  2. Jirafeau
  3. Upload speed ?
Upload speed ?
Scheduled Pinned Locked Moved Solved Jirafeau
9 Posts 4 Posters 4.1k Views 4 Watching
  • rmdesR Offline
    rmdesR Offline
    rmdes
    wrote on last edited by rmdes
    What's your upload speed ?
    I can't upload anything above 1MB, it doesnt go beyond 501 KB/s
    so it takes hours and hours, even just to upload 1GB (often fails before completion)
    edit: when I test my speed from the file manager, I can upload just fine, more MB's in a few second than using the app, I'm wondering what's going on..
    Also often Jirafeau even go on negative upload speed, like -323245554545 KB/s
    is anyone else having this ?
    d19dotcaD 1 Reply Last reply
    • rmdesR rmdes
      d19dotcaD Offline
      d19dotcaD Offline
      d19dotca
      @rmdes Funny enough I had one client testing it have that experience where the file they uploaded basically never completed, but I could never reproduce the issue. Been using it occasionally without issues here so far myself, but my client did have one bad experience with it.
      Dustin Dauncey
      www.d19.ca
        I'm assuming you have looked at the config file to enable greater limits, etc?
        rmdesR 1 Reply Last reply
          rmdesR Offline
          rmdesR Offline
          rmdes
          @robi Hmm not really, have not seen any params I can tweak..perhaps I'm not looking where I should...:/
          rmdesR robiR 2 Replies Last reply
          • rmdesR rmdes
            rmdesR Offline
            rmdesR Offline
            rmdes
            Here https://github.com/Newlode/jirafeau/blob/master/lib/config.original.php
            I don't see any parameters that can be used regarding upload speed.
            • rmdesR rmdes
              @rmdes try the same on my instance? up dot toldyouso dot com.
                rmdesR Offline
                rmdesR Offline
                rmdes
                @robi this is still up for testing ?
                • rmdesR rmdes
                  rmdesR Offline
                  rmdesR Offline
                  rmdes
                  I think I managed to find what's the issue : domain with this app is behind cloudflare, for some reaon this is messing up the upload, I did a test on another domain, without cloudflare, and the upload goes just fine !
                  • rmdesR rmdes
                    @rmdes fyi re Cloudflare https://git.nixnet.services/you/stop_cloudflare
