  2. Vaultwarden
  3. SIGNUPS_ALLOWED=false doesn't work for me.
Scheduled Pinned Locked Moved Vaultwarden
14 Posts 5 Posters 4.3k Views 5 Watching
  • luckowL
    luckowL
    luckow
    Someone else with this?:
    • env-sh file = export SIGNUPS_ALLOWED=false
    • restarting the app
    • https://vaultwarden.example.org with a link Create account
    • Filling out the form & submitting ends up with an email
    Thank you for creating an account at https://vaultwarden.example.org You may now log in with your new account.
    If you did not request to create an account, you can safely ignore this email.
    And yes: It looks like a fully functional account of a Vaultwarden instance where the admin has decided not to allow registrations.
    • luckowL luckow
      @luckow said in SIGNUPS_ALLOWED=false doesn't work for me.:
      I don't follow this step/ what you are talking about here?
      I just visited my own instance and don't see any Create account option.
      • jdaviescoatesJ
        • jdaviescoatesJ
          But, I'm also very confused, because I don't have the option enable in my instance!
          I just have this with it still all commented out 🤔
          # Export bitwarden rs environment variables here to ovveride the defaults
          #export SIGNUPS_ALLOWED=false
          #export INVITATIONS_ALLOWED=true
          # To only allow users with the same email domain as where the app is installed:
          #export SIGNUPS_DOMAINS_WHITELIST=ud.coop
          export LOG_LEVEL=info
          • andreasduerenA
            andreasduerenA
            andreasdueren
            Interesting, I can reproduce this. Looks like Vaultwarden will neither respect the config in the config file, env or admin backend.
              @andreasdueren but how have I manged to not have that link showing on my instance?!? 🤔
                andreasduerenA
                andreasduerenA
                andreasdueren
                @jdaviescoates Anyhting in the config.json?
                  @andreasdueren I do indeed have this in there:
                  "signups_allowed": false,
                  So perhaps that's it!
                  I was just trying to login to /admin/ to see what I could see there too, but using the admin token in my config.json doesn't seem to be working for me 🤔
                    Aha, the docs says:
                    The token to login to the admin page is the password you entered above to generate the ADMIN_TOKEN.
                    I hadn't spotted that on a quick read!
                    I managed to login and see this unchecked box there too:
                      Hello @luckow
                      From the Cloudron doc https://docs.cloudron.io/packages/vaultwarden/#users
                      By default, open registration is enabled. This can be changed via the config variables by editing /app/data/config.json using the File Manager. For example, to disable signup but allow invitations set the variables as below:
                        "invitations_allowed": true,>
                      Did you try this instead of the env-sh file?
                      Edit: for some reason my post got delayed for multiple minutes. Ignore this.
                        Hello @luckow
                        @james I guess perhaps this stuff should be remove from the env.sh file in the package given they seemingly don't do anything and lead to this confusion:
                          I remember fixing this. I guess very old installations (2022) still have the above comment and env variables . https://git.cloudron.io/packages/vaultwarden-app/-/commit/7de942dcc2ae45294b78ec22931fba906e5c64a1
                            @girish is it safe to just delete the left over env.sh and/ or is there a reason to keep it for other settings? 🤷
                              @jdaviescoates the comment in the package says there are some values that can only be set in env . But I cannot find what they are . AFAICT, it is safe to empty it out.
