  3. Restore not possible
20 Posts 6 Posters 3.6k Views 6 Watching
  • sponchS Offline
    sponchS Offline
    sponch
    wrote on last edited by sponch
    Had some troubles with Nextcloud and now wanted to restore from backup.
    Tried different backups from Hetzner Storagebox (cifs) all with the error:
    Crypto Error: Invalid password or tampered file (mac mismatch)
    Haven't changed any encrypting passwords (at least I don't know about it).
    ..edit: just hung in the storagebox some days ago as I always had some backup errors..but help me - even If there should be another encryption password - as long as it is in the Backup options it should use the one for restore, right?
    edit2: cloning doenst work as well (same error)
    • jdaviescoatesJ Online
      I can't help, but just to say this stuff is part of why I tend not to use encryption as in my limited experience the risk of my locking myself out of my own data is higher than the risk that someone else will access it! 🤣
      • jamesJ Online
        jamesJ Online
        Hello @sponch
        Can you please try to manually decrypt a singular backup following this guide:
        https://docs.cloudron.io/guides/decrypt-backups/
        • sponchS Offline
          sponchS Offline
          sponch
          TypeError: Invalid initialization vector
              at Decipheriv.createCipherBase (node:internal/crypto/cipher:117:19)
              at Decipheriv.createCipherWithIV (node:internal/crypto/cipher:128:3)
              at new Decipheriv (node:internal/crypto/cipher:247:3)
              at Object.createDecipheriv (node:crypto:145:10)
              at decryptFilePath (/opt/homebrew/lib/node_modules/cloudron/src/backup-tools.js:55:36)
              at Command.decryptDir (/opt/homebrew/lib/node_modules/cloudron/src/backup-tools.js:284:50)
              at Command.listener [as _actionHandler] (/opt/homebrew/lib/node_modules/cloudron/node_modules/commander/lib/command.js:552:17)
              at /opt/homebrew/lib/node_modules/cloudron/node_modules/commander/lib/command.js:1586:14
              at Command._chainOrCall (/opt/homebrew/lib/node_modules/cloudron/node_modules/commander/lib/command.js:1470:12)
              at Command._parseCommand (/opt/homebrew/lib/node_modules/cloudron/node_modules/commander/lib/command.js:1585:27) {
            code: 'ERR_CRYPTO_INVALID_IV'
          • jamesJ Online
            jamesJ Online
            Is this a tgz or rsync backup?
            • sponchS Offline
              sponchS Offline
              sponch
              @james rsync
              • jamesJ Online
                jamesJ Online
                @sponch
                Once, I've seen a strange error with rsync type backup where a zero byte file blocked the whole process.
                Because, a zero byte file does not even include the encryption header needed for the file.
                Can you please run the following command for the failing rsync decryption:
                find . -type f -size 0
                If you find any zero byte files, move them somewhere else outside the folder and try the decryption again.
                • sponchS Offline
                  sponchS Offline
                  sponch
                  a run the command in the encrypted backup directly right? doesn't find anything
                  • sponchS Offline
                    sponchS Offline
                    sponch
                    what would you recommend: rsync or tgz for future backups?
                    K 1 Reply Last reply
                    • P Offline
                      P Offline
                      p44
                      wrote on last edited by p44
                      We discussed this issue here:
                      https://forum.cloudron.io/topic/12632/tarextract-pipeline-error-invalid-tar-header/24
                      I've encountered this problem twice...
                      @sponch I have a question: Were the backups you're trying to restore still in their original location (where they were first created), or had they been moved/copied to a different Hetzner Box before restoring?
                      I’m asking because the files I tried to recover (unsuccessfully) had been transferred between Hetzner Boxes, and I’m wondering if that could be the root of the issue.
                      Edit: Were the files you tried to restore from the Hetzner Box originally created by the same specific Cloudron instance? Or were they from a different instance (e.g., after a reinstall)? I’m asking to help trace the root cause of the issue.
