  3. How to change domain from Wildcard to Gandi LiveDNS using Cloudron CLI?
domainsgandi
5 Posts 3 Posters 2.3k Views 3 Watching
  • jdaviescoatesJ Online
    I've been a bit silly and moved my Dashboard Domain from one registrar to another without thinking about it properly and I now can't access my Dashboard.
    Is there was a way to change the domain from Wildcard to Gandi LiveDNS using Cloudron CLI?
    BTW, I just installed Cloudron CLI and got these warnings and errors:
    code_tjosef@josef-ThinkPad-T510:~$ sudo npm install -g cloudron
    [sudo] password for josef:
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code EINTEGRITY
    npm ERR! sha512-sGkPx+VjMtmA6MX27oA4FBFELFCZZ4S4XqeGOXCv68tT+jb3vk/RyaKWP0PTKyWtmLSM0b+adUTEvbs1PEaH2w== integrity checksum failed when using sha512: wanted sha512-sGkPx+VjMtmA6MX27oA4FBFELFCZZ4S4XqeGOXCv68tT+jb3vk/RyaKWP0PTKyWtmLSM0b+adUTEvbs1PEaH2w== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    /usr/local/bin/cloudron -> /usr/local/lib/node_modules/cloudron/bin/cloudron
    npm WARN notsup Unsupported engine for open@8.2.1: wanted: {"node":">=12"} (current: {"node":"10.19.0","npm":"6.14.4"})
    npm WARN notsup Not compatible with your version of node/npm: open@8.2.1
    + cloudron@4.12.1
    added 12 packages from 10 contributors, removed 3 packages and updated 32 packages in 15.582s
    npm ERR! Callback called more than once.
    npm ERR! A complete log of this run can be found in:
    npm ERR!     /root/.npm/_logs/2021-06-21T13_30_50_897Z-debug.log
    ext
      + cloudron@4.12.1
      ext
      BrutalBirdieB Offline
      @jdaviescoates good question.
      My first initial thought was: "Can I do the initial DNS setup again in this case?"
      https://docs.cloudron.io/api.html#tag/Cloudron/paths/~1cloudron~1setup/post
      Maybe this can be done / fixed via the API?
      This solution is not user friendly tho and requires to have a API Key setup prior doing something wrong.
      curl -k -X POST -H 'Content-Type: application/json' --data '{"dnsConfig": {"provider":"gandi", "domain": "your.domain.tld", "config": "??? gandi specific config ???"}}' https://{HOST.NAME}/api/v1/cloudron/setup?access_token={$TOKEN}
      This is just what I hacked together without testing!
      • BrutalBirdieB BrutalBirdie
        @brutalbirdie thanks, in the end I was able to change it to Gandi LiveDNS within Gandi and then I edited my /etc/hosts/ to be albe to access my dashboard and then once in there edited the domain to change from Wildcard to Gandi LiveDNS and now I think I'm sorted 🙂
          @jdaviescoates That is also a solution 😄
          Good to read.
            The CLI has indeed no way to edit domains. What you did is the correct approach - make the dashboard available via the browser and then edit from the Domains view.
            (As for the CLI warnings, looks like we have to replace request module with superagent. Sigh, we actually used to use superagent before...)
