  3. BookStack - knowledge management application
29 Posts 11 Posters 21.9k Views 17 Watching
  • M
    msbt
    wrote on last edited by msbt
    #21
    Fixed, now all you have to do is login after installation and adjust the settings for new users!
    Todo: redis support
    murgeroM 1 Reply Last reply
    • M msbt
      Todo: redis support
      murgeroM
      murgeroM
      murgero
      @msbt Just an FYI I am getting a LOT of login errors after restarting the container after initial login:
      Jun 26 20:59:30 + [[ ! -f /app/data/.env ]]
      Jun 26 20:59:30 + [[ ! -d /run/sessions/ ]]
      Jun 26 20:59:30 + chmod -R 755 /app/data/uploads /app/data/storage
      Jun 26 20:59:30 + php artisan migrate --no-interaction --force
      [PDOException]
      Jun 26 20:58:28 SQLSTATE[HY000] [1045] Access denied for user 'REDACTED'@'f45baf31-
      Jun 26 20:58:28 somethingsomething.cloudron' (using password: YES)
      It has been sitting at repeating the above message for 30 minutes for me.
      https://urgero.org
      • M
        msbt
        #23
        ok that doesn't seem right, I've removed migrations for now from startup (#php artisan migrate --no-interaction --force), gonna have to talk to @girish or @nebulon if something changed in the environment. if you grab the latest one, it should start up again. thanks for mentioning!
        • M msbt
          murgeroM
          murgeroM
          murgero
          @msbt What do the migrations do here? If its for post-updates / install you can detect if you need to do that in bash by comparing files and such
          https://urgero.org
          • M
            msbt
            Yeah that was in case a new version got out, I'll think of something better to handle that 😉
            • M msbt
              murgeroM
              murgeroM
              murgero
              @msbt Just wanted to let you know, the fix you implemented did work. I am able to reconfigure, reboot, etc and it comes back up with no errors each time.
              https://urgero.org
              • M
                msbt
                there has been a security release, please update to v0.26.3.
                  Thanks a lot @msbt ! Bookstack is now available in the app store.
                    https://git.cloudron.io/cloudron/bookstack-app is the package repo
