  2. Pixelfed
  3. Direct messages no longer work
Scheduled Pinned Locked Moved Pixelfed
37 Posts 6 Posters 14.0k Views 6 Watching
    @onlybro Yes, I will try to debug this a bit later this week.
    O
    O
    onlybro
    wrote on last edited by onlybro
    #21
    @girish
    Like counts of image post are also not visible you can try my site like counts don’t work on iPhone behavior that can be produced is
    Here’s my site https://spacemag.xyz
    I have to like the post to see the count if someone else had liked it I cannot view it and even then if I like it and view most of the time I can only see my name on it it’s very rare I see the total profiles of those who had liked.
    This moreover seems to be a conflict with ui or java from cloudron I guess ? It all works fine at pixelfed.social though, which is a raw installation of pixelfed.
    I’m not certain but all i can say is there is something that’s not right
    • O onlybro
      @girish
      @onlybro It seems there is also a staging branch - https://github.com/pixelfed/pixelfed/commits/staging . Let me check if it helps if I update to that branch
        Latest dev seems to throw an exception with direct messages.
        17:25:36 - [2021-05-11 00:25:36] production.ERROR: Trying to get property 'private_key' of non-object {"userId":1,"exception":"[object] (ErrorException(code: 0): Trying to get property 'private_key' of non-object at /app/code/app/Util/ActivityPub/HttpSignature.php:40)
        17:25:36 - [stacktrace]
        17:25:36 - #0 /app/code/app/Util/ActivityPub/HttpSignature.php(40): Illuminate\\Foundation\\Bootstrap\\HandleExceptions->handleError()
        17:25:36 - #1 /app/code/vendor/laravel/framework/src/Illuminate/Cache/Repository.php(420): App\\Util\\ActivityPub\\HttpSignature::App\\Util\\ActivityPub\\{closure}()
        17:25:36 - #2 /app/code/vendor/laravel/framework/src/Illuminate/Cache/CacheManager.php(418): Illuminate\\Cache\\Repository->rememberForever()
        17:25:36 - #3 /app/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\\Cache\\CacheManager->__call()
        17:25:36 - #4 /app/code/app/Util/ActivityPub/HttpSignature.php(41): Illuminate\\Support\\Facades\\Facade::__callStatic()
        17:25:36 - #5 /app/code/app/Services/ActivityPubFetchService.php(20): App\\Util\\ActivityPub\\HttpSignature::instanceActorSign()
        17:25:36 - #6 /app/code/app/Util/ActivityPub/Helpers.php(230): App\\Services\\ActivityPubFetchService::get()
        17:25:36 - #7 /app/code/vendor/laravel/framework/src/Illuminate/Cache/Repository.php(385): App\\Util\\ActivityPub\\Helpers::App\\Util\\ActivityPub\\{closure}()
        17:25:36 - #8 /app/code/vendor/laravel/framework/src/Illuminate/Cache/CacheManager.php(418): Illuminate\\Cache\\Repository->remember()
        17:25:36 - #9 /app/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\\Cache\\CacheManager->__call()
        17:25:36 - #10 /app/code/app/Util/ActivityPub/Helpers.php(237): Illuminate\\Support\\Facades\\Facade::__callStatic()
        17:25:36 - #11 /app/code/app/Util/ActivityPub/Helpers.php(242): App\\Util\\ActivityPub\\Helpers::fetchFromUrl()
        17:25:36 - #12 /app/code/app/Util/ActivityPub/Helpers.php(474): App\\Util\\ActivityPub\\Helpers::fetchProfileFromUrl()
        17:25:36 - #13 /app/code/vendor/laravel/framework/src/Illuminate/Cache/Repository.php(385): App\\Util\\ActivityPub\\Helpers::App\\Util\\ActivityPub\\{closure}()
        17:25:36 - #14 /app/code/vendor/laravel/framework/src/Illuminate/Cache/CacheManager.php(418): Illuminate\\Cache\\Repository->remember()
        17:25:36 - #15 /app/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\\Cache\\CacheManager->__call()
        17:25:36 - #16 /app/code/app/Util/ActivityPub/Helpers.php(536): Illuminate\\Support\\Facades\\Facade::__callStatic()
        17:25:36 - #17 /app/code/app/Util/ActivityPub/Helpers.php(542): App\\Util\\ActivityPub\\Helpers::profileFirstOrNew()
        17:25:36 - #18 /app/code/app/Services/WebfingerService.php(40): App\\Util\\ActivityPub\\Helpers::profileFetch()
        17:25:36 - #19 /app/code/app/Services/WebfingerService.php(20): App\\Services\\WebfingerService->run()
        17:25:36 - #20 /app/code/app/Http/Controllers/DirectMessageController.php(608): App\\Services\\WebfingerService::lookup()
        17:25:36 - #21 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\\Http\\Controllers\\DirectMessageController->composeLookup()
        17:25:36 - #22 /app/code/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\\Routing\\Controller->callAction()
        17:25:36 - #23 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Route.php(254): Illuminate\\Routing\\ControllerDispatcher->dispatch()
        17:25:36 - #24 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Route.php(197): Illuminate\\Routing\\Route->runController()
        17:25:36 - #25 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Router.php(695): Illuminate\\Routing\\Route->run()
        17:25:36 - #26 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()
