Shiori: Simple bookmark manager built with Go
@girish no, it supports user accounts.
But TBH I haven't used that functionality.If you want, I can set up an account for you on my instance, so you can play around.
If that's helpful. -
@timconsidine just building it!
@girish said in Shiori: Simple bookmark manager built with Go:
@jdaviescoates said in Shiori: Simple bookmark manager built with Go:
Same. Having just discovered lots of link rot, I really want one that archives the links, like Shiori apparently does:
"Where possible, by default shiori will parse the readable content and create an offline archive of the webpage." - https://github.com/go-shiori/shiori#features
I'm really hoping we can get those archiving features working too!
If that's helpful.@timconsidine said in Shiori: Simple bookmark manager built with Go:
Just FYI before @timconsidine answered I asked in their Matrix channel and they said:
It allows multi user support, but the bookmarks are shared between all users. Owners can add/edit/delete bookmarks while guests can only see bookmarks.
G girish marked this topic as a question on
G girish has marked this topic as solved on
G girish locked this topic on
