  3. how to reset 2fa for admin?
2fa
9 Posts 4 Posters 3.3k Views 4 Watching
  • potemkin_aiP Offline
    potemkin_ai
    Hello! Documentation says admin can reset 2FA for the user; but how admin's 2FA be reset, if, let's say, he lost his device?
    • potemkin_aiP potemkin_ai
      BrutalBirdieB Offline
      @potemkin_ai I just did a little hacking to see if I could do that from the command line.
      ssh into your server, get root access.
      mysql -uroot -ppassword -e "select username, email, resetToken, twoFactorAuthenticationSecret, twoFactorAuthenticationEnabled from box.users";
      | username         | email                  | resetToken                                                       | twoFactorAuthenticationSecret                        | twoFactorAuthenticationEnabled |
      | t.test           | test@domain.tld        |        | REDACTED                                             |           1                    |
      Then I disable it via mysql:
      mysql -uroot -ppassword -e "UPDATE box.users set twoFactorAuthenticationEnabled=0 where username='t.test'";
      De Nada
      BrutalBirdieB potemkin_aiP 2 Replies Last reply
      • BrutalBirdieB BrutalBirdie
        De Nada
        @brutalbirdie
        I might be possible to do this via api.
        https://my.domain.tld/api/v1/profile/twofactorauthentication_disable
        {"password":"TheUsersPassword"}
        Testing right now.
        Nah this wont work, you need an active user session for this api call as far as I can tell.
        the top solution is working fine.
        potemkin_aiP 1 Reply Last reply
          De Nada
          potemkin_ai
          @brutalbirdie thanks a lot!!
            @brutalbirdie
            Testing right now.
            potemkin_ai
            @brutalbirdie thanks for trying a few options!
              @BrutalBirdie is correct, setting the twoFactorAuthenticationEnabled database field for that user to 0 will remove the 2fa for that user. The next release will have a button for admins to do this from the dashboard.
                potemkin_ai
                @nebulon thanks; how can admin reset 2FA if he can't login to the dashboard?
                  @potemkin_ai It's documented in a different section at https://docs.cloudron.io/user-management/#admins . But easiest way is to just SSH and run cloudron-support --owner-login . This will give you a temporary username/password to login with. Can only be used to login once. This password will bypass any 2FA.
                  I will fix the docs.
                    potemkin_ai
                    @girish thanks a lot, that sounds just right
