  2. Chatwoot
  3. Chatwoot on 4.2.0, but no Build info in settings
Scheduled Pinned Locked Moved Chatwoot
5 Posts 5 Posters 1.7k Views 5 Watching
  • D Offline
    D Offline
    djtilo-ol
    wrote on last edited by djtilo-ol
    Hi there,
    we're using Chatwoot on Cloudron - install and so on worked great. Now we have booked a premium account to use Captain, but it doesn't show up. Chatwoot's support is asking for the Build version, but apparently it does not show up in the Cloudron-Version 4.2.0, so I am a bit stuck.
    Should look like this:
    Is:
    Any ideas on what I can do?
    I have added the OpenAI Key, as required by the support, as I have done in other applications, too.
    Best wishes,
    John Alistair
    • nebulonN Away
      nebulonN Away
      the app package is built from their release tag: https://git.cloudron.io/packages/chatwoot-app/-/blob/master/Dockerfile?ref_type=heads#L32
      Maybe we miss some env variable to specify the build sha, but the tag is https://github.com/chatwoot/chatwoot/releases/tag/v4.2.0 so b76ec87
      • A Offline
        A Offline
        A_Gladiatek
        Where is the tag 'https://github.com/chatwoot/chatwoot/releases/tag/v4.2.0' located in Chatwoot?
        • v_shnuV Offline
          v_shnuV Offline
          v_shnu
          @nebulon This PR should fix the issue
          https://git.cloudron.io/packages/chatwoot-app/-/merge_requests/17
          • girishG Do not disturb
            @v_shnu thanks for the fix. Merged and published the new package.
