  2. Nextcloud
  3. Nextcloud not responding after restore (healthcheck ECONNREFUSED)
8 Posts 2 Posters 2.4k Views 2 Watching
  • archosA Offline
    archosA Offline
    archos
    Hello,
    after restoring the Nextcloud app (from a previous backup), the application enters the Not responding state.
    The logs only show repeated health check failures:
    Jun 12 08:39:55 Config value were not updated
    Jun 12 08:39:55 ==> Run cron job on startup
    Jun 12 08:40:00 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:40:10 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:40:20 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:40:30 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:40:40 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:40:50 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:41:00 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:41:10 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:41:20 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:41:30 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:41:40 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:41:50 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:00 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:10 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:20 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:30 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:40 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:50 => Healtheck error: Error: connect ECONNREFUSED 172.18.19.58:80
    Jun 12 08:42:55 13:M 12 Jun 2025 06:42:55.468 * 10000 changes in 60 seconds. Saving...
    Jun 12 08:42:55 13:M 12 Jun 2025 06:42:55.469 * Background saving started by pid 26
    Jun 12 08:42:55 26:C 12 Jun 2025 06:42:55.480 * DB saved on disk
    Jun 12 08:42:55 26:C 12 Jun 2025 06:42:55.481 * Fork CoW for RDB: current 1 MB, peak 1 MB, average 0 MB
    Jun 12 08:42:55 13:M 12 Jun 2025 06:42:55.569 * Background saving terminated with success
    • archosA archos
      Hello,
      @Hello archos
      The full app logs of the restore to now are needed to evalute what might be wrong.
      Please provide the full app logs.
      archosA 1 Reply Last reply
        @Hello archos
        archosA Offline
        archosA Offline
        archos
        @james Hello,
        thank you for the quick reply. This is all I have in the logs for now:
        log
          I will take a look in a moment.
          • archosA Offline
            archosA Offline
            archos
            Well, mystery solved (maybe) – I’ve been struggling with this for two hours, and suddenly I got an email that the app is back online.
            No idea what was wrong.
            All of this started because the native Photos app in Nextcloud refuses to load or add any folders that contain photos.
              Oh okay.
              I will not investigate further. Please report back after some time if everything is working as expected.
                Oh okay.
                archosA Offline
                archosA Offline
                archos
                @james As I mentioned, Nextcloud suddenly came back online, but the Photos app still doesn’t work.
                It’s possible that the issue is on Nextcloud’s side, but I’m not sure.
                Anyway, thank you very much for the quick response!
                • archosA Offline
                  archosA Offline
                  archos
                  Looks like it's an issue with the Photos app itself. Hopefully it will be fixed soon.
                  Github
