Drupal
@nebulon Is there any progress here? It would be great to have some more CMSs available on Cloudron.
@edapm afaik Drupal is facing similar challenges to pack as an app as Magento. It heavily relies on composer which handles all dependencies (modules, themes, libraries,...) This means that a big chunk of app needs to be writable at all times when you're customizing it. So it's probably easiest if you just fire up a LAMP and install it from there.
@kyzoe-be I've never used the LAMP app myself (because part of the whole reason for using Cloudron is to not have to bother), but I think the idea is just to install Drupal like you would on any other LAMP server as that is basically what the LAMP app is.
So I'd guess you just follow standard instructions for installing Drupal like e.g. https://www.drupal.org/docs/installing-drupal
