  2. Nextcloud
  3. Problem restarting Nextcloud after Disk Full Event
13 Posts 6 Posters 4.7k Views 6 Watching
  • ShaiS
    ShaiS
    Shai
    This seems to happen to me every couple of years... I fill the hard drive and it crashes Nextcloud and I have a hard time restarting Nextcloud. I have read through the previous threads I've started on this topic.
    I removed lots of file allowing for plenty of hard drive space. I dealt with the unbound issue and restarted that service.
    In terms of replacing config/config.php with a version from a backup, the most recent version I had was from 2023, oops. I got an error from that file about it being an old version. So then I just tried inserting
      'installed' => true,
    into the current version. The error messages I'm getting now after clicking on "Start app" are
    OCP\HintException: [0]: Configuration was not read or initialized correctly, not overwriting /app/code/config/config.php ()
    and
    Jan 09 17:30:43=> Healtheck error: Error: connect EHOSTUNREACH 172.18.17.145:80
    I'd really appreciate help in getting my Nextcloud running again. Thank you.
    • ShaiS Shai
      and
      @Shai said in Problem restarting Nextcloud after Disk Full Event:
      I don't understand, you're using Cloudron but don't have regular automatic backups?!?
      • ShaiS
        ShaiS
        Shai
        Yes, really stupid, there were reasons which I don't want to go into here.
          search for "disk full nextcloud" in the forum for ready made solutions
            @Shai take a config.php from a fresh config.php and patch in values like passwordsalt, secret . If you restart nextcloud, values like db/redis/smtp/ldap will get updated to latest values automatically, so you don't need to fixup those. 🤞
            • ShaiS
              ShaiS
              Shai
              @girish followed your instruction but I'm getting the following in the logs after a restart of the Nextcloud App says "Not responding":
              An unhandled exception has been thrown:
              Jan 11 22:12:08OCP\HintException: [0]: Downgrading is not supported and is likely to cause unpredictable issues (from 30.0.4.1 to 29.0.3.4) ()code_text
              Ideas?
                @Shai there is a version field in the same config.php . Adjust that to your nextcloud version.
                • ShaiS
                  ShaiS
                  Shai
                  Thanks @girish. Won't restart after the recommended edit of config.php. Here is the error:
                  => Healtheck error: Error: connect ECONNREFUSED 172.18.17.145:80
                  OCP\HintException: [0]: Downgrading is not supported and is likely to cause unpredictable issues (from 30.0.4 to 29.0.3.4) ()
                  • ShaiS Shai
                    30.0.4
                    Is this the version field you filled in?
                    • ShaiS
                      ShaiS
                      Shai
                      @girish
                      Yes.
                        @Shai I think you have to contact us at support@ at this point, if you want us to fix it.
                        • timconsidineT
                          Off-topic perhaps but after you have recovered your Nextcloud deployment …
                          Worth considering some kind of free space monitoring?
                          Various server monitor apps/agents, but simplest is a bash script run as a cron using ntfy to send alerts.
                          I get a daily notification of disk free space, and an “intra-day” alert if anything spikes over a set level.
                          I’m not judging, been there too, but poking yourself in the eye repeatedly doesn’t seem a good idea. Incidents happen, I know, the trick is to learn from them. ‘Root cause’ ‘corrective action’ blah blah blah
                          S 1 Reply Last reply
                            S
                            S
                            SolarSimon
                            @timconsidine said in Problem restarting Nextcloud after Disk Full Event:
                            is there a good tutorial somewhere? I also ran once into that case and would love automated monitoring.
                            The new notification support of cloudron 8.2 does not cover that case?