        17:25:36 - #27 /app/code/app/Http/Middleware/AccountInterstitial.php(42): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #28 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\AccountInterstitial->handle()
        17:25:36 - #29 /app/code/app/Http/Middleware/Localization.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #30 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\Localization->handle()
        17:25:36 - #31 /app/code/app/Http/Middleware/TwoFactorAuth.php(33): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #32 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\TwoFactorAuth->handle()
        17:25:36 - #33 /app/code/app/Http/Middleware/EmailVerificationCheck.php(34): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #34 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\EmailVerificationCheck->handle()
        17:25:36 - #35 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #36 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
        17:25:36 - #37 /app/code/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(44): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #38 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Auth\\Middleware\\Authenticate->handle()
        17:25:36 - #39 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #40 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\VerifyCsrfToken->handle()
        17:25:36 - #41 /app/code/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #42 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\View\\Middleware\\ShareErrorsFromSession->handle()
        17:25:36 - #43 /app/code/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #44 /app/code/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\\Session\\Middleware\\StartSession->handleStatefulRequest()
        17:25:36 - #45 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Session\\Middleware\\StartSession->handle()
        17:25:36 - #46 /app/code/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #47 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Cookie\\Middleware\\AddQueuedCookiesToResponse->handle()
        17:25:36 - #48 /app/code/app/Http/Middleware/FrameGuard.php(18): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #49 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): App\\Http\\Middleware\\FrameGuard->handle()
        17:25:36 - #50 /app/code/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #51 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Cookie\\Middleware\\EncryptCookies->handle()
        17:25:36 - #52 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #53 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Router.php(697): Illuminate\\Pipeline\\Pipeline->then()
        17:25:36 - #54 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Router.php(672): Illuminate\\Routing\\Router->runRouteWithinStack()
        17:25:36 - #55 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Router.php(636): Illuminate\\Routing\\Router->runRoute()
        17:25:36 - #56 /app/code/vendor/laravel/framework/src/Illuminate/Routing/Router.php(625): Illuminate\\Routing\\Router->dispatchToRoute()
        17:25:36 - #57 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(166): Illuminate\\Routing\\Router->dispatch()
        17:25:36 - #58 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(128): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()
        17:25:36 - #59 /app/code/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #60 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Fideloper\\Proxy\\TrustProxies->handle()
        17:25:36 - #61 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #62 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
        17:25:36 - #63 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull->handle()
        17:25:36 - #64 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #65 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
        17:25:36 - #66 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
        17:25:36 - #67 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #68 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()
        17:25:36 - #69 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #70 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(167): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()
        17:25:36 - #71 /app/code/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(103): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
        17:25:36 - #72 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(141): Illuminate\\Pipeline\\Pipeline->then()
        17:25:36 - #73 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
        17:25:36 - #74 /app/code/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle()
        17:25:36 - #75 {main}
        17:25:36 - "}
          Actually, direct messages don't work for me in https://pixelfed.social/account/direct anymore either. It just keeps spinning.
