  3. Fix for kernel bug in Ubuntu 20.04 causing various issues
44 Posts 8 Posters 14.5k Views 9 Watching
    This fix is not needed anymore. Ubuntu has released 5.4.0-135-generic
    Cloudron enables automatic ubuntu security updates. Roughly around 2022-11-17, the linux kernel was updated to 5.4.0-132-generic . You can find the automatic updates log in /var/log/apt/history.log. This kernel has a bug causing various things like containerd, prometheus node exporter etc to fail. On Cloudron, this manifests itself as:
    • automatic updates appear to get stuck in 'cleaning up old install"
    • cron jobs don't work anymore
    • file permissions inside containers become incorrect
    For the moment, it's best to revert to the previous kernel 5.4.0-131-generic. How you do this, depends on your VPS provider. Some VPS providers allow you to change the kernel via their control panels.
    Please be careful with instructions below. You might have to fine tune it based on your setup/provider.
    Many of the modern provider will just use Grub 2 as the kernel (digitalocean, linode, to name a few). On such VPS, please change the kernel as follows:
    • Highly recommend taking a snapshot of the server, in case something goes wrong.
    • SSH into the server
    • apt install linux-image-5.4.0-131-generic linux-modules-extra-5.4.0-131-generic
    • apt-mark hold linux-generic linux-image-generic linux-headers-generic
    • Edit /etc/default/grub . Find the line GRUB_DEFAULT=0. Change this to GRUB_DEFAULT="Advanced options for Ubuntu>Ubuntu, with Linux 5.4.0-131-generic" . Important you get this line right, otherwise your server may not boot!
    • update-grub
    • reboot
    • After reboot, uname -nar will say 5.4.0-131-generic.
    To reverse the above changes:
    • apt-mark unhold linux-generic linux-image-generic linux-headers-generic
    • unattended-upgrade -d - when running this you will see new kernel 5.4.0-135-generic is getting installed.
    • Edit /etc/default/grub . Change the line to GRUB_DEFAULT="Advanced options for Ubuntu>Ubuntu, with Linux 5.4.0-135-generic".
    • update-grub
    • reboot
    • After reboot, uname -nar will say 5.4.0-135-generic
    • apt remove linux-image-5.4.0-131-generic linux-modules-extra-5.4.0-131-generic - to remove the old kernel
    • Edit /etc/default/grub . Change the line to `GRUB_DEFAULT=0
    • update-grub
    Related threads:
    • https://forum.cloudron.io/topic/8096/docker-needs-to-be-restarted-often-due-to-fail-app-updates
    • https://forum.cloudron.io/topic/8032/apps-stuck-updating-cleaning-up-old-install-even-after-stopping-restarting-task
    imc67I P O 3 Replies Last reply
    10
    • girishG girish pinned this topic on
      • update-grub
      • reboot
      • update-grub
      • reboot
      • update-grub
      Related threads:
      imc67I Offline
      imc67I Offline
      imc67
      @girish was anyone succesful in reverting the kernel (especially on NetCup)?
      • imc67I imc67
        @imc67 I've not tried yet, but I'm interested in why @girish recommends the kernel reversion as opposed to updating Ubuntu 22.04?
        imc67I 1 Reply Last reply
          imc67I Offline
          imc67I Offline
          imc67
          wrote on last edited by imc67
          @jdaviescoates said in Fix for kernel bug in Ubuntu 20.04 causing various issues:
          was thinking about that too, but then first you need to update Cloudron to 7.3.2 and that's not stable yet? Or won't even update because of the issues?
          • imc67I imc67
            @imc67 said in Fix for kernel bug in Ubuntu 20.04 causing various issues:
            I'm already on it.
            That could be why I guess, might be risky to update with the issue.
            But still wondering if it might be the best option for me given I'm already on 7.3.2
              @p44 right. unfortunately, it's all part of the "cron jobs don't work anymore" issue.
              P Offline
              P Offline
              p44
              wrote on last edited by p44
              @girish Ok thank's, I applied this https://forum.cloudron.io/topic/8101/fix-for-kernel-bug-in-ubuntu-20-04-causing-various-issues on most of active instances.
              • Should we apply fix to all instances, even those that seemingly don't show any problems?
