. But my original question was to connect to the external endpoint which is the correct way to configure FreeScout. openssl s_client -connect <mailsever>:993 -crlf where mailserver is my.domain.com (whatever the mail server domain is)
                                There are updated screenshots at https://docs.cloudron.io/apps/freescout/#cloudron-mailbox on how to connect.
                                  bmannB
                                  bmannB
                                  bmann
                                  @girish
                                  CONNECTED(00000003)
                                  depth=2 C = US, O = Internet Security Research Group, CN = ISRG Root X1
                                  verify return:1
                                  depth=1 C = US, O = Let's Encrypt, CN = E6
                                  verify return:1
                                  depth=0 CN = *.commonscomputer.com
                                  verify return:1
                                  Certificate chain
                                   0 s:CN = *.commonscomputer.com
                                     i:C = US, O = Let's Encrypt, CN = E6
                                     a:PKEY: id-ecPublicKey, 384 (bit); sigalg: ecdsa-with-SHA384
                                     v:NotBefore: Dec  9 07:12:07 2024 GMT; NotAfter: Mar  9 07:12:06 2025 GMT
                                   1 s:C = US, O = Let's Encrypt, CN = E6
                                     i:C = US, O = Internet Security Research Group, CN = ISRG Root X1
                                     a:PKEY: id-ecPublicKey, 384 (bit); sigalg: RSA-SHA256
                                     v:NotBefore: Mar 13 00:00:00 2024 GMT; NotAfter: Mar 12 23:59:59 2027 GMT
                                  Server certificate
                                  (several more screenfuls of certs and things)
                                  read R BLOCK
                                  * OK [CAPABILITY IMAP4rev1 SASL-IR LOGIN-REFERRALS ID ENABLE IDLE LITERAL+ AUTH=PLAIN] Dovecot (Ubuntu) ready.
                                  • bmannB bmann
                                    @girish
                                    CONNECTED(00000003)
                                    verify return:1
                                    verify return:1
                                    verify return:1
                                    Certificate chain
                                    Server certificate
                                    read R BLOCK
                                    @bmann perfect. Simply use that domain/port to configure FS
                                      humptyH
                                      humptyH
                                      humpty
                                      @girish It looks like FS is working fine with v.8.2.3 using the proper settings shown in the docs. Thanks for the prompt fixes!
                                      • humptyH
                                        humptyH
                                        humpty
                                        #39
                                        @girish I forgot to ask, are these still the best settings to use or can we set an encryption now?
                                        I'm using Mailgun SMTP.
                                        Manage > Settings > Mail Settings
                                        • humptyH humpty
                                          @humptydumpty said in Connection could not be established with host mail.domain.com [Connection timed out #110]:
                                          Your screenshot is still using the internal connection. The internal connection doesn't need any encryption since they don't leave the server. I don't expect the values to change but those values are still internal/cloudron implementation detail. I suggest using the settings as in the docs at https://docs.cloudron.io/apps/freescout/#cloudron-mailbox . Those use STARTTLS (SMTP) and SSL (IMAP)
