  2. Immich
  3. Immich, Side-by-Side Comparison, and Voting?
Scheduled Pinned Locked Moved Immich
immichcomparisonside-by-sidevote
3 Posts 2 Posters 1.9k Views 3 Watching
  • L
    CA Maintainer
    You might have two slightly different images of the same subject. Or you might have two similar subjects in an image and wish to compare them together. You also would like feedback/votes to help indicate which is, for example, the best picture.
    Are there any tools people know which can help you accomplish this?
    • jdaviescoatesJ
      Super Fan
      I wouldn't have put this in the Immich category because it hasn't really got anything to do with that app.
      Closest I've found is https://pollunit.com/en/tutorials/vote_for_images
      You could probably create something similar using LimeSurvey but not in a nice automated way like you are looking for.
      There used to be this fun app in Nextcloud (which also wasn't really what you're looking for, but similar-ish) but it hasn't been updated for 4 years
      https://apps.nextcloud.com/apps/keeporsweep
      L 1 Reply Last reply
        CA Maintainer
        @jdaviescoates said in Immich, Side-by-Side Comparison, and Voting?:
        That is very kind of you and thanks for looking. I didn't think of LimeSurvey in this instance, but as you suggest, it is a bit overkill for what I have in mind.
        There is a tool to accomplish this task in DigiKam, but it is quite a large program too, and more for personal use than for displaying to hordes of people, though there are options for rating images.
        That PollUnit is a cool suggestion.