              • What will be next? When they fix kernel issue, we have to operate again to remove fix that we did?
              Thank's a lot
              • P p44 referenced this topic on
                I'm already on it.
                @jdaviescoates Updating to ubuntu 22.04 is a much riskier endeavor than just downgrading the kernel. Downgrading kernel only takes 5 mins. In fact, just this weekend I upgraded all our servers from Ubuntu 18 to 20 and all of them just completely hosed 😞 Each one failed in different places - one in upgrading cloud-init, another is still stuck in some "conflicting package" and for another I had to switch from DO mirror to canonical's mirror. I have generally not had good experiences with distro upgrades (on the server atleast). On desktop ubuntu, I feel things are better, maybe because I have the PC in front of me and have more control of the boot loader.
                Ubuntu 22 should work fine though with Cloudron 7.3. But note that it requires you to also rebuild all containers because of cgroup v1 to cgroup v2 migration. All this is in the docs but atleast we had 2-3 bug reports of the migration script not working perfectly.
                • P p44
                  Thank's a lot
                  @p44 said in Fix for kernel bug in Ubuntu 20.04 causing various issues:
                  I think it's best to apply to all instances running that kernel.
                  Yes, I think we can unhold the kernel packages and then it will keep auto updating to latest kernel.
                    @girish thanks, makes sense.
                    I guess rather than updating to 22.04 (if people wanted to try that route) it could be safer/ easier to migrate to a fresh install of 22.04?
                    @imc67 fyi I just did the fix above on my primary netcup server (the other one is only running an unloved instance of Uptime Kuma atm), very easy and seems to have gone smoothly.
                    jdaviescoatesJ girishG 2 Replies Last reply
                      Not so fast, some how my backup mount lost its permission and now I'm unable to remount it
                        yes, definitely.
                        martinkbsM 1 Reply Last reply
                        • girishG girish forked this topic on
                          • update-grub
                          • reboot
                          • update-grub
                          • reboot
                          • update-grub
                          Related threads:
                          P Offline
                          P Offline
                          p44
                          @girish Hello Girish,
                          after fix «automatic updates appear to get stuck in 'cleaning up old install"» has been solved, but it seems "cron jobs don't work anymore" problem is still there...
                          Do you have any other feedback on this issue?
                          • P p44
                            Seems to have gone for me. Previously my Nextclouds were giving me warnings about that, but they aren't doing that anymore.
                              P Offline
                              P Offline
                              p44
                              @jdaviescoates Thank's a lot, I'll do more accurate tests ... it seems only few cron jobs are executed, in external cron panel
                              • P Offline
                                P Offline
                                privsec
                                Is this a need to be done?
                                Can this get automated by Cloudron?
                                • P privsec
                                  @privsec It's not automated. I think automating kernel updates would be quite a reach for us since we don't control or have access to the hardware. We have to rely on ubuntu/debian to get their testing right here.
                                    avatar1024A Offline
                                    avatar1024A Offline
                                    avatar1024
                                    @girish said in Fix for kernel bug in Ubuntu 20.04 causing various issues:
                                    Interesting.... I upgraded one server from 16 > 18 > 20 and two more servers from 18 > 20 using the Cloudron guides and never had a problem. I was going to upgrade to 22 thinking it'll all be easy but a little more unsure now.
                                    • avatar1024A avatar1024
                                      @avatar1024 I think it's some issue with the DO apt mirrors. Something is out of rsync. I test out upgrading in vultr/linode and they seem perfect.
                                      • BrutalBirdieB BrutalBirdie referenced this topic on
                                        Ubuntu released a new kenel with the fix 5.4.0-135.152 - https://bugs.launchpad.net/ubuntu/+source/containerd/+bug/1996678/comments/28 . I don't know if this kernel arrives as a security update.
                                          At least on vultr Ubuntu 20.04 repository mirrors, the new fixed kernel is already available via security updates. You can check if this is the same in your instance by running:
                                          apt-get update && apt list --upgradable | grep "\-security"
                                          If it lists linux-generic/focal-updates,focal-security 5.4.0.135.133 amd64 [upgradable from: 5.4.0.132.132] then you have to unhold the previously hold packages and eventually it will normally update:
