  3. Cloudron on 18.04.5 - GLIBC_2.28 not found (required by node)
nodeupgrade
12 Posts 5 Posters 13.7k Views 5 Watching
  • BrutalBirdieB Offline
    Jun 28 08:01:10 ubuntu-2gb-fsn1-2 systemd[1]: box.service: Main process exited, code=exited, status=1/FAILURE
    Jun 28 08:01:10 ubuntu-2gb-fsn1-2 systemd[1]: box.service: Failed with result 'exit-code'.
    Jun 28 08:01:10 ubuntu-2gb-fsn1-2 systemd[1]: box.service: Service hold-off time over, scheduling restart.
    Jun 28 08:01:10 ubuntu-2gb-fsn1-2 systemd[1]: box.service: Scheduled restart job, restart counter is at 166209.
    Jun 28 08:01:10 ubuntu-2gb-fsn1-2 systemd[1]: Stopped Cloudron Admin.
    Jun 28 08:01:10 ubuntu-2gb-fsn1-2 systemd[1]: Started Cloudron Admin.
    Jun 28 08:01:11 ubuntu-2gb-fsn1-2 box.js[24427]: node: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by node)
    Incident logging topic.
    • BrutalBirdieB BrutalBirdie
      Looks like Ubuntu 18.04.05 is the issue.
      Attempting upgrade to 20.04 to fix the Issue.
      Upgrade to Ubuntu 20.04 solved the Issue.
          • BrutalBirdieB BrutalBirdie marked this topic as a question on
          • BrutalBirdieB BrutalBirdie has marked this topic as solved on
          • nebulonN Away
            nebulonN Away
            Yes this is the reason why we stopped supporting Ubuntu 18 😕
            See also https://forum.cloudron.io/post/68921
              @nebulon happend on a server with Cloudron version v7.4.2 tho 🤔
                Can you check node --version ? I think this is supposed to happen only with node 18 (which is in Cloudron 7.5.0)
                • C Offline
                  C Offline
                  Cetheus
                  I am facing the same Problem.
                  Do I have to be careful with something, when upgrading to Ubuntu 20.04?
                  I'm told at the ssh-login not to upgrade the System via console. Thats why I'm asking.
                    @Cetheus We have a guide at https://docs.cloudron.io/guides/upgrade-ubuntu-20/ to upgrade ubuntu. It's fine to upgrade all packages (for ubuntu 18 to 20).
                    • RazielKanosR Offline
                      RazielKanos
                      just be careful about to boot partition, that fucked up my update from 18 to 20 and i had to reinstall everything, make sure you have backups for your cloudron stuff!
                      C 1 Reply Last reply
                      • RazielKanosR RazielKanos
                        C Offline
                        C Offline
                        Cetheus
                        @RazielKanos Thanks for the warning.
                        I'm running a Mastodon Instance.
                        Then I will take a look how to back it up via command line.
                        • C Offline
                          C Offline
                          Cetheus
                          Thanks for all your help.
                          The Server is up and running again 🙂
                          • nebulonN Away
                            nebulonN Away
                            Also for others to come here, to get back up on Ubuntu 18.04 run the following commands via SSH:
                            mkdir -p /usr/local/node-16.18.1
                            curl -sL https://nodejs.org/dist/v16.18.1/node-v16.18.1-linux-x64.tar.gz -o /tmp/node.tar.gz
                            tar zxvf /tmp/node.tar.gz --strip-components=1 -C /usr/local/node-16.18.1
                            rm /tmp/node.tar.gz
                            ln -sf /usr/local/node-16.18.1/bin/node /usr/bin/node
                            ln -sf /usr/local/node-16.18.1/bin/npm /usr/bin/npm
                            systemctl restart box
                            Then the system should be working again, however for the 7.5 update ubuntu has to be upgraded first.
