  2. Nextcloud
  3. Bug: Auto logout with and without inactivity - 28.0.5
27 Posts 10 Posters 7.1k Views 10 Watching
  • daebakD Offline
    daebakD Offline
    daebak
    wrote on last edited by daebak
    After the latest update from 28.0.4 to 28.0.5, there’s an auto logout problem with or without activity.
    I also tried to add these parameters
    ‘session_lifetime’ => 86400, ‘session_keepalive’ => true, ‘auto_logout’ => false,
    in the config.php but nothing, the problem persists.
    I reported this bug:
    https://github.com/nextcloud/server/issues/45132
    the response:
    Please try to apply #45093. it is for 29, but the changes can be done for 28 as well until the backport is done.
    https://github.com/nextcloud/server/pull/45093
    Has anyone else encountered this problem?
    Thank you.
    BUSINESS DEVELOPER
    https://antoniodonofrio.com
      @daebak thanks for reporting upstream. Let's see, I just logged in into my nextcloud. Will report back in 1 hour or so.
        So far.. mine is still logged in after 45 mins.
          OK, so for me it does not log out, even with no activity. Maybe this is something browser related or plugin related.
          • daebakD Offline
            daebakD Offline
            daebak
            @girish Thank you! It's not regular, in some cases it happens during use. For example, in the clinic where downtime is rare, it happened 3 or 4 times to accounts even just switching from file to calendar. I did a new installation and I noticed that if the browser window is minimized, if I reopen it after a while it requires login.
            BUSINESS DEVELOPER
            • daebakD Offline
              daebakD Offline
              daebak
              It's not a matter of plugins or browsers. New installation and incognito browser.
              BUSINESS DEVELOPER
              • M Offline
                M Offline
                msbt
                wrote on last edited by msbt
                Happens to me as well, using Firefox on Ubuntu, the only special plugin I have is the news extension which times out rather quickly, I haven't timed it since I'm not watching it, but at some point it always goes Request unauthorized. Are you logged in?.
                • necrevistonnezrN Offline
                  I have the same issue...
                  • E Offline
                    E Offline
                    EntityPacket
                    Same issue here. Literally logs me out all the time, every day and sometimes multiple times per day. Has this be acknowledged as a new bug?
                    • P Offline
                      P Offline
                      Phase
                      Same issue for me. It's literally impossible to upload big files with my slow Internet Connection because I get logged out while uploading.
                        I can't reproduce this here either. Not sure if this is related but maybe to narrow down the potential error angle, does this happen with Cloudron user management enabled? And if so does the same happen for the Nextcloud local admin account?
                          • User management set to "All users from this Cloudron"
                          • Normal user: Logout happens even in an "incognito" browser window (Edge, Brave)
                          • Admin: stays logged in (for the last ~30 mins; Edit: stays logged in even after ~90 mins)
                          So at least for me, it seems restricted to "normal" users.
                            Seems to be a common problem now: https://help.nextcloud.com/t/web-interface-forcing-logout-after-upgrade-to-28-0-5/189651
                            https://github.com/nextcloud/server/pull/45093 will me merged now, apparently
                              @necrevistonnezr well spotted, thanks for sharing. Seems merged already, so hopefully this fixes the issue then with the next release.
                              • daebakD Offline
                                daebakD Offline
                                daebak
                                As I opened this post, I already indicated that I had opened an issue on GitHub, the one mentioned in the previous comment.
                                https://github.com/nextcloud/server/issues/45132#issuecomment-2098151745
                                Now, whoever applied the fix, which is hoped to be released in the next release, encountered this problem:
                                "for us #45093 did fix the auto logout error but Nextcloud Office / Collabora Code could not access the files any more, so we had to choose what’s more important, NC Office or a reliable Talk App.
                                A general question: Does the Maintenance and Release Schedule, in this case for 28.0.6 (2024-05-23) and 29.0.1 (2024-05-23), also apply to critical issues like that or are hotfixes rolled out via the Updater earlier?".
                                I don’t know if this can also cause problems with OnlyOffice. I believe that must be very careful when performing the update, at least try the operation of the main applications.
                                BUSINESS DEVELOPER
                                • tshirt-chihuahuT Offline
                                  tshirt-chihuahu
                                  wrote on last edited by tshirt-chihuahu
                                  This is awful. Nextcloud calendar has become (effectively) unusable. Has anyone found a workaround? @nebulon were you able to figure out why you could not reproduce? Perhaps that's a potential workaround....
                                    Think we are looking for the answer to https://github.com/nextcloud/server/issues/45132#issuecomment-2098151745 . If the patch will be part of next release or not. If it will be, then we should have a new package next week.
                                    • marcusquinnM Offline
                                      Looks like there could be a fix coming downstream...
                                      The PR was merged for 28.0.6: https://github.com/nextcloud/server/milestone/265?closed=1
                                      https://github.com/nextcloud/server/issues/45132#issuecomment-2121047422
                                        I can't stress enough, how super annoying this is when you're actually trying to work with the web interface.
                                        It'a major f*ck-up by Nextcloud and really bad that they did not release an emergency fix.
                                        Let's me question the whole use of the system.
                                          It says 28.0.6 is expected today - https://github.com/nextcloud/documentation/milestone/258 but there are still some tasks open. Anyone know the nextcloud release date for this patch release? 🤞
