  2. Nextcloud
  3. How to fix thes errors in PostgreSQL Logs related to oc_filecache_extended ?
postgresqlnextcloud
12 Posts 3 Posters 4.5k Views 3 Watching
  • JOduMonTJ Offline
    JOduMonTJ Offline
    JOduMonT
    While I still have bearly 500MiB (but a lot of tiny files) as data in this Nextcloud instance and not Nextcloud Client yet, I installed almost all recommended apps
    While on Redis and Nextcloud side I don't see anything abnormal
    Related to this issue it seams to be related to memcached
    occ maintenance:repair only Removed 2 orphaned children entries
    I also did an occ files:scan --all
    Jan 14 09:14:13 2021-01-14 02:14:13.822 UTC [68545] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:51 2021-01-14 02:14:51.089 UTC [68562] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:51 2021-01-14 02:14:51.089 UTC [68562] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1532) already exists.
    Jan 14 09:14:51 2021-01-14 02:14:51.089 UTC [68562] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:51 2021-01-14 02:14:51.479 UTC [68563] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:51 2021-01-14 02:14:51.479 UTC [68563] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1565) already exists.
    Jan 14 09:14:51 2021-01-14 02:14:51.479 UTC [68563] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:51 2021-01-14 02:14:51.651 UTC [68565] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:51 2021-01-14 02:14:51.651 UTC [68565] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1534) already exists.
    Jan 14 09:14:51 2021-01-14 02:14:51.651 UTC [68565] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:52 2021-01-14 02:14:52.363 UTC [68566] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:52 2021-01-14 02:14:52.363 UTC [68566] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1543) already exists.
    Jan 14 09:14:52 2021-01-14 02:14:52.363 UTC [68566] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:52 2021-01-14 02:14:52.486 UTC [68569] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:52 2021-01-14 02:14:52.486 UTC [68569] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1573) already exists.
    Jan 14 09:14:52 2021-01-14 02:14:52.486 UTC [68569] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:52 2021-01-14 02:14:52.974 UTC [68572] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:52 2021-01-14 02:14:52.974 UTC [68572] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1711) already exists.
    Jan 14 09:14:52 2021-01-14 02:14:52.974 UTC [68572] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:53 2021-01-14 02:14:53.063 UTC [68571] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:53 2021-01-14 02:14:53.063 UTC [68571] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1707) already exists.
    Jan 14 09:14:53 2021-01-14 02:14:53.063 UTC [68571] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:53 2021-01-14 02:14:53.198 UTC [68573] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:53 2021-01-14 02:14:53.198 UTC [68573] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1708) already exists.
    Jan 14 09:14:53 2021-01-14 02:14:53.198 UTC [68573] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:53 2021-01-14 02:14:53.954 UTC [68579] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:53 2021-01-14 02:14:53.954 UTC [68579] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1736) already exists.
    Jan 14 09:14:53 2021-01-14 02:14:53.954 UTC [68579] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:54 2021-01-14 02:14:54.070 UTC [68581] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:54 2021-01-14 02:14:54.070 UTC [68581] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1751) already exists.
    Jan 14 09:14:54 2021-01-14 02:14:54.070 UTC [68581] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:54 2021-01-14 02:14:54.394 UTC [68584] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:54 2021-01-14 02:14:54.394 UTC [68584] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1756) already exists.
    Jan 14 09:14:54 2021-01-14 02:14:54.394 UTC [68584] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:54 2021-01-14 02:14:54.492 UTC [68583] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:54 2021-01-14 02:14:54.492 UTC [68583] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1759) already exists.
    Jan 14 09:14:54 2021-01-14 02:14:54.492 UTC [68583] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:54 2021-01-14 02:14:54.767 UTC [68586] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:54 2021-01-14 02:14:54.767 UTC [68586] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1760) already exists.
    Jan 14 09:14:54 2021-01-14 02:14:54.767 UTC [68586] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:54 2021-01-14 02:14:54.933 UTC [68587] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:54 2021-01-14 02:14:54.933 UTC [68587] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1765) already exists.
    Jan 14 09:14:54 2021-01-14 02:14:54.933 UTC [68587] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:14:55 2021-01-14 02:14:55.060 UTC [68585] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:14:55 2021-01-14 02:14:55.060 UTC [68585] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(1762) already exists.
