  3. Running Cloudron on eMMC – How to Reduce Writes?
Scheduled Pinned Locked Moved Solved Discuss
15 Posts 4 Posters 2.3k Views 4 Watching
  • WiseMetalheadW Offline
    WiseMetalhead
    Hi there!
    I decided to install Cloudron on my home mini PC, using the built-in eMMC storage for Ubuntu (to keep my M.2 drives free from the OS). I understand that to preserve the longevity of the eMMC memory, it's important to reduce write operations as much as possible. There are plenty of suggestions online — disabling swap, lowering the swappiness value, tweaking or disabling system logging, etc.
    But my main question is: how can I minimize Cloudron's impact on system disk wear?
    I realize it would be much easier to just dedicate one of the M.2 SSDs for the OS and Cloudron, but at this point, it’s become more of a curiosity project 🙂
      It is a bit to tinker, but you can see all locations Cloudron mostly writes to at https://docs.cloudron.io/storage/#default-data-directory and you could relocate those to the M.2 drive then (see relocate section in the docs page)
      Further for swap you may also just add the swapfile onto the M.2 drive.
      WiseMetalheadW 1 Reply Last reply
        WiseMetalhead
        @nebulon said in Running Cloudron on eMMC – How to Reduce Writes?:
        Thank you! I managed to move everything except the swap. I'm still not entirely sure about the correct steps for that. As for the Docker images — I haven’t moved them yet, since they don’t take up enough space to be a problem at this point.
          Great. For swap you can follow the docs at https://docs.cloudron.io/storage/#swap just make sure the swapfile is located within the other disk.
            WiseMetalhead
            Great, everything’s working now. Thanks again!
            • WiseMetalheadW WiseMetalhead
              WiseMetalhead
              So, I finally decided to move Docker images to my main SSD.
              Unfortunately, after completing the steps, Cloudron didn’t fully start up. I could access the dashboard, but only a few services were running — cloudron, docker, unbound, and nginx. The logs were also filled with errors.
              2025-10-14T14:19:49.974Z box:platform onActivated: starting post activation services
              2025-10-14T14:19:49.974Z box:platform startInfra: checking infrastructure
              2025-10-14T14:19:49.975Z box:platform startInfra: updating infrastructure from 49.8.1 to 49.8.0
              2025-10-14T14:19:49.975Z box:platform markApps: reconfiguring apps
              2025-10-14T14:19:49.975Z box:reverseproxy removeAppConfigs: removing app nginx configs
              2025-10-14T14:19:50.030Z box:platform removeAllContainers: removing all containers for infra upgrade
              2025-10-14T14:19:50.030Z box:shell platform: docker ps -qa --filter label=isCloudronManaged
              2025-10-14T14:19:50.046Z box:platform createDockerNetwork: recreating docker network
              2025-10-14T14:19:50.046Z box:shell platform: docker network rm -f cloudron
              2025-10-14T14:19:50.326Z box:shell platform: docker network create --subnet=172.18.0.0/16 --ip-range=172.18.0.0/20 --gateway=172.18.0.1 --ipv6 --subnet=fd00:c107:d509::/64 cloudron
              2025-10-14T14:19:50.514Z box:services startServices: 49.8.1 -> 49.8.0. starting all services
              2025-10-14T14:19:50.514Z box:mailserver startMail: starting
              2025-10-14T14:19:50.518Z box:mailserver restart: restarting mail container with mailFqdn:my.DOMAIN.ru mailDomain:lvcloud.ru
              2025-10-14T14:19:50.522Z box:locks write: current locks: {"mail_restart":null}
              2025-10-14T14:19:50.523Z box:locks acquire: mail_restart
              2025-10-14T14:19:50.530Z box:mailserver configureMail: stopping and deleting previous mail container
              2025-10-14T14:19:50.548Z box:mailserver createMailConfig: generating mail config with my.DOMAIN.ru
              2025-10-14T14:19:50.553Z box:mailserver configureMail: starting mail container
