  2. Penpot
  3. Penpot not avaliable in appstore
Scheduled Pinned Locked Moved Solved Penpot
8 Posts 4 Posters 3.9k Views 4 Watching
  • B
    B
    borax
    My cloudron version is 7.4.0. Cant locate penpot app in appstore. What could be the problem?
    • luckowL
      luckowL
      luckow
      Perhaps it's a topic for updating your Cloudron platform. Settings -> Updates. My current version is: v7.4.2
        Yes, as @luckow said, Cloudron needs to be on v7.4.2 to install Penpot.
        • B
          B
          borax
          There is a message on my update page, thats why is didnt upgrade.
          "Update Cloudron to 7.4.1
          This update is a pre-release and not considered stable yet. Please update at your own risk."
            7.4.2 is fully released by now, so it is safe to update, not sure why you would still see the pre-release note
            B 1 Reply Last reply
              B
              B
              borax
              @nebulon will it directly upgrade to 7.4.2 or initially to 7.4.1 as the message says?
                it will upgrade on release after the other, as this is how releases are tested from our side
                  B
                  B
                  borax
                  @nebulon thank you. I will upgrade cloudron.