    Jan 14 09:14:55 2021-01-14 02:14:55.060 UTC [68585] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
    Jan 14 09:15:22 2021-01-14 02:15:22.545 UTC [68606] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 ERROR: duplicate key value violates unique constraint "oc_filecache_extended_pkey"
    Jan 14 09:15:22 2021-01-14 02:15:22.545 UTC [68606] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 DETAIL: Key (fileid)=(3982) already exists.
    Jan 14 09:15:22 2021-01-14 02:15:22.545 UTC [68606] user85bc018b6fe74f26913fd53467e14a05@db85bc018b6fe74f26913fd53467e14a05 STATEMENT: INSERT INTO "oc_filecache_extended" ("fileid", "upload_time") VALUES($1, $2)
      Hm this issue again...we have had various problems with those cache keys during app update. Apparently some nextcloud addons use fields and until recently the table primary key was not correctly set, resulting in not unique keys.
      We have a special section for attempts to handle this in the start.sh since recently: https://git.cloudron.io/cloudron/nextcloud-app/-/blob/master/start.sh#L173
      Which nextcloud package version are you currently at?
      JOduMonTJ 1 Reply Last reply
        JOduMonTJ Offline
        JOduMonTJ Offline
        JOduMonT
        @nebulon said in How to fix thes errors in PostgreSQL Logs related to oc_filecache- _extended ?:
        Nextcloud Package v4.8.5 App v20.0.5
        Nextcloud apps
        • Auditing / Logging 1.10.0 Featured
        • Bookmarks 4.0.5
        • Calendar 2.1.3 Featured
        • Circles 0.20.6 Featured
        • Collaborative tags 1.10.0 Featured
        • Comments 1.10.0 Featured
        • Contacts 3.4.3 Featured
        • Contacts Interaction 1.1.0 Featured
        • Dashboard 7.0.0 Featured
        • Deck 1.2.3 Featured
        • Deleted files 1.10.1 Featured
        • Duplicate Finder 0.0.4
        • External storage support 1.11.1 Featured
        • Federation 1.10.1 Featured
        • File sharing 1.12.2 Featured
        • First run wizard 2.9.0 Featured
        • Flow Upload 1.1.2
        • Forms 2.1.0 Featured
        • Impersonate 1.7.0 Featured
        • LDAP user and group backend 1.10.2 Featured
        • Log Reader 2.5.0 Featured
        • Monitoring 1.10.0
        • Featured News 15.1.1
        • Nextcloud announcements 1.9.0 Featured
        • Notes 4.0.2 Featured
        • Notifications 2.8.0 Featured
        • ONLYOFFICE 6.2.0 Featured
        • Password policy 1.10.1 Featured
        • PDF viewer 2.0.1 Featured
        • Photos 1.2.3 Featured
        • Privacy 1.4.0 Featured
        • QOwnNotesAPI 20.9.0
        • Recommendations 0.8.0 Featured
        • Retention 1.9.0 Featured
        • Right click 0.17.0 Featured
        • Share by mail 1.10.0 Featured
        • Social 0.4.2 Featured
        • Social sharing via Diaspora 2.1.0 Featured
        • Social sharing via email 2.1.0 Featured
        • Social sharing via Facebook 2.1.0 Featured
        • Social sharing via Twitter 2.1.0 Featured
        • Support 1.3.0 Featured
        • Talk 10.0.5 Featured
        • Tasks 0.13.6 Featured
        • Text 3.1.0 Featured
        • Theming 1.11.0 Featured
        • Two-Factor TOTP Provider 5.0.0
        • Update notification 1.10.0 Featured
        • Usage survey 1.8.0 Featured
        • User status 1.0.1 Featured
        • Versions 1.13.0 Featured
        • Video player 1.9.0 Featured
        • Weather status 1.0.0 Featured
        I'm welling to execute command and disable apps for test purpose
        just tell me 🙂
        • JOduMonTJ JOduMonT
          Nextcloud apps
          • Bookmarks 4.0.5
          • Flow Upload 1.1.2
          • Monitoring 1.10.0
          just tell me 🙂
          @jodumont For a start, can you put the app into developer mode and then verify that indeed sudo -u www-data php /app/code/occ db:add-missing-primary-keys is the failing command?