              2025-10-14T14:19:50.553Z box:shell mailserver: /bin/bash -c docker run --restart=always -d --name=mail                 --net cloudron                 --net-alias mail                 --log-driver syslog                 --log-opt syslog-address=unix:///home/yellowtent/platformdata/logs/syslog.sock                 --log-opt syslog-format=rfc5424                 --log-opt tag=mail                 -m 3221225472                 --memory-swap -1                 --dns 172.18.0.1                 --dns-search=.                 --ip 172.18.30.4                 -e CLOUDRON_MAIL_TOKEN=8341aa4f76f95c159da68e7b42a2eebccdf3030911053500489402bae83441cb74cafabe0be38274ea1a9fbfdcce53bb60e7ae94a5ffdd134b1eeaabe832334c397b4c93824a0fe51ef1a22b6ae3877be5c930814128680bac06dc410afbf4301791f07dce29fae3d0323e95d247e3ba74ff1229823f4711c0abdee014d414f1                 -e CLOUDRON_RELAY_TOKEN=f40b99d36cb9ad072aafdecd52fabb44c7fb9464e2dc573e9468105143f3d2f2f6efc191cbe8b93b8fea50cb54318081f316464c6abb2d9d82f53a2e9f82b024b74ca69efbef550f7706368ec8c38cb0f6a5980d7883ca95e30eaab3b4dc6476b3305bd87bc9c55fdca16d4d8169500eb2cf4e5bacd54ca7ace2d646fff8f551                 -e LOGLEVEL=info                 -v /home/yellowtent/boxdata/mail:/app/data                 -v /home/yellowtent/platformdata/addons/mail:/etc/mail:ro                 -p 587:2587 -p 993:9993 -p 4190:4190 -p 25:2587 -p 465:2465 -p 995:9995                 --label isCloudronManaged=true                 --read-only -v /run -v /tmp registry.docker.com/cloudron/mail:3.15.0@sha256:c93b5a83fc4e775bda4e05010bd19e5a658936e7a09cf7e51281e3696fde4536
              2025-10-14T14:20:40.637Z box:shell mailserver: /bin/bash -c docker run --restart=always -d --name=mail                 --net cloudron                 --net-alias mail                 --log-driver syslog                 --log-opt syslog-address=unix:///home/yellowtent/platformdata/logs/syslog.sock                 --log-opt syslog-format=rfc5424                 --log-opt tag=mail                 -m 3221225472                 --memory-swap -1                 --dns 172.18.0.1                 --dns-search=.                 --ip 172.18.30.4                 -e CLOUDRON_MAIL_TOKEN=8341aa4f76f95c159da68e7b42a2eebccdf3030911053500489402bae83441cb74cafabe0be38274ea1a9fbfdcce53bb60e7ae94a5ffdd134b1eeaabe832334c397b4c93824a0fe51ef1a22b6ae3877be5c930814128680bac06dc410afbf4301791f07dce29fae3d0323e95d247e3ba74ff1229823f4711c0abdee014d414f1                 -e CLOUDRON_RELAY_TOKEN=f40b99d36cb9ad072aafdecd52fabb44c7fb9464e2dc573e9468105143f3d2f2f6efc191cbe8b93b8fea50cb54318081f316464c6abb2d9d82f53a2e9f82b024b74ca69efbef550f7706368ec8c38cb0f6a5980d7883ca95e30eaab3b4dc6476b3305bd87bc9c55fdca16d4d8169500eb2cf4e5bacd54ca7ace2d646fff8f551                 -e LOGLEVEL=info                 -v /home/yellowtent/boxdata/mail:/app/data                 -v /home/yellowtent/platformdata/addons/mail:/etc/mail:ro                 -p 587:2587 -p 993:9993 -p 4190:4190 -p 25:2587 -p 465:2465 -p 995:9995                 --label isCloudronManaged=true                 --read-only -v /run -v /tmp registry.docker.com/cloudron/mail:3.15.0@sha256:c93b5a83fc4e775bda4e05010bd19e5a658936e7a09cf7e51281e3696fde4536  errored BoxError: /bin/bash exited with code 125 signal null
                  at ChildProcess.<anonymous> (/home/yellowtent/box/src/shell.js:72:23)
                  at ChildProcess.emit (node:events:519:28)
                  at maybeClose (node:internal/child_process:1105:16)
                  at ChildProcess._handle.onexit (node:internal/child_process:305:5) {
                reason: 'Shell Error',
                details: {},
                stdout: '',
                stdoutLineCount: 0,
                stderr: "Unable to find image 'registry.docker.com/cloudron/mail:3.15.0@sha256:c93b5a83fc4e775bda4e05010bd19e5a658936e7a09cf7e51281e3696fde4536' locally\n" +
                  'docker: Error response from daemon: Get "https://registry.docker.com/v2/": dial tcp: lookup registry.docker.com on 127.0.0.53:53: read udp 127.0.0.1:54808->127.0.0.53:53: i/o timeout.\n' +
                  "See 'docker run --help'.\n",
                stderrLineCount: 3,
                code: 125,
                signal: null
