  2. Nextcloud
  3. Bug: Auto logout with and without inactivity - 28.0.5
27 Posts 10 Posters 7.0k Views 10 Watching
  • daebakD Offline
    daebakD Offline
    daebak
    What @necrevistonnezr says is totally appropriate. There are bugs, like in this case, that cannot wait for an update to be released but should be released as a priority. The dental clinic secretaries have been doing the swing (logout/login) for 2 weeks to register appointments. In the end, with this bug it is possible to continue working but, what would have happened if it completely prevented an operation, we went back to pen and paper? Although updates can be scheduled over the weekend to have time to test and possibly restore the old version, the real problems occur with normal use and, after adding data, it is not possible to go back. I therefore hope that Nexcloud understands that, in some cases, it is important to release emergency fix releases. 🤞
    BUSINESS DEVELOPER
    https://antoniodonofrio.com
      I can't stress enough, how super annoying this is when you're actually trying to work with the web interface.
      It'a major f*ck-up by Nextcloud and really bad that they did not release an emergency fix.
      Let's me question the whole use of the system.
      #22
      @necrevistonnezr said in Bug: Auto logout with and without inactivity - 28.0.5:
      I almost thought the same when an update to the Nextcloud OnlyOffice app stopped it working
        28.0.6 is out now
        • necrevistonnezrN Offline
          The error seems gone.
          I recommend clearing the browser cache after the upgrade - the web interface of Nextcloud had become much much slower until I did.
          • marcusquinnM Offline
            Yup, looks to be fixed to me after a few hours since last login.
            Speed sees as usual, too.
              Messages are editable now, too 🙌
              • marcusquinnM marcusquinn
                @marcusquinn I've not yet updated to 29.0.1 to get the message editing features, but so glad it's coming!
                It's also great how you can now finally (already in 28) link Nextcloud Forms to Nextcloud Spreadsheets too!
