  2. Valheim
  3. Mods do not work
Mods do not work
Scheduled Pinned Locked Moved Solved Valheim
8 Posts 5 Posters 3.8k Views 4 Watching
    A Former User
    Hello,
    i am hosting a valheim server for a few friends.
    Now they came up with the idea to enable mods. They gave me a list of the mods they wanted.
    I edited the .env like this:
    SERVERNAME="xxxxxxxxxxx"
    WORLDNAME="CloudronValheimWorld"
    PASSWORD="xxxxxxxxx"
    PUBLIC=1
    MODSUPPORT="1"
    SAVEINTERVAL="1800"
    BACKUPS="4"
    BACKUPSHORT="7200"
    BACKUPLONG="43200"
    CROSSPLAY=0
    after a restart i was able to connect to valheim using the client.
    After uploading the mods as described in their instructions i get these logs, MBs of text in minutes:
    /Unity.TextMeshPro.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/UnityEngine.UI.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/UnityEngine.XRModule.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/Valheim.DisplayBepInExInfo.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_googleanalytics.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_guiutils.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_lux.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_postprocessing.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_simplemeshcombine.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_steamworks.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_sunshafts.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_utils.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/assembly_valheim.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/data-0x55b2e74a4ca0.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/data-0x55b2e8ae1640.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/data-0x55b2e8af9460.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/data-0x55b2e8b12410.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/netstandard.dll.so
    Aug 19 16:57:28 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/�$o�U/mono/aot-cache/amd64/ui_lib.dll.so
    even removing the mods i installed did not change this.
    I found a log stating that BepInx Version is out of date. Maybe this is the issue?
      Closed due to inactivity
      note: mods are working, asked @BrutalBirdie he tested it briefly
        @BrutalBirdie do you know?
        • BrutalBirdieB
          BrutalBirdieB
          I need to take a look at it.
          • BrutalBirdieB
            BrutalBirdieB
            @timbo please leave some information about the mod you are trying to use.
            • BrutalBirdieB
              BrutalBirdieB
              I've updated the app to have the beepinex mod support version dynamically select able by the user.
              With default a version tested by me with the most common used mod, ValheimPlusPlus.
              Aug 21 14:09:06 [Info : BepInEx] Loading [Valheim Plus 0.9.9.11]
              Aug 21 14:09:06 Fallback handler could not load library /run/vhserver-steam/valheim_server_Data/Mono/data-0x55a0aadf1fe0.so
              Aug 21 14:09:06 [Info :Valheim Plus] Trying to load the configuration file
              https://git.cloudron.io/cloudron/valheim-gameserver-app/-/merge_requests/8
              So far latest BeepInEx Version works as expected. If the plugin / mod is not working I can not help with that.
              Since also I have no information about what plugin / mod is used.
              All I can say, mod support is working.
                I have pushed a new package version now based on the changes from @BrutalBirdie
                  A Former User
                  Thanks and sorry for the delay - i went for a trip last week with my wife. 🙂 I will try this soon.
                  • nebulonN nebulon referenced this topic on