              2025-10-14T14:20:40.644Z box:locks write: current locks: {}
              2025-10-14T14:20:40.644Z box:locks release: mail_restart
              2025-10-14T14:20:40.644Z box:platform startInfra: Failed to start services. retry=false (attempt 0): /bin/bash exited with code 125 signal null
              2025-10-14T14:20:40.644Z box:platform BoxError: /bin/bash exited with code 125 signal null
              2025-10-14T14:21:30.394Z box:shell system: swapon --noheadings --raw --bytes --show=type,size,used,name
              2025-10-14T14:21:30.843Z box:shell services: grep -q avx /proc/cpuinfo
              2025-10-14T14:21:30.883Z box:shell services: systemctl is-active unbound
              2025-10-14T14:21:30.907Z box:shell services: systemctl is-active nginx
              2025-10-14T14:21:36.375Z box:mailserver restart: restarting mail container with mailFqdn:my.DOMAIN.ru mailDomain:lvcloud.ru
              2025-10-14T14:21:36.378Z box:locks write: current locks: {"mail_restart":null}
              2025-10-14T14:21:36.378Z box:locks acquire: mail_restart
              2025-10-14T14:21:36.382Z box:mailserver configureMail: stopping and deleting previous mail container
              2025-10-14T14:21:36.386Z box:mailserver createMailConfig: generating mail config with my.DOMAIN.ru
              2025-10-14T14:21:36.388Z box:mailserver configureMail: starting mail container
              2025-10-14T14:21:36.388Z box:shell mailserver: /bin/bash -c docker run --restart=always -d --name=mail                 --net cloudron                 --net-alias mail                 --log-driver syslog                 --log-opt syslog-address=unix:///home/yellowtent/platformdata/logs/syslog.sock                 --log-opt syslog-format=rfc5424                 --log-opt tag=mail                 -m 3221225472                 --memory-swap -1                 --dns 172.18.0.1                 --dns-search=.                 --ip 172.18.30.4                 -e CLOUDRON_MAIL_TOKEN=2e511179a006de6797e4f4aaeb1b26d5bcd61591fa4719d22117f0f26e5e90869e0d06b6fbac980cf9d6b71454e4e77a8ea1b8027ea5de876d3d79c95e7a06a7a6477f9347995d527f32ef1fdcda8dfbbc95a448f672423c679b3debe7f65b2c9c460d5b996044ca0fdc4449242982b7f52989f622a6b9308f97298c167ad7a0                 -e CLOUDRON_RELAY_TOKEN=2b059b06940699c69a0039ad98bd6f6b1fae80e5a5793c97a73efa92517f38707d8d0f5a6ebfa2da41c7a60b0aeebdca285dbfa9b200af1202bf3a0418076dc7bce27dd343eb0f6c8560595806729a9009e53bf9260d155e912e68f2512368bdbc728d8248d962c68b390a903aec7bfde0484e579cfc0812199e4fa079069167                 -e LOGLEVEL=info                 -v /home/yellowtent/boxdata/mail:/app/data                 -v /home/yellowtent/platformdata/addons/mail:/etc/mail:ro                 -p 587:2587 -p 993:9993 -p 4190:4190 -p 25:2587 -p 465:2465 -p 995:9995                 --label isCloudronManaged=true                 --read-only -v /run -v /tmp registry.docker.com/cloudron/mail:3.15.0@sha256:c93b5a83fc4e775bda4e05010bd19e5a658936e7a09cf7e51281e3696fde4536
              2025-10-14T14:22:26.468Z box:shell mailserver: /bin/bash -c docker run --restart=always -d --name=mail                 --net cloudron                 --net-alias mail                 --log-driver syslog                 --log-opt syslog-address=unix:///home/yellowtent/platformdata/logs/syslog.sock                 --log-opt syslog-format=rfc5424                 --log-opt tag=mail                 -m 3221225472                 --memory-swap -1                 --dns 172.18.0.1                 --dns-search=.                 --ip 172.18.30.4                 -e CLOUDRON_MAIL_TOKEN=2e511179a006de6797e4f4aaeb1b26d5bcd61591fa4719d22117f0f26e5e90869e0d06b6fbac980cf9d6b71454e4e77a8ea1b8027ea5de876d3d79c95e7a06a7a6477f9347995d527f32ef1fdcda8dfbbc95a448f672423c679b3debe7f65b2c9c460d5b996044ca0fdc4449242982b7f52989f622a6b9308f97298c167ad7a0                 -e CLOUDRON_RELAY_TOKEN=2b059b06940699c69a0039ad98bd6f6b1fae80e5a5793c97a73efa92517f38707d8d0f5a6ebfa2da41c7a60b0aeebdca285dbfa9b200af1202bf3a0418076dc7bce27dd343eb0f6c8560595806729a9009e53bf9260d155e912e68f2512368bdbc728d8248d962c68b390a903aec7bfde0484e579cfc0812199e4fa079069167                 -e LOGLEVEL=info                 -v /home/yellowtent/boxdata/mail:/app/data                 -v /home/yellowtent/platformdata/addons/mail:/etc/mail:ro                 -p 587:2587 -p 993:9993 -p 4190:4190 -p 25:2587 -p 465:2465 -p 995:9995                 --label isCloudronManaged=true                 --read-only -v /run -v /tmp registry.docker.com/cloudron/mail:3.15.0@sha256:c93b5a83fc4e775bda4e05010bd19e5a658936e7a09cf7e51281e3696fde4536  errored BoxError: /bin/bash exited with code 125 signal null
