  2. MiroTalk
  3. Are alias-domains possible for Mirotalk?
Scheduled Pinned Locked Moved Solved MiroTalk
aliasmirotalk
7 Posts 4 Posters 2.8k Views 4 Watching
  • M
    msbt
    App Dev Super Fan
    wrote on last edited by msbt
    I have a Mirotalk instance that I use for my own stuff on miro.example.com. Is it possible to add alias domains, so a customer could use talk.customerdomain.com with the same instance as mine? Thus saving resources and not having to install the app several times. I know this is possible with Nextcloud (not on Cloudron though I believe), would be nice to have that possibility, if technically feasible.
    MiroTalkM 1 Reply Last reply
      I have added this flag for all the apps.
      • M msbt
        MiroTalkM
        MiroTalkM
        MiroTalk
        App Maintainer
        @msbt said in Are alias-domains possible for Mirotalk?:
        You can embedding your MiroTalk instance into any website (talk.customerdomain.com) or app easily using an iframe:
        <iframe
          allow="camera; microphone; display-capture; fullscreen; clipboard-read; clipboard-write; web-share; autoplay"
          src="https://miro.example.com/newroom"
          style="width: 100vw; height: 100vh; border: 0px;">
        </iframe>
        You can check the MiroTalk SFU example here, or MiroTalk P2P example here.
        This functionality would greatly streamline the management of multiple domains while maintaining a single instance.
        • MiroTalkM MiroTalk
          <iframe
          </iframe>
          msbt
          App Dev Super Fan
          @MiroTalk thanks for your work and input, maybe I should have explained why: This specific example would be for 1:1 sessions for a customer of mine (therapist), where the join-links are supposed to be sent via email (that's why the separate domain, for credibility's sake).
          • MiroTalkM
            MiroTalkM
            MiroTalk
            App Maintainer
            MiroTalk with Alias Domains
            I'm not tested but I think can be archived with something like this:
            Use alias domains (e.g., talk.customerdomain.com) for your MiroTalk instance on the same server. Here's how:
            1. DNS Configuration
            • A Record: Point talk.customerdomain.com to your server's IPv4 address.
            • CNAME Record: Alternatively, alias talk.customerdomain.com to miro.example.com.
            2. Web Server Configuration
            Nginx Configuration:
            server {
                listen 80;
                server_name miro.example.com talk.customerdomain.com;
                location / {
                    proxy_pass http://127.0.0.1:3000;
                    proxy_set_header Host $host;
                    proxy_set_header X-Real-IP $remote_addr;
            Apache Configuration:
            <VirtualHost *:80>
                ServerName miro.example.com
                ServerAlias talk.customerdomain.com
                ProxyPreserveHost On
                ProxyPass / http://127.0.0.1:3000/
                ProxyPassReverse / http://127.0.0.1:3000/
            </VirtualHost>
            3. SSL Configuration
            Generate SSL certificates for both domains using Certbot:
            sudo certbot --nginx -d miro.example.com -d talk.customerdomain.com
            # OR
            sudo certbot --apache -d miro.example.com -d talk.customerdomain.com
            Ensure your web server is configured to include SSL settings for both domains.
            4. Cross-Origin Requests (CORS)
            If necessary, adjust MiroTalk or web server settings to allow CORS for talk.customerdomain.com.
            5. Testing
            • Verify that talk.customerdomain.com resolves to your server.
            • Access MiroTalk through both miro.example.com and talk.customerdomain.com to ensure everything works as expected.
            jdaviescoatesJ M 2 Replies Last reply
              server {
                  listen 80;
                  location / {
              <VirtualHost *:80>
              </VirtualHost>
              # OR
              5. Testing
              Super Fan
              @MiroTalk It probably just needs @staff to add alias stuff to the Cloudron package like some other apps like WordPress already have
                server {
                    listen 80;
                    location / {
                <VirtualHost *:80>
                </VirtualHost>
                # OR
                5. Testing
                msbt
                App Dev Super Fan
                @MiroTalk thanks for the detailed writeup. Looks good and as @jdaviescoates suggested, this probably only needs aliases enabled in the manifest and we're good to go 😄
                  • M msbt marked this topic as a question on
                  • M msbt has marked this topic as solved on
