  2. Jitsi
  3. No sound in Jitsi...
Scheduled Pinned Locked Moved Solved Jitsi
49 Posts 6 Posters 29.0k Views 6 Watching
  • potemkin_aiP
    potemkin_aiP
    potemkin_ai
    @girish , I understand this topic is marked as solved and might fall out of sight - so I'm wondering if there are any updates on that?
    • potemkin_aiP
      potemkin_aiP
      potemkin_ai
      @girish , I understand there are no updates?
      • potemkin_aiP potemkin_ai referenced this topic on
        @potemkin_ai No updates. We can't reproduce this and I am not sure what we can do to debug this further.
        potemkin_aiP 1 Reply Last reply
          potemkin_aiP
          potemkin_aiP
          potemkin_ai
          @girish right... but if felt like you found something to check (https://forum.cloudron.io/post/55044) - from what I understand, it won't hurt at least?
            @opensourced Think we found a few variables that we can set in Jitsi (that the package currently does not set). We will release a new package shortly with the changes.
            potemkin_aiP
            potemkin_aiP
            potemkin_ai
            @girish is there any way I can add those variables persistently just on my instance, to verify if they solve the issue and to make sure it doesn't brake anything?
            If that would work, I would revert back to you and you will only need to merge them into the source tree and everyone would be happy.
            How does it sound?
            I really hate having separate machine just for Jitsi.
            • potemkin_aiP
              potemkin_aiP
              potemkin_ai
              Raising this up, in case it got lost.
                @potemkin_ai We are still reworking the package (the package has fallen a bit behind since we couldn't figure how to update with ubuntu 22). Will pick this up next week.
                  potemkin_aiP
                  potemkin_aiP
                  potemkin_ai
                  @girish thank you! Keep fingers crossed, I really need Jitsi working on Cloudron 🤞
                  • potemkin_aiP
                    potemkin_aiP
                    potemkin_ai
                    btw, the script I'm using requires Ubuntu 20.04 LTS, guess there might be a reason for that...
