  2. SOGo
  3. 2fa code issues
2fa code issues
Scheduled Pinned Locked Moved SOGo
6 Posts 4 Posters 2.7k Views 4 Watching
  • P Offline
    P Offline
    privsec
    I now have multiple users experiencing an issue with their 2FA codes that was set up with SOGo.
    How do I have them bypass/reset their accounts?
    I just tried myself, and now my two (personal and business) account is not letting me sign in at sogo.domain.com, I can login in just fine st snappy.domain.com
    BrutalBirdieB girishG 2 Replies Last reply
    • P privsec
      BrutalBirdieB Offline
      @privsec
      In the Database it's:
      To see your profile
      SELECT *
      FROM sogo_user_profile
      WHERE c_uid = "your@email.com";
      Disable 2FA:
      UPDATE sogo_user_profile
      SET c_defaults = REPLACE(
      c_defaults,
      "\\"SOGoTOTPEnabled\\": 1",
      "\\"SOGoTOTPEnabled\\": 0")
      • P privsec
        @privsec usually 2fa errors come from time not being in sync. Can you check the server time?
          P Offline
          P Offline
          privsec
          @girish Sure, but weird thing is all my other 2fa for services work without a problem
          • T Offline
            T Offline
            True
            For those who still struggle with the SQL method:
            Open up the terminal and just paste in this command to disable Sogo 2FA for a specific mailbox / user
            sogo-tool user-preferences set defaults your@email.com SOGoTOTPEnabled '{"SOGoTOTPEnabled":0}'
            @girish this single line of code could be easily added to the documentation: https://docs.cloudron.io/apps/sogo/
            There is nothing there regarding 2FA reset.
            "sogo-tool" is a CLI tool. Comes built in with the deployed image.
            Source for the solution: https://github.com/mailcow/mailcow-dockerized/issues/4490#issuecomment-1052121610
              Added to docs, thanks @True and @BrutalBirdie
