  3. Flarum - next-generation forum
51 Posts 21 Posters 25.5k Views 21 Watching
  • G
    G
    gog122
    So will Flarum be added ?
    TheMeerkatT 1 Reply Last reply
    • G gog122
      TheMeerkatT
      TheMeerkatT
      TheMeerkat
      @gog122 said in Flarum - next-generation forum:
      All you can do is upvote, express your interest, and pray to the Cloudron gods. 😺
      • TheMeerkatT TheMeerkat
        @TheMeerkat You can do much more than that!
        From sponsoring the packaging, having someone else package it, to getting it started by packaging it yourself.. there is a wide spectrum of options to moving the ball forward. 😉
        • S
          S
          simong
          wrote on last edited by simong
          #44
          @TheMeerkat @gog122 Flarum works on Cloudron with the LAMP App out of the box:
          https://forum.cloudron.io/topic/13446/template-flarum-modern-fast-free-community-software
          • S simong
            #45
            @simong said in Flarum - next-generation forum:
            @gog122 Flarum works on Cloudron with the LAMP App out of the box.
            1. Install LAMP
            2. open the Terminal and enter this command:
            composer create-project --no-interaction flarum/flarum:^1.8.0 /app/data/flarum && sed -i 's|/app/data/public|/app/data/flarum/public|g' /app/data/apache/app.conf && cd /app/data/flarum && composer require flarum/extension-manager:"*" && (read -p "Admin-User: " username && read -p "Admin-Password: " password && read -p "Admin-Email: " email && read -p "Forum-Name: " forum_title && php -r "file_put_contents('flarum-config.json', json_encode(['debug' => false, 'baseUrl' => 'https://' . getenv('CLOUDRON_APP_DOMAIN'), 'databaseConfiguration' => ['driver' => 'mysql', 'host' => getenv('CLOUDRON_MYSQL_HOST'), 'port' => 3306, 'database' => getenv('CLOUDRON_MYSQL_DATABASE'), 'username' => getenv('CLOUDRON_MYSQL_USERNAME'), 'password' => getenv('CLOUDRON_MYSQL_PASSWORD'), 'prefix' => ''], 'adminUser' => ['username' => '$username', 'password' => '$password', 'email' => '$email'], 'settings' => ['forum_title' => '$forum_title', 'mail_driver' => 'smtp', 'mail_host' => getenv('CLOUDRON_MAIL_SMTP_SERVER'), 'mail_port' => getenv('CLOUDRON_MAIL_SMTP_PORT'), 'mail_encryption' => '', 'mail_username' => getenv('CLOUDRON_MAIL_SMTP_USERNAME'), 'mail_password' => getenv('CLOUDRON_MAIL_SMTP_PASSWORD'), 'mail_from' => getenv('CLOUDRON_MAIL_FROM')]], JSON_PRETTY_PRINT));" && php flarum install --file=flarum-config.json && sed -i -e "s/'host' => '.*'/'host' => getenv('CLOUDRON_MYSQL_HOST')/g" -e "s/'database' => '.*'/'database' => getenv('CLOUDRON_MYSQL_DATABASE')/g" -e "s/'username' => '.*'/'username' => getenv('CLOUDRON_MYSQL_USERNAME')/g" -e "s/'password' => '.*'/'password' => getenv('CLOUDRON_MYSQL_PASSWORD')/g" -e "s/'url' => '.*'/'url' => 'https:\/\/'.getenv('CLOUDRON_APP_DOMAIN')/g" config.php && rm flarum-config.json)
            1. restart the app and open the website
            Updates can be done via the Extension Manager in the Admin UI.
            Nice, thanks!
            Just for fun I thought I'd give that a try. It prompted me to set-up Admin user/ pw/ email and forum name, then I restarted and... it worked!
            https://flarum.uniteddiversity.coop
            I was able to register as a new user and login and start a discussion:
            I'll delete this soon, but good to know it's that easy if I ever/ want or need one!
              1. Install LAMP
              Nice, thanks!
              @jdaviescoates is there a dark mode?
                @robi doesn't look like it. Perhaps via extensions.
                  wrote on last edited by robi
                  #48
                  @jdaviescoates It seems it does, it's just not obvious in Settings.
                  It's in the > Administration > Appearance menu
                  or
                  /admin#/appearance
                    or
                    /admin#/appearance
                    #49
                    @robi ah, I didn't even look in admin, assumed it'd be a user level setting
                    • J
                      There's a write up on how to install it using the LAMP app here - https://forum.cloudron.io/topic/13446/template-flarum-modern-fast-free-community-software
                        @joseph we know: https://forum.cloudron.io/post/103375
