  2. MediaWiki
  3. Changing entry point URLs
Scheduled Pinned Locked Moved MediaWiki
feature-request
2 Posts 2 Posters 9.9k Views 2 Watching
  • M
    mononym
    wrote on last edited by mononym
    Hi. I would like to remove the /wiki/ in my site's URL: https:example.com/wiki/some_page -> https://example.com/some_page
    I added two variables in app/data/LocalSettings.php:
    $wgArticlePath = '/$1';
    $wgScriptPath = '/';
    After a restart, the https:example.com landing page loads but without any CSS style. All other pages behind /wiki/ did not "move" and do not exist at the new URLs.
    On the mediawiki one step in the process is "Rename the installation directory of MediaWiki on your server from /wiki to /w [i.e. / in my case]." How can I do that ?
    EDIT: with $wgScriptPath = ''; the stylesheet is loaded.
      Hello @mononym
      I have investigated this issue and found the following.
      According to my understanding after reading the documentation the LocalSettings.php should include the following:
      # Set the script path to root
      $wgScriptPath = "";
      # Set the article path for pretty URLs
      $wgArticlePath = "/$1";
      # If you're using a different entry point than index.php
      $wgScript = "/index.php";
      # For resource loading
      $wgResourceBasePath = $wgScriptPath;
      Just for good measure I also cleared the Main Page cache with:
      php maintenance/run.php purgePage <<< "Main Page"
      But sadly, this did also not work.
      So the only thing now breaking it could be the apache2 config and there it is.
      By default (not editable) - https://git.cloudron.io/packages/mediawiki-app/-/blob/master/apache/mediawiki.conf?ref_type=heads:
      ServerName %{HTTP_HOST}
      <VirtualHost *:8000>
          DocumentRoot /app/code
          LogFormat "%{X-Forwarded-For}i %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" proxy
          CustomLog "|/bin/cat" proxy
          ErrorLog "|/bin/cat"
          # https://www.mediawiki.org/wiki/Manual:Security
          php_flag register_globals off
          ## http://www.mediawiki.org/wiki/Manual:Short_URL/Apache
          RewriteEngine On
          RewriteRule ^/?wiki(/.*)?$ %{DOCUMENT_ROOT}/index.php [L]
          RewriteRule ^/*$ %{DOCUMENT_ROOT}/index.php [L]
          <Directory /app/code>
              Options +FollowSymLinks
              AllowOverride All
              Require all granted
          </Directory>
          # some directories must be protected
          # images/ still has to be accessible since mw references it directly
          <Directory /app/code/images>
              Options -FollowSymLinks
              AllowOverride None
              <IfModule mod_php7.c>
                  php_admin_flag engine off
              </IfModule>
          </Directory>
      </VirtualHost>
      I put the app into recovery mode and edited the Apache2 site file and changed the rewrite to the following:
          RewriteEngine On
          RewriteCond %{REQUEST_URI} !^/rest\.php
          RewriteCond %{DOCUMENT_ROOT}%{REQUEST_URI} !-f
          RewriteCond %{DOCUMENT_ROOT}%{REQUEST_URI} !-d
          RewriteRule ^(.*)$ %{DOCUMENT_ROOT}/index.php [L]
      and started the app with /app/pkg/start.sh and got a working MediaWiki under sub.DOMAIN.tld/Main_Page.
      To make this usable for you and everyone else, an app update would be needed where users, like you, could also upload a custom Apache2 site setting file that will be included to overwrite the default one.
      I am converting / hijacking this topic into a feature request.