                details: {},
                stdout: '',
                stdoutLineCount: 0,
                  'docker: Error response from daemon: Get "https://registry.docker.com/v2/": dial tcp: lookup registry.docker.com on 127.0.0.53:53: read udp 127.0.0.1:51654->127.0.0.53:53: i/o timeout.\n' +
                stderrLineCount: 3,
                code: 125,
                signal: null
              2025-10-14T14:22:26.474Z box:locks write: current locks: {}
              2025-10-14T14:22:26.474Z box:locks release: mail_restart
              HttpError: /bin/bash exited with code 125 signal null
                  at BoxError.toHttpError (/home/yellowtent/box/src/boxerror.js:109:16)
                  at restart (/home/yellowtent/box/src/routes/services.js:125:37)
                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5) {
                status: 500,
                internalError: BoxError: /bin/bash exited with code 125 signal null
                  details: {},
                  stdout: '',
                  stdoutLineCount: 0,
                  stderrLineCount: 3,
                  code: 125,
                  signal: null
                details: {}
              I reverted everything back for now, and Cloudron is working again. Just wondering — is this section of the documentation still valid for the current Cloudron versions, or could this issue be something specific to my setup?
              J 1 Reply Last reply
                  details: {},
                  stdout: '',
                  stdoutLineCount: 0,
                  stderrLineCount: 3,
                  code: 125,
                  signal: null
                  details: {},
                  stdout: '',
                  stdoutLineCount: 0,
                  stderrLineCount: 3,
                  code: 125,
                  signal: null
                  status: 500,
                    details: {},
                    stdout: '',
                    stdoutLineCount: 0,
                    stderrLineCount: 3,
                    code: 125,
                    signal: null
                  details: {}
                J Online
                J Online
                @WiseMetalhead said in Running Cloudron on eMMC – How to Reduce Writes?:
                The error seems to indicate that it cannot pull down the docker images. Does cloudron-support --troubleshoot work (this verifies the DNS etc) ?
                  WiseMetalhead
                  @joseph
                  Right now cloudron-support --troubleshoot works and shows the following:
                  Vendor: AZW Product: ME mini
                  Linux: 6.14.0-33-generic
                  Ubuntu: noble 24.04
                  Processor: Intel(R) N150
                  BIOS Intel(R) N150 To Be Filled By O.E.M. CPU @ 2.8GHz x 4
                  RAM: 12001804KB
                  Disk: /dev/mmcblk0p2   24G
                  [OK]	node version is correct
                  [OK]	IPv6 is enabled in kernel. No public IPv6 address
                  [OK]	docker is running
                  [OK]	MySQL is running
                  [OK]	nginx is running
                  [OK]	dashboard cert is valid
                  [OK]	box v8.3.2 is running
                  [OK]	netplan is good
                  [OK]	Dashboard is reachable via domain name
                  [WARN]	Domain ***.ru expiry check skipped because whois does not have this information
                  [OK]	unbound is running
                  It’s strange that the Docker images couldn’t be pulled, because updates and new app installations work for me without any issues.
