  2. PeerTube
  3. Peertube and S3/Minio Objectstorage
Scheduled Pinned Locked Moved PeerTube
41 Posts 8 Posters 15.8k Views 9 Watching
  • A awnzky
    @scooke
    iam already try using contabo. it's does not work. contabo not support virtual host style, sorry for my bad english.
    its my working config. insert after storage section.
    if have an error you can check the logs from peertube administration. make sure minio support virtual host style requests
    https://github.com/Chocobozzz/PeerTube/issues/4455
    example vhost style like this : yourbucket.sin1.contabostorage.com
    path style : sin1.contabostorage.com/a808f6dce2514fba8eeb68596724ddd1:yourbucket
    object_storage:
      enabled: true
      # Without protocol, will default to HTTPS
      endpoint: 'e4u6.la11.idrivee2-5.com' # 's3.amazonaws.com' or 's3.fr-par.scw.cloud' for example
      region: 'us-la'
      # Set this ACL on each uploaded object
      upload_acl: ''
      credentials:
        # You can also use AWS_ACCESS_KEY_ID env variable
        access_key_id: 'secret'
        # You can also use AWS_SECRET_ACCESS_KEY env variable
        secret_access_key: 'secret'
      # Maximum amount to upload in one request to object storage
      max_upload_part: 2GB
      streaming_playlists:
        bucket_name: 'peertube'
        # Allows setting all buckets to the same value but with a different prefix
        prefix: 'streaming-playlists/' # Example: 'streaming-playlists:'
        # Base url for object URL generation, scheme and host will be replaced by this URL
        # Useful when you want to use a CDN/external proxy
        base_url: 'https://peertube.e4u6.la11.idrivee2-5.com' # Example: ''
      # Same settings but for webtorrent videos
      videos:
        prefix: 'videos/'
    #21
    @awnzky said in Peertube and S3/Minio Objectstorage:
    Wish I'd read/ seen this earlier. I just spent hours pulling my hair trying to get contabo object storage to work with peertube but I just couldn't get it to work either 😞 (whereas on Scaleway it Just Worked - and even when it didn't work, like when I hadn't set the region, it gave useful error messages telling me what was wrong and how to fix it 👍 )
    However, even with the S3 connection to my Scaleway object buckets working fine, playback actually just didn't work 😞
    Playback with Object Storage disabled works fine.
    I don't have any base_url set anywhere.
      @jdaviescoates playback may require the bucket to be https accessible, which is a setting.
      Frequency tech
        @robi said in Peertube and S3/Minio Objectstorage:
        You mean making the bucket public? Already is. Can't find any other settings related to https.
        scookeS 1 Reply Last reply
          scookeS
          scookeS
          scooke
          @jdaviescoates I wonder if the problem is the TYPE of bucket. In the comments above I was running a self-installed instance of Minio. That is, I didn't use Yunohost, or CapRover, or Cloudron, etc. I installed it by hand. Somehow (I guess I could figure it out by rereading the above) I set Minio up to use virtual-host, rather than path-style. And for whatever reason, Peertube (only) works with virtual-host style. Maybe this has something to do with it?
          FWIW (I'm only getting my own head sort of around all this), the end_point in teh config has to be whatever your API enpoint is. Off the top of my head, I forget how to tell which is which, but one address is the home adress, and the other is the end point address. That is to say, when it is being installed on mino.example.com, a second API address is created, something like minio-s3.example.com. The API is the address needed.
          • scookeS scooke
            @scooke said in Peertube and S3/Minio Objectstorage:
            That's why Contabo didn't work, I think.
            But Scaleway does support that and did work in that the files get transferred to the bucket fine. It's just that then playback basically doesn't work at all.
              scookeS
              scookeS
              scooke
              @jdaviescoates Care to share your config (the pertinent part)?
              • scookeS scooke
                @scooke
                # Store all videos in one bucket on Scaleway
                object_storage:
                  enabled: true
                  # Scaleway endpoint
                  endpoint: 's3.fr-par.scw.cloud'
                  region: 'fr-par'
                  videos:
                    bucket_name: 'bridport-tv'
                    prefix: 'videos/'
                  # Use the same bucket as for webtorrent videos but with a different prefix
                  credentials:
                    access_key_id: 'xxxxx'
                    secret_access_key: 'xxxxx'
                That's was working fine for getting stuff into the bucket, but then videos didn't actually play
                Bucket is also public:
                  @scooke
                  object_storage:
                    enabled: true
                    # Scaleway endpoint
                    region: 'fr-par'
                    videos:
                      prefix: 'videos/'
                    credentials:
                  @jdaviescoates if you get a public link, does it play in the browser?
                  compare that to the link the app tries to use?
