  2. Pixelfed
  3. Pixelfed not starting, some kind of DB error it seems
Scheduled Pinned Locked Moved Pixelfed
11 Posts 3 Posters 1.2k Views 3 Watching
  • scookeS Offline
    scookeS Offline
    scooke
    It may have started with the Sept update. All my backups are only for the current version so I can't restore to an earlier version to see what happens. This is from the logs:
    Oct 13 22:06:57 "}
    Oct 13 22:06:57 2025-10-13T15:06:57Z
    Oct 13 22:06:57 Illuminate\Database\QueryException
    Oct 13 22:06:57 SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'custom_filter_statuses' already exists (Connection: mysql, SQL: create table `custom_filter_statuses` (`id` bigint unsigned not null auto_increment primary key, `custom_filter_id` bigint unsigned not null, `status_id` bigint unsigned not null, `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
    Oct 13 22:06:57 at vendor/laravel/framework/src/Illuminate/Database/Connection.php:824
    Oct 13 22:06:57 820▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
    Oct 13 22:06:57 821▕ );
    Oct 13 22:06:57 822▕ }
    Oct 13 22:06:57 823▕
    Oct 13 22:06:57 ➜ 824▕ throw new QueryException(
    Oct 13 22:06:57 825▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
    Oct 13 22:06:57 826▕ );
    Oct 13 22:06:57 827▕ }
    Oct 13 22:06:57 828▕ }
    Oct 13 22:06:57 +9 vendor frames
    Oct 13 22:06:57 10 database/migrations/2025_04_08_103433_create_custom_filter_statuses_table.php:14
    Oct 13 22:06:57 Illuminate\Support\Facades\Facade::__callStatic()
    Oct 13 22:06:57 +25 vendor frames
    Oct 13 22:06:57 36 artisan:35
    Oct 13 22:06:57 Illuminate\Foundation\Console\Kernel::handle()
    Any ideas?
      Seems like it has many uncomplete database migrations. Give it double the RAM temporarily and see if they complete. Watch the graphs to see how much it actually uses.
      • scookeS Offline
        scookeS Offline
        scooke
        I gave it 6GB, and it still stalls on the one table already existing.
        Oct 14 12:48:30 2025-10-14T05:48:30Z
        Oct 14 12:48:30 Illuminate\Database\QueryException
        Oct 14 12:48:30 SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'custom_filter_statuses' already exists (Connection: mysql, SQL: create table `custom_filter_statuses` (`id` bigint unsigned not null auto_increment primary key, `custom_filter_id` bigint unsigned not null, `status_id` bigint unsigned not null, `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
        Oct 14 12:48:30 at vendor/laravel/framework/src/Illuminate/Database/Connection.php:824
        Oct 14 12:48:30 820▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
        Oct 14 12:48:30 821▕ );
        Oct 14 12:48:30 822▕ }
        Oct 14 12:48:30 823▕
        Oct 14 12:48:30 ➜ 824▕ throw new QueryException(
        Oct 14 12:48:30 825▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
        Oct 14 12:48:30 826▕ );
        Oct 14 12:48:30 827▕ }
        Oct 14 12:48:30 828▕ }
        Oct 14 12:48:30 +9 vendor frames
        Oct 14 12:48:30 10 database/migrations/2025_04_08_103433_create_custom_filter_statuses_table.php:14
        Oct 14 12:48:30 Illuminate\Support\Facades\Facade::__callStatic()
        Oct 14 12:48:30 +25 vendor frames
        Oct 14 12:48:30 36 artisan:35
        Oct 14 12:48:30 Illuminate\Foundation\Console\Kernel::handle()
        Oct 14 12:48:43 ==> Creating directories
        Oct 14 12:48:43 ==> Creating caches
        Oct 14 12:48:44 2025-10-14T05:48:44Z
        Oct 14 12:48:44 INFO Configuration cached successfully.
        Oct 14 12:48:45 2025-10-14T05:48:45Z
        Oct 14 12:48:45 INFO Application cache cleared successfully.
        Oct 14 12:48:46 2025-10-14T05:48:46Z
        Oct 14 12:48:46 INFO Routes cached successfully.
        Oct 14 12:48:47 2025-10-14T05:48:47Z
        Oct 14 12:48:47 INFO Blade templates cached successfully.
        Oct 14 12:48:47 ==> Running migrations
        Oct 14 12:48:48 2025-10-14T05:48:48Z
        Oct 14 12:48:48 INFO Running migrations.