                  • jamesJ Online
                    jamesJ Online
                    Hello @WiseMetalhead
                    Can you please run the following commands for me and give me the output?
                    docker run --rm hello-world
                    and
                    dig A registry.docker.com
                      and
                      WiseMetalhead
                      wrote on last edited by WiseMetalhead
                      @james said in Running Cloudron on eMMC – How to Reduce Writes?:
                      Unable to find image 'hello-world:latest' locally
                      latest: Pulling from library/hello-world
                      17eec7bbc9d7: Pull complete
                      Digest: sha256:6dc565aa630927052111f823c303948cf83670a3903ffa3849f1488ab517f891
                      Status: Downloaded newer image for hello-world:latest
                      Hello from Docker!
                      This message shows that your installation appears to be working correctly.
                      To generate this message, Docker took the following steps:
                       1. The Docker client contacted the Docker daemon.
                       2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
                          (amd64)
                       3. The Docker daemon created a new container from that image which runs the
                          executable that produces the output you are currently reading.
                       4. The Docker daemon streamed that output to the Docker client, which sent it
                          to your terminal.
                      To try something more ambitious, you can run an Ubuntu container with:
                       $ docker run -it ubuntu bash
                      Share images, automate workflows, and more with a free Docker ID:
                       https://hub.docker.com/
                      For more examples and ideas, visit:
                       https://docs.docker.com/get-started/
                      ; <<>> DiG 9.18.30-0ubuntu0.24.04.2-Ubuntu <<>> A registry.docker.com
                      ;; global options: +cmd
                      ;; Got answer:
                      ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 4191
                      ;; flags: qr rd ra; QUERY: 1, ANSWER: 8, AUTHORITY: 0, ADDITIONAL: 1
                      ;; OPT PSEUDOSECTION:
                      ; EDNS: version: 0, flags:; udp: 65494
                      ;; QUESTION SECTION:
                      ;registry.docker.com.		IN	A
                      ;; ANSWER SECTION:
                      registry.docker.com.	60	IN	A	34.197.251.18
                      registry.docker.com.	60	IN	A	18.206.23.233
                      registry.docker.com.	60	IN	A	98.86.59.233
                      registry.docker.com.	60	IN	A	52.22.88.186
                      registry.docker.com.	60	IN	A	34.225.208.41
                      registry.docker.com.	60	IN	A	34.237.110.211
                      registry.docker.com.	60	IN	A	54.165.148.211
                      registry.docker.com.	60	IN	A	34.232.216.124
                      ;; Query time: 60 msec
                      ;; SERVER: 127.0.0.53#53(127.0.0.53) (UDP)
                      ;; WHEN: Wed Oct 15 08:52:27 UTC 2025
                      ;; MSG SIZE  rcvd: 176
                      • jamesJ Online
                        jamesJ Online
                        So the pull of the hello-world image worked.
                        So maybe now the pull of the cloudron/mail:3.15.0 image works as well?
                        Can you please try to pull the image manually?
                        docker pull cloudron/mail:3.15.0@sha256:c93b5a83fc4e775bda4e05010bd19e5a658936e7a09cf7e51281e3696fde4536
                        If this works manually, there might be an issue in the box startup.
                        @WiseMetalhead Since you censored your domain in the latest post in the output of cloudron-support --troubleshoot I take the liberty to also censor your domain from the box.log you have posted above.
                          WiseMetalhead
                          Thanks a lot for your help and suggestions. I was able to resolve my issue.
                          My Cloudron had AdGuard Home installed and connected to the router. Even though I set the server’s traffic to go through the provider’s DNS, I probably messed something up in the configuration.
                          Since AdGuard Home wasn’t working, there was no DNS resolution, and therefore no connection 😑
                          After I temporarily changed the DNS on the router, everything started working fine. The Docker images are slowly restoring now.
                          • jamesJ Online
                            jamesJ Online
                            Good to read!
                            Also, back to main topic of reducing writes to the eMMC.
                            Logs!
                            Since logs get written all the time this might also be good to move somewhere away from the eMMC.
                            If you don't care about logs and have enough memory, you could even create a Ramdisk and have all logs just be in RAM.
                            I have put my download folder into a Ramdisk since I used to never clean up my downloads and now each reboot deletes everything.
                            Also, nice side effect, since I know my downloads folder is not persistent, I have to sort documents into a correct location. Less messy file system.
                            And, since its RAM, the read-write rates super high, also improving the download speed.
                              WiseMetalhead
                              @james
                              Fortunately, I took care of this issue almost right after installing Ubuntu, but thanks a lot for sharing another interesting approach.
                                WiseMetalhead
                                • WiseMetalheadW WiseMetalhead referenced this topic on