                      @james I believe that in some cases encryption is necessary, so increased security inherently comes with the trade-off of being locked out of the recovery process. However, in this specific case, we should investigate the root cause of the issue, since it seems that has affected multiple users...
                      @sponch @james Another hypothesis that comes to mind is the use of special characters in the password, which might not be interpreted correctly during the backup recovery process – Eg. a Gui problem –. I’ve since updated my passwords to only include uppercase letters, lowercase letters, and numbers (40 characters long), and the issue appears to be resolved... but this is only an hypothesis.
                      sponchS 1 Reply Last reply
                      • P p44
                        sponchS Offline
                        sponchS Offline
                        sponch
                        Same location (only the prefixed changed months ago - should not concern the recent backups)
                        Same instance. Nextcloud is backed up daily. Last fews days restoring always ends up with same error.
                        Just restored another (unimportant) app from same backup day. Worked perfectly.
                        • P Offline
                          P Offline
                          p44
                          @sponch ok thanks for informations. I hope those informations could help to reproduce issue and eventually find the source cause...
                          • sponchS Offline
                            sponchS Offline
                            sponch
                            hi and thanks four you information. Unfortunately I could not find the cause.... and set up a new Nextcloud instance (only had 5 users and offline data from the clients).
                            As other apps could be restored w/o any problems it must have been s.th. related to Nextcloud specific restoration I guess.
                            Just made a clone of the new Nextcloud App (encryption disabled....)worked perfectly.
                            • sponchS sponch
                              P Offline
                              P Offline
                              p44
                              @sponch you disabled Cloudron Backup Encryption or Nextcloud App Encription?
                              • sponchS sponch
                                K Offline
                                K Offline
                                Kelsey67
                                @sponch I learned the hard way and lost a ton of data using tgz. Rsync is definitely better, i dont even know why anyone would both with tgz. Unless you combine them, use rsync for daily incremental backups to a remote server and tgz for weekly/monthly full archives. i have a large Nextcloud data directory on an AWS server, managed HostJane EC2 - https://www.hostjane.com: supporting 500MB of changes daily (e.g., new uploads, modified files) needing frequent backups for tens of GBs for mainly photos). I like to set up rsync via Cygwin, automate it with Task Scheduler, and pair it with database dumps.
                                e.g. Rsync transfers the full 50GB data directory to the NAS.
                                Time: ~2 hours at 5MB/s (50GB ÷ 5MB/s = 10,000 seconds ≈ 167 minutes).
                                Bandwidth: 50GB.
                                Compare that to tgz. Backup takes ~6 hours 20 minutes, regardless of changes, due to full compression and transfer. tgz completely screws up Nextcloud availability if maintenance mode extends into active hours. tgz requires a full archive each time, additional steps to manage multiple archives. tgz is redundant for every use case of every Nextcloud backup I have ever done.
                                • P p44
                                  sponchS Offline
                                  sponchS Offline
                                  sponch
                                  @p44 I haven't uses NC Encryption. I disabled backup encryption now (which doesn't feel right....). But as I said - other apps could be restored w/o any problems.
                                  As restoring backups should be one of the most important thing for everyone here I wonder why there came no further support from "official" side here.
                                  • K Kelsey67
                                    Bandwidth: 50GB.
                                    sponchS Offline
                                    sponchS Offline
                                    sponch
                                    @Kelsey67 thanks. that’s what I have used anyway.
                                    • sponchS sponch
                                      P Offline
                                      P Offline
                                      p44
                                      @sponch Thanks, keep us posted.
                                      • necrevistonnezrN Offline
                                        restic is made for this. Fast, e2e encrypted, any provider you can imagine via rclone.
                                          P Offline
                                          P Offline
                                          p44
                                          @necrevistonnezr Thanks a lot, it seems to be a very good strategy, but implementation is out of my personal knowledge.