        Oct 14 12:48:48 2025_04_08_103433_create_custom_filter_statuses_table ......... 25.95ms FAIL
        Oct 14 12:48:48 [2025-10-14 05:48:48] production.ERROR: SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'custom_filter_statuses' already exists (Connection: mysql, SQL: create table `custom_filter_statuses` (`id` bigint unsigned not null auto_increment primary key, `custom_filter_id` bigint unsigned not null, `status_id` bigint unsigned not null, `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci') {"exception":"[object] (Illuminate\\Database\\QueryException(code: 42S01): SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'custom_filter_statuses' already exists (Connection: mysql, SQL: create table `custom_filter_statuses` (`id` bigint unsigned not null auto_increment primary key, `custom_filter_id` bigint unsigned not null, `status_id` bigint unsigned not null, `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci') at /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php:824)
        Oct 14 12:48:48 [stacktrace]
        Oct 14 12:48:48 #0 /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php(778): Illuminate\\Database\\Connection->runQueryCallback()
        Oct 14 12:48:48 #1 /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php(559): Illuminate\\Database\\Connection->run()
        Oct 14 12:48:48 #2 /app/code/vendor/laravel/framework/src/Illuminate/Database/Schema/Blueprint.php(119): Illuminate\\Database\\Connection->statement()
        Oct 14 12:48:48 #3 /app/code/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php(618): Illuminate\\Database\\Schema\\Blueprint->build()
        Oct 14 12:48:48 #4 /app/code/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php(472): Illuminate\\Database\\Schema\\Builder->build()
        Oct 14 12:48:48 #5 /app/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(361): Illuminate\\Database\\Schema\\Builder->create()
        Oct 14 12:48:48 #6 /app/code/database/migrations/2025_04_08_103433_create_custom_filter_statuses_table.php(14): Illuminate\\Support\\Facades\\Facade::__callStatic()
        Oct 14 12:48:48 #7 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(514): Illuminate\\Database\\Migrations\\Migration@anonymous->up()
        Oct 14 12:48:48 #8 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(439): Illuminate\\Database\\Migrations\\Migrator->runMethod()
        Oct 14 12:48:48 #9 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(448): Illuminate\\Database\\Migrations\\Migrator->Illuminate\\Database\\Migrations\\{closure}()
        Oct 14 12:48:48 #10 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(250): Illuminate\\Database\\Migrations\\Migrator->runMigration()
        Oct 14 12:48:48 #11 /app/code/vendor/laravel/framework/src/Illuminate/Console/View/Components/Task.php(41): Illuminate\\Database\\Migrations\\Migrator->Illuminate\\Database\\Migrations\\{closure}()
        Oct 14 12:48:48 #12 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(809): Illuminate\\Console\\View\\Components\\Task->render()
        Oct 14 12:48:48 #13 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(250): Illuminate\\Database\\Migrations\\Migrator->write()
        Oct 14 12:48:48 #14 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(210): Illuminate\\Database\\Migrations\\Migrator->runUp()
        Oct 14 12:48:48 #15 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(137): Illuminate\\Database\\Migrations\\Migrator->runPending()
        Oct 14 12:48:48 #16 /app/code/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php(116): Illuminate\\Database\\Migrations\\Migrator->run()
        Oct 14 12:48:48 #17 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(666): Illuminate\\Database\\Console\\Migrations\\MigrateCommand->Illuminate\\Database\\Console\\Migrations\\{closure}()
        Oct 14 12:48:48 #18 /app/code/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php(109): Illuminate\\Database\\Migrations\\Migrator->usingConnection()
        Oct 14 12:48:48 #19 /app/code/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php(88): Illuminate\\Database\\Console\\Migrations\\MigrateCommand->runMigrations()
        Oct 14 12:48:48 #20 /app/code/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Database\\Console\\Migrations\\MigrateCommand->handle()
        Oct 14 12:48:48 #21 /app/code/vendor/laravel/framework/src/Illuminate/Container/Util.php(43): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
        Oct 14 12:48:48 #22 /app/code/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(96): Illuminate\\Container\\Util::unwrapIfClosure()
        Oct 14 12:48:48 #23 /app/code/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\\Container\\BoundMethod::callBoundMethod()