          After that you can run the sql commands mentioned in that start.sh if section. As far as I can tell if that is run, you shouldn't hit the issue you are seeing.
          JOduMonTJ amg-webA 2 Replies Last reply
            JOduMonTJ Offline
            JOduMonTJ Offline
            JOduMonT
            @nebulon said in How to fix thes errors in PostgreSQL Logs related to oc_filecache_extended ?:
            Dev Mode ?
            I restarted the Nextcloud Apps in recovery mode
            and executed the command in the Terminal App
            it ran without issue
            Check primary keys.
            Done.
              yes I meant recovery mode. So can you then see in the logs where the issue you initially posted appears?
                JOduMonTJ Offline
                JOduMonTJ Offline
                JOduMonT
                ok I did it again this (my) morning
                Nextcloud ran the command without any issue
                Check primary keys.
                Done.
                and in PostgreSQL logs nothing appear
                • yesterday = 21:15
                • today = 06:46
                Jan 15 17:15:36 Starting supervisor
                Jan 15 17:15:37 2021-01-15 10:15:37,375 CRIT Supervisor running as root (no user in config file)
                Jan 15 17:15:37 2021-01-15 10:15:37,393 INFO Included extra file "/etc/supervisor/conf.d/postgresql-service.conf" during parsing
                Jan 15 17:15:37 2021-01-15 10:15:37,393 INFO Included extra file "/etc/supervisor/conf.d/postgresql.conf" during parsing
                Jan 15 17:15:37 2021-01-15 10:15:37,462 INFO RPC interface 'supervisor' initialized
                Jan 15 17:15:37 2021-01-15 10:15:37,481 CRIT Server 'inet_http_server' running without any HTTP authentication checking
                Jan 15 17:15:37 2021-01-15 10:15:37,482 INFO RPC interface 'supervisor' initialized
                Jan 15 17:15:37 2021-01-15 10:15:37,485 CRIT Server 'unix_http_server' running without any HTTP authentication checking
                Jan 15 17:15:37 2021-01-15 10:15:37,485 INFO supervisord started with pid 1
                Jan 15 17:15:38 2021-01-15 10:15:38,488 INFO spawned: 'postgresql' with pid 37
                Jan 15 17:15:38 2021-01-15 10:15:38,490 INFO spawned: 'postgresql-service' with pid 38
                Jan 15 17:15:38 2021-01-15 10:15:38.598 UTC [37] LOG: listening on IPv4 address "0.0.0.0", port 5432
                Jan 15 17:15:38 2021-01-15 10:15:38.606 UTC [37] LOG: listening on IPv6 address "::", port 5432
                Jan 15 17:15:38 2021-01-15 10:15:38.610 UTC [37] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
                Jan 15 17:15:38 2021-01-15 10:15:38.785 UTC [45] LOG: database system was shut down at 2021-01-15 10:15:35 UTC
                Jan 15 17:15:38 2021-01-15 10:15:38.817 UTC [37] LOG: database system is ready to accept connections
                Jan 15 17:15:39 Postgresql service endpoint listening on https://:::3000
                Jan 15 17:15:40 2021-01-15 10:15:40,459 INFO success: postgresql entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
                Jan 15 17:15:40 2021-01-15 10:15:40,459 INFO success: postgresql-service entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
                Jan 15 21:15:56 [POST] /databases
                Jan 15 21:18:54 [POST] /databases
                Jan 16 06:45:34 [POST] /databases
                Jan 16 06:46:12 [GET] /healthcheck
                  So where and when do those error logs initially posted appear then?
                    JOduMonTJ Offline
                    JOduMonTJ Offline
                    JOduMonT
                    In PostgreSQL, the January 14, probably while I was messing with my CIFS
                      @jodumont Actually I meant the original error logs from Nextcloud or are those gone by now and the issue somehow resolved? Asking since apparently then it was not related to the add-missing-primary-keys command?
                        amg-webA Offline
                        amg-webA Offline
                        amg-web
                        into developer mode
                        I could not find how to put app into developer mode
                        Can you tell me? I have same issue in DB
                        • amg-webA amg-web
                          into developer mode
                          @amg-web I mean the recovery mode, which you can enable for the app in the "Repair" section on the app configure view in the Cloudron dashboard.
