  2. Nextcloud
  3. Increase Loading Speed and Reliability
11 Posts 3 Posters 3.2k Views 4 Watching
  • firmansiF Offline
    firmansiF Offline
    firmansi
    I am running on aws with 4 vcpu and 8 MB RAM with only core and essential addons including Nextcloud Office with Collabora, and so far we only have like 6 users registered to use nextcloud since we still feel like there's a an issue with loading speed for whole UI, and sometimes the nextcloud office not loaded smoothly
    Can anyone share experiences on using nextcloud, and maybe there's tips on how to make it more reliable
      @firmansi I would try two things:
      • Bump the memory limit of the app to say 2-3GB or so.
      • Adjust apache prefork configuration as you see fit. It's in /app/data/apache which you can edit using the File manager. Specifically you can bump up MaxRequestWorkers to a higher number say 50 or so.
      <IfModule mpm_prefork_module>
          # On startup, start these many servers
          StartServers    2
          # At any given time, keep atleast these many servers
          MinSpareServers 2
          # At any given time, keep atmost these many idle servers (this is always >= MinSpareServers+1)
          MaxSpareServers 3
          # Maximum number of servers at any given instant. Requests will be queued after this
          MaxRequestWorkers     15
          # Recycle process after handling these many requests. This protected against accidental memory leaks
          MaxConnectionsPerChild   100
      </IfModule>
      • humptydumptyH Offline
        humptydumpty
        The difference is day and night! I might have gone overboard with the values, but it's on my homeserver so it should handle it just fine.
        	StartServers	10
        	MinSpareServers	10
        	MaxSpareServers 20
        	MaxRequestWorkers	  95
        	MaxConnectionsPerChild   200
        </IfModule>
        • firmansiF Offline
          firmansiF Offline
          firmansi
          Thanks @girish for the input, how about collabora office, is there any optimization needed? and also reddis cache, is there any tips on how to set the memory size to sizing with nextcloud usage?
          • firmansiF Offline
            firmansiF Offline
            firmansi
            @humptydumpty what's your server spec for this configuration? will the spec have impact on apache configuration?
              humptydumpty
              I5-6500T and 8GB RAM. Idk about the impact on apache but the resource usage look the same in the graphs.
              • firmansiF firmansi
                @firmansi AFAIK, collabora office has no specific settings to optimize.
                Turns out there are a bunch of settings. If you see https://github.com/CollaboraOnline/online/blob/master/coolwsd.xml.in , there is num_prespawn_children and also max_concurrency. Maybe you can play with those settings a bit. On Cloudron, this file is in /app/data/coolwsd.xml .
                firmansiF 1 Reply Last reply
                  firmansiF Offline
                  firmansiF Offline
                  firmansi
                  @girish thanks...i will try to put this on play and see how things going
                  • firmansiF Offline
                    firmansiF Offline
                    firmansi
                    After trying this and that, i finally uninstall collabora and deactivate nextcloud office, the loading time is not that good even after optimization, we stick to use nextcloud as storage and document management without office capabilities
                      @firmansi have you tried onlyoffice as well? that one also has office integration.
                      • firmansiF Offline
                        firmansiF Offline
                        firmansi
                        After trying Onlyoffice Docs for the the last 15 days, i can say onlyoffice is better than Collabora, it runs and loads faster than collabora with the same machine specification and number of users, now i turn back on the nextcloud office with onlyoffice ,i can say this solution is more reliable than collabora office which is slow and failing most of the time