        Oct 14 12:48:48 #24 /app/code/vendor/laravel/framework/src/Illuminate/Container/Container.php(780): Illuminate\\Container\\BoundMethod::call()
        Oct 14 12:48:48 #25 /app/code/vendor/laravel/framework/src/Illuminate/Console/Command.php(211): Illuminate\\Container\\Container->call()
        Oct 14 12:48:48 #26 /app/code/vendor/symfony/console/Command/Command.php(318): Illuminate\\Console\\Command->execute()
        Oct 14 12:48:48 #27 /app/code/vendor/laravel/framework/src/Illuminate/Console/Command.php(180): Symfony\\Component\\Console\\Command\\Command->run()
        Oct 14 12:48:48 #28 /app/code/vendor/symfony/console/Application.php(1092): Illuminate\\Console\\Command->run()
        Oct 14 12:48:48 #29 /app/code/vendor/symfony/console/Application.php(341): Symfony\\Component\\Console\\Application->doRunCommand()
        Oct 14 12:48:48 #30 /app/code/vendor/symfony/console/Application.php(192): Symfony\\Component\\Console\\Application->doRun()
        Oct 14 12:48:48 #31 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(197): Symfony\\Component\\Console\\Application->run()
        Oct 14 12:48:48 #32 /app/code/artisan(35): Illuminate\\Foundation\\Console\\Kernel->handle()
        Oct 14 12:48:48 #33 {main}
        Oct 14 12:48:48 [previous exception] [object] (PDOException(code: 42S01): SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'custom_filter_statuses' already exists at /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php:570)
        Oct 14 12:48:48 #0 /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php(570): PDOStatement->execute()
        Oct 14 12:48:48 #1 /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php(811): Illuminate\\Database\\Connection->Illuminate\\Database\\{closure}()
        Oct 14 12:48:48 #2 /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php(778): Illuminate\\Database\\Connection->runQueryCallback()
        Oct 14 12:48:48 #3 /app/code/vendor/laravel/framework/src/Illuminate/Database/Connection.php(559): Illuminate\\Database\\Connection->run()
        Oct 14 12:48:48 #4 /app/code/vendor/laravel/framework/src/Illuminate/Database/Schema/Blueprint.php(119): Illuminate\\Database\\Connection->statement()
        Oct 14 12:48:48 #5 /app/code/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php(618): Illuminate\\Database\\Schema\\Blueprint->build()
        Oct 14 12:48:48 #6 /app/code/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php(472): Illuminate\\Database\\Schema\\Builder->build()
        Oct 14 12:48:48 #7 /app/code/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(361): Illuminate\\Database\\Schema\\Builder->create()
        Oct 14 12:48:48 #8 /app/code/database/migrations/2025_04_08_103433_create_custom_filter_statuses_table.php(14): Illuminate\\Support\\Facades\\Facade::__callStatic()
        Oct 14 12:48:48 #9 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(514): Illuminate\\Database\\Migrations\\Migration@anonymous->up()
        Oct 14 12:48:48 #10 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(439): Illuminate\\Database\\Migrations\\Migrator->runMethod()
        Oct 14 12:48:48 #11 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(448): Illuminate\\Database\\Migrations\\Migrator->Illuminate\\Database\\Migrations\\{closure}()
        Oct 14 12:48:48 #12 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(250): Illuminate\\Database\\Migrations\\Migrator->runMigration()
        Oct 14 12:48:48 #13 /app/code/vendor/laravel/framework/src/Illuminate/Console/View/Components/Task.php(41): Illuminate\\Database\\Migrations\\Migrator->Illuminate\\Database\\Migrations\\{closure}()
        Oct 14 12:48:48 #14 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(809): Illuminate\\Console\\View\\Components\\Task->render()
        Oct 14 12:48:48 #15 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(250): Illuminate\\Database\\Migrations\\Migrator->write()
        Oct 14 12:48:48 #16 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(210): Illuminate\\Database\\Migrations\\Migrator->runUp()
        Oct 14 12:48:48 #17 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(137): Illuminate\\Database\\Migrations\\Migrator->runPending()
        Oct 14 12:48:48 #18 /app/code/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php(116): Illuminate\\Database\\Migrations\\Migrator->run()
        Oct 14 12:48:48 #19 /app/code/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php(666): Illuminate\\Database\\Console\\Migrations\\MigrateCommand->Illuminate\\Database\\Console\\Migrations\\{closure}()
        Oct 14 12:48:48 #20 /app/code/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php(109): Illuminate\\Database\\Migrations\\Migrator->usingConnection()
        Oct 14 12:48:48 #21 /app/code/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php(88): Illuminate\\Database\\Console\\Migrations\\MigrateCommand->runMigrations()
