  3. Trouble with IPv6 (was "HELP NEEDED URGENTLY") !!!
networkingipv6
39 Posts 10 Posters 17.6k Views 9 Watching
  • humptyH
    humptyH
    humpty
    I’ll save you the trouble.. use an smtp relay like mailgun
    • M mmtrade
      @matix131997 It does not deliver eitherway
      I have tried to send from yahoo and it keeps bouncing back
      @girish please share your ideas on this solution.
      @mmtrade usually the IP addresses in most VPS providers are blocked by the big mail providers. You have to use a mail relay or be patient with warming up the IP for say 6 months or so (and contact the big providers to unblock your IP). There is no other solution to this.
        @mmtrade it doesn't looks like your server supports IPv6. You can try like this:
        • SSH into your server
        • Run curl https://ipv6.api.cloudron.io/api/v1/helper/public_ip
        Does the above command return your IPv6 ?
        C
        C
        csteiger
        @girish I
        I have the same problem since today. I can't install any app anymore, I get the "ipv6.api.cloudron.io unreachable" error.
        ubuntu@s3:~$ curl https://ipv6.api.cloudron.io/api/v1/helper/public_ip
        curl: (28) Failed to connect to ipv6.api.cloudron.io port 443 after 132362 ms: Connection timed out
        A problem with your server? It doesn't answer to ping.
        ubuntu@s3:~$ ping ipv6.api.cloudron.io
        PING ipv6.api.cloudron.io(2604:a880:800:10::b66:f001) 56 data bytes
        ^C
        --- ipv6.api.cloudron.io ping statistics ---
        184 packets transmitted, 0 received, 100% packet loss, time 187390ms
        Thanks in advance for your help.
        • C csteiger
          @girish I
          ^C
          @csteiger the server is definitely up
          PING ipv6.api.cloudron.io (2604:a880:800:10::b66:f001) 56 data bytes
          64 bytes from prod.cloudron.io (2604:a880:800:10::b66:f001): icmp_seq=1 ttl=45 time=205 ms
          64 bytes from prod.cloudron.io (2604:a880:800:10::b66:f001): icmp_seq=2 ttl=45 time=132 ms
          64 bytes from prod.cloudron.io (2604:a880:800:10::b66:f001): icmp_seq=3 ttl=45 time=133 ms
          64 bytes from prod.cloudron.io (2604:a880:800:10::b66:f001): icmp_seq=4 ttl=45 time=276 ms
          64 bytes from prod.cloudron.io (2604:a880:800:10::b66:f001): icmp_seq=5 ttl=45 time=129 ms
          Can you check your network? Are you able to ping other IPv6 addresses?
          C 1 Reply Last reply
            C
            C
            csteiger
            @girish
            Thanks.
            I don't know what happened, the local DNS was down... a reboot did it 🙂
            • M
              mmtrade
              @girish my cludron server is offline..
              i do not know why but no matter what i do and retsart it is still offline
              • M
                mmtrade
                  Is the DNS resolving to the correct IP? At least the one it resolves for me is not even pingable, so is that server publicly reachable?
                  • M
                    mmtrade
                    @nebulon I checked in my cloudflare and i just readjusted the server DNS to the IP
                    It is still not working and i do not know why? what should I do from here?
                    humptyH 1 Reply Last reply
                    • M mmtrade
                      humptyH
                      humptyH
                      humpty
                      @mmtrade it could be because of DNS propagation, check it using an online tool: https://mxtoolbox.com/dnspropagation.aspx
                      • M
                        mmtrade
                        https://mxtoolbox.com/supertool3?abt_id=AB-631A&abt_var=Variation&action=a:ronsteels.com:all
                        • M
                          mmtrade
                          and yes i adjusted the IP on my cloudflare. I initaially rebooted my VPS and i think that was why the DNS changed. But i had to go to my cloudflare to adjust this also
                          • M
                            mmtrade
                            so i corrected the issue with the DNS now.
                              Is it working now? Is your dashboard domain resolving to the correct IP ? At least from here it appears to be resolving to an IP which is not reachable on any port I've tried.
                              • M
                                mmtrade
                                it is not working... the domain is resolving to the correct IP but i cannot seem to open the cloudron at all
                                this is my vps IP 185.203.217.223
                                you can check from any tool to see if it is resolving fine. I think the problem is on cloudrun
                                can you advise
                                • matix131997M
                                  matix131997M
                                  matix131997
                                  wrote on last edited by matix131997
                                  #36
                                  I checked that your domains have the IP address you provided and it detects correctly, that is, the DNS is set correctly. The next test I did was a port scan and BUM. They are filtered. If you didn't set something with SSH some settings then Contabo restricted IP access to the server e.g.: a large number of requests or an attack on your servers e.g. SSH hacking attempt.
                                  If you didn't have a secured server with a few parameters that restricts the attack on SSH in sshd_config with a public key then you really had hack attacks.
                                  I too have 2 servers in Contabo and I didn't experience any attack because I already set up according to the security standard SSH access to the server right after launching the Cloudron platform.
                                  The solution? You need to write to support to unblock the IP address, if not then change the address to another one and manually enter in Cloudflare the new address in each entry "A" and "AAAA"
                                  • M
                                    mmtrade
                                    @matix131997 I really would need some help chaning it manually. I have written the support and still no answer. I could use your help if you come on a live followup
                                    matix131997M 2 Replies Last reply
                                    • M mmtrade
                                      matix131997M
                                      matix131997M
                                      matix131997
                                      @mmtrade
                                      Now on a quick note, I can't recall how it changed the IP address. You'll have to wait from tech support for them to fix the problem for you. If they unblock it for you, you need to secure the server well, i.e. limit SSH access.
                                      • M mmtrade
                                        matix131997M
                                        matix131997M
                                        matix131997
                                        @mmtrade
                                        Okay, after a thorough analysis of my account. I have a VPS the cheapest, where I could not change the IP address. It remains technical support to solve this and as you in which you manage the server you have the task of securing the server.
