  3. CAPTCHA options for Cloudron Applications
captchacloudron
21 Posts 6 Posters 8.6k Views 5 Watching
  • L Offline
    L Offline
    CAPTCHA (Completely Automated Public Turing tests) are used to detect whether the user is human. Unfortunately, proprietary solutions are being used to collect biometric data which can be used to fingerprint visitors.
    We should look around for some Freedom respecting options which are not troublesome.
    If you have some ideas, suggestions, resources etc. please add them to this thread.
    For example, here is a survey of Free Software options for 2022:
    https://fixthephoto.com/best-free-captcha-sources.html
    L ei8fdbE 2 Replies Last reply
    • archosA archos
      Hi, I would like to thank Cloudron Support for helping me with the Matrix app. Despite my poor English, they were patient with me. Classically, it was a problem between the chair and the keyboard. And all you had to do was read the release notes, add captcha verification to the file. A matter of minutes. The update went through today without a problem. So thank you again for your help. I'm happy to use Cloudron.
      L Offline
      L Offline
      @archos
      CAPTCHAs (Completely Automated Public Turing test) are being used to harvest biometric data to fingerprint people and relay results to Big Data corporations. It is insidious and we need to find a humane, Freedom respecting way of achieving the same outcome and try and support it.
      For example,
      https://friendlycaptcha.com/
      There are others, but ... busy...
        There's also hcaptcha.com
        L 1 Reply Last reply
          L Offline
          L Offline
          @robi hCaptcha is proprietary, I seem to remember.
          A while back I investigated Free alternatives.
          There was one where you tell the time on the clock. I must look again.
            Mini Doom game captcha, OSS
            https://vivirenremoto.github.io/doomcaptcha/
            L 2 Replies Last reply
              L Offline
              L Offline
              @robi Hahaa! 😂
              That is the funniest thing! Easily the best Captcha!
                L Offline
                L Offline
                @robi
                https://www.hcaptcha.com/post/why-captchas-will-be-with-us-always
                • L LoudLemur
                  L Offline
                  L Offline
                  @LoudLemur
                  Why CAPTCHAs are considered harmful:
                  https://ezinearticles.com/?Captchas-Considered-Harmful---Why-Captchas-Are-Bad-And-How-You-Can-Do-Better&id=1104207
                  W3
                  https://www.w3.org/WAI/GL/wiki/Captcha_Alternatives_and_thoughts
                  Human Presence (proprietary)
                  https://www.humanpresence.io/
                  Visual Captcha (abandoned, i think)
                  https://visualcaptcha.net/demo/#
                  Captchas.net (good candidate?)
                  http://captchas.net/
                  FriendlyCaptcha
                  SecurImage
                  https://www.phpcaptcha.org/
                  Hcaptcha
                  https://www.hcaptcha.com/#plans
                  svgCAPTCHA (from MIT)
                  https://openbase.com/js/svg-captcha
                  necrevistonnezrN L 2 Replies Last reply
                  • L LoudLemur
                    @LoudLemur
                    W3
                    FriendlyCaptcha
                    SecurImage
                    Hcaptcha
                    necrevistonnezrN Offline
                    @LoudLemur BTW Vaultwarden / Bitwarden has captcha built-in (appears after 5 unsuccessful login attempts)
                    • L LoudLemur
                      ei8fdbE Offline
                      ei8fdbE Offline
                      ei8fdb
                      wrote on last edited by ei8fdb
                      @LoudLemur said in CAPTCHA options for Cloudron Applications:
                      I agree with your motivation to find freedom respect login protections.
                      However the majority of captchas are not accessible - meaning any human with a visual impairment will not be able to log in to a system.
                      Multi-factor auth. is already configurable on Cloudron. In my view that is a suitable alternative, while also improving user security.
                      What is the problem you're trying to solve with a captcha?
                      • ei8fdbE ei8fdb
                        @ei8fdb said in CAPTCHA options for Cloudron Applications:
                        Usually it’s a form of rate limiting - preventing too many login attempts from a malicious actor which uses different IPs
                        ei8fdbE 1 Reply Last reply
                          ei8fdbE Offline
                          ei8fdbE Offline
                          ei8fdb
                          @necrevistonnezr said in CAPTCHA options for Cloudron Applications:
                          Yep, I thought the same but then remembered Cloudron already has rate limiting via fail2ban. I don't know (and haven't tested) if it is enabled on login page of each application hosted on an instance.
                          Is there a reason why it wouldn't address the many login attempts from different IPs use case?
                          • L LoudLemur
                            @LoudLemur
                            W3
                            FriendlyCaptcha
                            SecurImage
                            Hcaptcha
                            L Offline
                            L Offline
                            @LoudLemur Google reCAPTCHA destroying the internet:
                            https://github.com/google/recaptcha/issues/296
                              We have been using hcaptcha for cloudron.io for a while now. Seems to work quite well.
                                Currently we use hcaptcha for this forum with limited success, however given that the remaining spam we get is usually handcrafted, those are likely real users.
                                Also we use it for https://console.cloudron.io now and that seems to work well.
                                • L Offline
                                  L Offline
                                  On a podcast recently, I heard that one thing CAPTCHAs do "to identify you as a human" is use your click on the square with the ... as a permission to check your browsers recent website history on the other tabs too. I didn't check this but wouldn't be surprised.
                                    Turnstile FREE for all.
                                    https://blog.cloudflare.com/turnstile-ga/
                                    @girish see if it makes a difference for the forum
                                      L Offline
                                      L Offline
                                      @robi said in CAPTCHA options for Cloudron Applications:
                                      When Cloudflare use free, they mean free as in beer, not Free as in Freedom, I think. While turnstile might appear a relief, Cloudflare is a centralizing force on the internet, and I feel Turnstile could easily be used to gatekeep access to the internet. Cloudflare have been involved in censorship before and I suspect they might want to be able to do so again. They might start saying that "unusual traffic" was associated with somebody's address or something like that.
                                      I wish something like this were available without needing to be a Cloudflare service, something we could run ourselves.
                                        Actually they are preventing more censorship, compared to all the blocking corps and govts are doing, eroding your freedoms.
                                        Beware the gaslighting.
                                          L Offline
                                          L Offline
                                          I hope you are right, @robi, and you might be, but I think that either governments are using corporations to do their dirty work, like censorship, for them, or those who own the corporations have used their power and influence to subvert governments through lobbying, etc. I think one of the ways they operate is to introduce something that seems beneficial and helpful so that it becomes accepted and widespread. Then the fangs come out and the horrible stuff begins, like censorship.
