  2. Baserow
  3. Does Baserow automation work in Cloudron?
Scheduled Pinned Locked Moved Baserow
5 Posts 3 Posters 1.1k Views 3 Watching
  • jeauJ
    jeauJ
    jeau
    I was excited to see the automation feature in Baserow.
    I could be wrong, but I can't get automation to work in the Cloudron Baserow app, in my installation, or with the Cloudron demo. The same operation works with my account on https://baserow.io/
    Here's what I'm doing, as simply as possible:
    • Creation of a new project
    • Addition of a database, with a default table
    • Addition of automation
    • Activate “lines created” node withs parameters: connection to the database and table created by default
    • Launch of Test event (no publication), create a new line in table
    Results:
    • this élément de liste test is OK on my test project on the baserow.io cloud
    • the test produces nothing on my test project on my Cloudron.
    I repeated this simple test on the Cloudron demo instance by activating the baserow application, and the problem is exactly the same.
    Have you noticed the same problem?
    I posted an issue on the Baserow forum.
    I feel like I'm making a mistake, but I don't see what the problem is.
      Hello @jeau
      Thanks for reporting.
      I was able to reproduce this and I am looking into a fix.
        Hello @jeau
        I have found the issue and a fix is currently being build.
        An app update will be available soon.
        • jeauJ
          jeauJ
          jeau
          thanks @james
          • klawitterbK
            klawitterbK
            klawitterb
            @james i've noticed that my baserow instance now runs into out of memory after update to 1.33.3 (or .4, not sure). Either it now needs loads of more memory or there's something wrong, had increased memory limit from 5gb to 6.5 gb and it still wasn't enough.
