  2. Greenlight
  3. Sending emails doesn't work
Scheduled Pinned Locked Moved Solved Greenlight
6 Posts 3 Posters 3.3k Views 3 Watching
  • jeauJ Offline
    jeauJ Offline
    jeau
    When I try setting registration method to "Invitation", I can't and this message appears:
    Emails must be enabled in order to use this method. Please contact your system administrator.
      Just released the new package with the fix from @BrutalBirdie thanks!
      • jeauJ Offline
        jeauJ Offline
        jeau
        I found a solution. Inside the .env file, I uncommented and activated the option:
        ALLOW_MAIL_NOTIFICATIONS=true
        and it works well.
        It activates also the password reset.
        Maybe this option should be enabled in the packaging of this application.
        • jeauJ jeau
          and it works well.
          BrutalBirdieB Offline
          @jeau hmm another good catch.
          The problem with Greenlight is also, every time you make .env file changes you need to restart the app to take effect.
          I will look into this option and make an update tomorrow.
          Thanks for reporting.
          • BrutalBirdieB BrutalBirdie
            Checked, Updated, Tested.
            Created PR.
            https://git.cloudron.io/cloudron/greenlight-app/-/merge_requests/6
            jeauJ 1 Reply Last reply
              Created PR.
              jeauJ Offline
              jeauJ Offline
              jeau
              @brutalbirdie thanks
