  3. PocketBase
PocketBase
14 Posts 5 Posters 6.6k Views 5 Watching
  • ericdrgnE
    ericdrgnE
    ericdrgn
    Would be great if we could get this on here 🙂
    Site - https://pocketbase.io/
    Source - https://github.com/pocketbase/pocketbase
      Looks interesting. Has a small warning: "Please keep in mind that PocketBase is still under active development and therefore full backward compatibility is not guaranteed before reaching v1.0.0."
      • D
        D
        d1rk
        I See, but that is also being said about Immich, http://immich.app. Yet, it is wonderful to use 🙂
        • D
          D
          d1rk
          Adding to this, also: It is a developer tool: So the people using it, would definitely be aware of such a caveat, I guess.
          • R
            R
            rollermy
            I'd like to use pocketbase on cloudron too. Great replacement for firestore. Been self hosting for a few months without any issues.
            • T
              T
              TheNils
              i have done a Cloudron package at https://git.cloudron.io/nils/pocketbase if some adventurous Cloudroneers want to test it. Packaging it is pretty easy but i'm not sure to keep it updated if it does not fit my needs.
              Also i may be more interested to fork the base project to support Postgresql because SQLite... i don't know... it feels weak to me.
              • R
                R
                rollermy
                I want to test it! I might be missing something obvious, but how do I test it out on my cloudron instance?
                T 1 Reply Last reply
                • R rollermy
                  T
                  T
                  TheNils
                  @rosano posted a simple tutorial for installing custom apps without docker : https://forum.cloudron.io/topic/11349/install-custom-app-via-private-registry-and-cloudron-build
                    @TheNils Can you put in a LICENSE ? I can try to publish it, since it seems simple enough.
                    • T
                      T
                      TheNils
                      @girish Done !
                        @TheNils thanks! repo moved to https://git.cloudron.io/cloudron/pocketbase-app . you should have permissions. I have published the app as unstable. Couple of issues are pending (in the issue tracker).
                        • girishG girish locked this topic on
                          @TheNils you should have App Dev badge as well, now.
                          • girishG girish marked this topic as a regular topic on
                            I had to unlist Pocketbase for the moment since it's using sqlite. This is not safe wrt Cloudron backups (especially because this is a backend app). SMTP automation also does not work since this feature has to be added upstream - https://github.com/pocketbase/pocketbase/discussions/669
                              @TheNils sqlite3 support is now in 8.2 - https://docs.cloudron.io/packaging/addons/#sqlite . I guess we can add this back now.