        Oct 14 12:48:48 #22 /app/code/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Database\\Console\\Migrations\\MigrateCommand->handle()
        Oct 14 12:48:48 #23 /app/code/vendor/laravel/framework/src/Illuminate/Container/Util.php(43): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
        Oct 14 12:48:48 #24 /app/code/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(96): Illuminate\\Container\\Util::unwrapIfClosure()
        Oct 14 12:48:48 #25 /app/code/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\\Container\\BoundMethod::callBoundMethod()
        Oct 14 12:48:48 #26 /app/code/vendor/laravel/framework/src/Illuminate/Container/Container.php(780): Illuminate\\Container\\BoundMethod::call()
        Oct 14 12:48:48 #27 /app/code/vendor/laravel/framework/src/Illuminate/Console/Command.php(211): Illuminate\\Container\\Container->call()
        Oct 14 12:48:48 #28 /app/code/vendor/symfony/console/Command/Command.php(318): Illuminate\\Console\\Command->execute()
        Oct 14 12:48:48 #29 /app/code/vendor/laravel/framework/src/Illuminate/Console/Command.php(180): Symfony\\Component\\Console\\Command\\Command->run()
        Oct 14 12:48:48 #30 /app/code/vendor/symfony/console/Application.php(1092): Illuminate\\Console\\Command->run()
        Oct 14 12:48:48 #31 /app/code/vendor/symfony/console/Application.php(341): Symfony\\Component\\Console\\Application->doRunCommand()
        Oct 14 12:48:48 #32 /app/code/vendor/symfony/console/Application.php(192): Symfony\\Component\\Console\\Application->doRun()
        Oct 14 12:48:48 #33 /app/code/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(197): Symfony\\Component\\Console\\Application->run()
        Oct 14 12:48:48 #34 /app/code/artisan(35): Illuminate\\Foundation\\Console\\Kernel->handle()
        Oct 14 12:48:48 #35 {main}
        Oct 14 12:48:48 "}
        Oct 14 12:48:48 Illuminate\Database\QueryException
        Oct 14 12:48:48 SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'custom_filter_statuses' already exists (Connection: mysql, SQL: create table `custom_filter_statuses` (`id` bigint unsigned not null auto_increment primary key, `custom_filter_id` bigint unsigned not null, `status_id` bigint unsigned not null, `created_at` timestamp null, `updated_at` timestamp null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
        Oct 14 12:48:48 at vendor/laravel/framework/src/Illuminate/Database/Connection.php:824
        Oct 14 12:48:48 820▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
        Oct 14 12:48:48 821▕ );
        Oct 14 12:48:48 822▕ }
        Oct 14 12:48:48 823▕
        Oct 14 12:48:48 ➜ 824▕ throw new QueryException(
        Oct 14 12:48:48 825▕ $this->getName(), $query, $this->prepareBindings($bindings), $e
        Oct 14 12:48:48 826▕ );
        Oct 14 12:48:48 827▕ }
        Oct 14 12:48:48 828▕ }
        Oct 14 12:48:48 +9 vendor frames
        Oct 14 12:48:48 10 database/migrations/2025_04_08_103433_create_custom_filter_statuses_table.php:14
        Oct 14 12:48:48 Illuminate\Support\Facades\Facade::__callStatic()
        Oct 14 12:48:48 +25 vendor frames
        Oct 14 12:48:48 36 artisan:35
        Oct 14 12:48:48 Illuminate\Foundation\Console\Kernel::handle()
        • scookeS Offline
          scookeS Offline
          scooke
          Am I gonna have to go into that db manually and do something?
            Yep, probably.. unless you can restore from a good backup.
            scookeS 1 Reply Last reply
              Hello @scooke
              Can you please share with my what cloudron app package version of Pixelfed you were running before the update so I can attempt reproducing this issue?
              • scookeS Offline
                scookeS Offline
                scooke
                It was updated to package version 1.22.2 on 09/06/2025, and it seems the problem started then. So, whatever version was before 1.22.2. Based on the Alerts in my Cloudron, the previous update was updated to package version 1.22.0 on 06/14/2025. So the jump from 1.22.0 to 1.22.2 did something, it seems.
                  scookeS Offline
                  scookeS Offline
                  scooke
                  @robi Unfortunately my backup duration is only a month, so all I have are 1.22.2 backups, and I've tried a few of them but the same issue occurs.
                    Hello @scooke
                    Thanks for that. I will look into it and try to reproduce your issue.
                      Hello @scooke
                      scookeS Offline
                      scookeS Offline
                      scooke
                      @james Any luck?
                        Hello @scooke
                        Sorry, I was not able to start working on this issue yet.
