  3. serious Cloudflare goof
cloudflare
21 Posts 6 Posters 12.8k Views 7 Watching
    @benborges said in serious Cloudflare goof:
    Maybe I'm confused, but unless this logic isn't build at the app deployment too, then yes for the main deployment it will work, but not for individual app additions ?
    Ah yes, that's what that flag does. I see now that the screeshot is not "complete". That UI is the domains view. If you set the flag, then when Cloudron adds a new domain to Cloudflare, it will set the proxying based on that value. Essentially, it's the default value of the proxying cloudflare bit for new subdomains (so, not just installation time). If you want to turn this off later, you can do so by going to the Cloudflare dashboard. Cloudron won't interfere with the "proxying" flag after the domain has been added (for the lifecycle of the app).
    benborgesB
    benborgesB
    benborges
    @girish Oh great, that seems good then, happy to test it when it's available !
    BenB
