Problems with 1.14.3 ?
My Freshrss instance has been working fine.
This morning it has lost most of its feeds.
They exist in subscription management
But they do not display in the main stream.
I check backups and noticed yesterday's backup was 1.14.2 and last night's backup was 1.14.3
I restored the latest 1.14.2 backup and the feeds are back again in the main stream.Does this indicate a problem with 1.14.3 ?
can you maybe clone the app and perform another update on the cloned instance? Lets see if this can be reproduced so we can debug that.
@nebulon I decided not to clone immediately, but restart the app as a first step.
And then I discovered that actually feeds ARE there.
It seems feeds with no unread do not show UNLESS you click on favourites EVEN IF feed is marked to in Main Stream
Maybe it's a "feature" I wasn't aware of.
Also complicated that some feeds are coming out from mynitterapp, and there was a breaking change recently, so had to fix that.
I think probably best to put this downE30error (error 30 cm away from keyboard ==> user)
Still have problem with one feed but other are working and showing, once the (in my opinion) UI glitch is understood.
So I will close this.
Thanks for reviewing it.
