  2. WordPress (Developer)
  3. WP-CLI Doesn't Work
WP-CLI Doesn't Work
Scheduled Pinned Locked Moved WordPress (Developer)
2 Posts 2 Posters 859 Views 2 Watching
  • B
    B
    BetterWP
    Hi ,
    I am trying to use at /public folder but I got that error
    /usr/bin/wp: line 3:   607 Killed                  sudo -u www-data -i -- /app/pkg/wp --path=/app/data/public/ "$@"
    Any help , Thanks
      Usually Killed means that the app is running out of memory. Give it more memory and try running the command.
      BTW, there is an alias called wp. You can just use that to run wp cli commands.
