  3. ClassQuiz
ClassQuiz
13 Posts 7 Posters 6.3k Views 7 Watching
  • D Offline
    D Offline
    DohnJoe
    About ClassQuiz:
    ClassQuiz is a quiz-application like KAHOOT!, but open-source which is very important if it is a product for educational purposes. You can create quizzes and play them remotely with other people. It is mainly made for teachers, who create a quiz, so students can compete with their knowledge against each other.
    Additional links:
    Website: https://classquiz.de/
    source: https://github.com/mawoka-myblock/ClassQuiz
    docs: https://classquiz.de/docs
    self-hosting: https://classquiz.de/docs/self-host
    License: This repository is licensed under the Mozilla Public License 2.0
    timconsidineT jdaviescoatesJ 2 Replies Last reply
    • D DohnJoe
      About ClassQuiz:
      Additional links:
      timconsidineT Offline
      @uwcrbc looks good !
      The Dockerfile in github doesn't seem too complex.
      Might be a 'quick win' for deployment.
      • D DohnJoe
        About ClassQuiz:
        Additional links:
        @uwcrbc another great find, thanks!
        • M Offline
          M Offline
          Mawoka
          @timconsidine ClassQuiz dev here! I'd be happy to to help!
          girishG timconsidineT 2 Replies Last reply
          • M Mawoka
            @Mawoka welcome here! Very nice, we use kahoot! and Blooket quite a bit . What is the status of the app? Would be great to have a stable release first before we can package it for Cloudron.
            M 1 Reply Last reply
              M Offline
              M Offline
              Mawoka
              @girish Ah, yes! The problem with releases! Some features are done, others are... functional. ClassQuiz is definitely under active development, but I tend to add new features without polishing others. You can easily go ahead and test it online. The hosted version is exactly from the git master branch. I'll have a look at releases and will tell you what I'll come up with.
              • M Mawoka
                @Mawoka thank you 👏
                In case you're not aware, one important thing to know about Cloudron apps is that usually the application code (which doesn't change at runtime) is under /app/code/ and user data is under /app/data.
                  @Mawoka thank you 👏
                  M Offline
                  M Offline
                  Mawoka
                  @timconsidine But ClassQuiz is a docker-conpose stack, not just one container and 2 containers save user data:
                  1. Image uploads from the api container
                  2. Application data is saved by the postgres
                  timconsidineT girishG 2 Replies Last reply
                  • M Mawoka
                    @Mawoka Ah
                    OK
                    Beyond my skills then sadly.
                    Others maybe can advise about multiple containers.
                    Cloudron doesn't use docker-compose.
                    Just Dockerfile.
                    I had a quick look at modifying your Dockerfile in repo, but failed. Sorry !
                      @Mawoka Ah
                      OK
                      Just Dockerfile.
                      M Offline
                      M Offline
                      Mawoka
                      @timconsidine I may be looking into a single container setup in the future and will let you know!
                      • M Mawoka
                        @Mawoka Postgres is built into Cloudron, so the single image for the app need only connect to it for data storage.
                          @robi rather excellent point !
                          • M Mawoka
                            @Mawoka Cloudron is designed like a PaaS (like heroku). So, only the application container is needed. Rest of the things (database, cache etc) are maintained and provided by the platform.