            Reported here - https://github.com/pixelfed/pixelfed/issues/2752 . @onlybro I will stop debugging since I don't think I can do anything to fix this without having a stable release where DM is known to work. You will have to reach out to the upstream author.
            O 3 Replies Last reply
              O
              O
              onlybro
              #26
              @girish
              Reporting from GitHub
              I was able to reproduce the direct message issue within a docker container, and I think I know why it is happening.
              Line
              https://github.com/pixelfed/pixelfed/blob/4ad3de3b885b8d21a53ca9cc8a4a83e2a1d4a459/app/Http/Controllers/AccountController.php#L129-L132
              in the account controller, the following SQL query is generated:
              [2021-05-10 21:41:58] local.DEBUG: array (
              0 =>
              array (
              'query' => 'select * from profiles where id != ? and profiles.id = ? and profiles.deleted_at is null limit 1',
              'bindings' =>
              array (
              0 => 297440899045134336,
              1 => '297465207490482176',
              'time' => 37.91,
              As you can see, the id in the URL gets treated as string and that's why the query does not return any results.
                O
                O
                onlybro
                @girish
                Direct messages does work to me when I login to pixelfed.social site without any issues.
                  O
                  O
                  onlybro
                  @girish
                  In these lines in the account controller, the following SQL query is generated:
                  0 =>
                  array (
                  'bindings' =>
                  array (
                  'time' => 37.91,
                  I made a preliminary patch on this branch with int casts wherever necessary and it resolves the issue locally, but there must be some sort of underlying issue that needs to be investigated to tell why this stopped working
                  O 1 Reply Last reply
                  • O onlybro
                    @girish
                    0 =>
                    array (
                    'bindings' =>
                    array (
                    'time' => 37.91,
                    O
                    O
                    onlybro
                    @girish
                    Following is the GitHub link
                    https://github.com/pixelfed/pixelfed/issues/2729#issuecomment-837986008
                    • O onlybro
                      @girish
                      @onlybro let's continue there. I have replied on GitHub.
                      O 2 Replies Last reply
                        O
                        O
                        onlybro
                        #31
                        @girish
                        Could you please update the pixelfed app to latest Daniel has updated to version 0.11.0 when I check for updates on dashboard it doesn’t do anything it still shows 0.10.0 as the latest
                          O
                          O
                          onlybro
                          #32
                          @girish
                          Please take a look
                          https://github.com/pixelfed/pixelfed/issues/2752#
                          And the following
                          https://github.com/pixelfed/pixelfed/commit/2d0a253e071280c692b14516a6aac8d6c33c44d5
                          Daniel informed that he is using MySQL however the issue of sending messsges yet persists it’s still there not able to send messages yet
                          • O
                            O
                            onlybro
                            as per the developer this seems to be a issue with configuration
                            https://pasteboard.co/Kj1NAaR.jpg
                            @girish @nebulon
                            Please assist with this it has been months and months now haven’t beeen able to get messaging working on pixelfed yet
                            • O onlybro
                              @girish @nebulon
                              @onlybro Is the situation any better with the 1.6.1 package?
                              • O
                                O
                                owlgeek
                                Hi, I've the same problem with a docker installation of Pixelfed v0.11.1.
                                Someone have news?
                                • archosA
                                  archosA
                                  archos
                                  Hi, I have the same problem, private messages won't open. Attached is a screenshot.pixelfed_message.png
                                    A Former User
                                    This happens on my instance as well 😞
