  3. running command inside container
exec
7 Posts 4 Posters 3.2k Views 4 Watching
  • P
    P
    perler
    for an import script I want to run a bash command inside a (here: nextcloud..) container. This instruction to identify the container from the hostname doesn't seem to work anymore:
    https://forum.cloudron.io/post/2011
    what's the current approach?
    fbartelsF 1 Reply Last reply
      The script mentioned in the other forum post should still work fine. At its core is the following docker cli line to detect the container id:
      docker ps -q -f label=fqdn=$app -f label=isSubcontainer=false
      The attributes it filters on have not changed since then.
      • P perler
        fbartelsF
        fbartelsF
        fbartels
        Hi @perler
        from the settings of the app on in the Cloudron dashboard you could open a terminal. which will give you access to the container.
        You could also use the cloudron cli from your workstation. cloudron exec --app $locationofyournextcloud.
        • P
          P
          perler
          we want to use this in a script which runs locally on the cloudron server - what would be the preferred way here?
          • P perler
            fbartelsF
            fbartelsF
            fbartels
            @perler is this a one off thing, or something to run on a regular base?
            Personally I would use cloudron exec, but if you're planning to run the task regularly then it may be better to add this to the cron jobs of the app.
            • P
              P
              perler
              it's a one off thing, but preferrable within a script (so it should resolve the local container-id by hostname)
                • P perler
                  @perler Have you seen https://docs.cloudron.io/apps/#cron already? This will run the job in the context of a container.
                  I am happy to add other "meta" patterns, if none of those fit your use case 🙂