                  Frequency tech
                  jdaviescoatesJ 2 Replies Last reply
                    Yes
                      Looking for that I spotted this:
                      CORS Missing Allowed Origin
                      I guess that's likely the problem...
                      (man, it's SO much easier doing this stuff when I'm not both freezing cold and way too tired! /me reminds himself, again, to get more f-ing sleep and go to bed on f-ing time!)
                        Woohoo! 😄
                        So, after following this guide:
                        https://www.scaleway.com/en/docs/storage/object/api-cli/object-storage-aws-cli/
                        And then this guide:
                        https://www.scaleway.com/en/docs/storage/object/api-cli/setting-cors-rules/
                        I now have videos stored on S3 that ALSO play! 😄
                        https://bridport.tv/w/hCegSC1b9YGW5hAgbQbFcE
                          Woohoo! 😄
                          #32
                          Scaleway are great. Good prices, great docs!
                          I was tempted by special offer Contabo pricing, but unlike Scaleway they aren't 100% renewably powered (although their German based stuff when I'd bought some object storage is), and their docs are crap.
                          So looks like I'll just ditch Contabo and stick with using Scaleway for my Object Storage needs.
                          • S
                            S
                            SamGreenwood
                            anyone done this on Linode?
                            • scookeS scooke
                              I recently discovered how to host media from my Cloudron-hosted Mastodon instance on my Minio instance (non-Cloudron), and it works great. So I started exploring what else I can use my Minio storage for, and found a plugin for Wordpress, , that also works well. So now, I'm trying to see how to use it for Peertube, which apparently can use objectstorage. I've found the following links with sample yaml files, but I haven't been able to get it working on my own Cloudron-hosted Peertube instance. Has anyone else had success?
                              https://docs.joinpeertube.org/admin-remote-storage
                              https://framacolibri.org/t/redundancy-videos-not-able-to-use-object-storage/14668
                              https://github.com/Chocobozzz/PeerTube/blob/develop/support/docker/production/config/custom-environment-variables.yaml#L24
                              https://github.com/Chocobozzz/PeerTube/blob/develop/config/production.yaml.example
                              https://github.com/Chocobozzz/PeerTube/blob/develop/support/docker/production/config/production.yaml
                              https://framagit.org/framasoft/peertube/PeerTube/-/blob/c342726ad4ccbb90b8ff29f1cc1c89f9f7e8d98f/config/production.yaml.example
                              #34
                              @scooke Thanks for asking this question. I might try this using block storage with Wasabi and PeerTube.
                              Why is object storage suitable for this task? Isn't object storage better for keeping gigantic files? I suppose a considerable archive of videos would end up needing a large amount of storage, but they would all be separate files.
                              • L LoudLemur
                                @LoudLemur said in Peertube and S3/Minio Objectstorage:
                                Video files are relatively large files.
                                But aside from that, often VPS servers don't come with much disk space and so Object Storage is just one relatively cheap way of increasing the amount of storage you have.
                                Wasabi
                                Lots of people on here seem to have moved away from them for various reasons.
                                The cheapest out there seems to be iDrive e2 who have a 90% off offer which makes it insanely cheap for the first year (and pretty good value after that):
                                https://www.idrive.com/e2/
                                Personally I use Scaleway who are also good value and 100% powered by renewable energy
                                I've got all my instances of Peertube, Mastodon, and Pixelfed all storing their data on Scaleway Object Storage.
                                L 1 Reply Last reply
                                  Wasabi
                                  @jdaviescoates You are so good to me!
                                  Thank you. I shall look into those.
                                  • benborgesB
                                    benborgesB
                                    benborges
                                    wrote on last edited by benborges
                                    #37
                                    I'm wondering if there is a path to do this with Peertube + Hetzner storage box or if the S3 Storage objects way is the only way to store peertube video content outside the cloudron, anyone tried ?
                                    edit : Hmm apparently, the answer is no, only S3 is supported : https://docs.joinpeertube.org/maintain/remote-storage#migrate-to-another-object-storage-provider
                                    BenB
                                    • benborgesB benborges
                                      @benborges said in Peertube and S3/Minio Objectstorage:
                                      You might be able to mount a Volume and then use that for the data directory? 🤷
                                      benborgesB 1 Reply Last reply
                                        benborgesB
                                        benborgesB
                                        benborges
                                        #39
                                        @jdaviescoates Tried that but I have this error then :
                                        it does the same for CIFS volumes
                                        BenB
                                          @benborges yeah, as it states in the data directory docs:
                                          cifs and sshfs volumes are unsuitable as an app's data directory as they do not support file permissions and ownership. mountpoint and nfs volumes may or may not work depending on the destination filesystem.
