  2. OpenWebUI
  3. "Ollama: Network Problem" Error in OpenWebUI
3 Posts 3 Posters 2.7k Views 3 Watching
  • O
    O
    omnichannel
    I am sure this is a tale as old as time but here goes. Looking for some help with an unresolved error. OpenWebUI has been configured with the FQDN of Ollama.DOMAIN.COM as outlined in the documentation. API key from Ollama cat /app/data/.api_key was pasted and verified. When verifying the connection, an “Ollama: Network Problem” error modal appears on screen.
      Hello @omnichannel and welcome to the Cloudron community
      The internal Ollama server has been removed from the @openwebui package some versions ago.
      You will have to install the @ollama app and setup OpenWebUi to use that one.
      Same topic as https://forum.cloudron.io/topic/14645/how-to-configure-ollama-in-openwebui
      • O omnichannel
        @omnichannel I’m using openwebui and ollama apps installed in the same Cloudron instance.
        In openwebui Admin settings, under Connections, I am using similar to what you have.
        Server connection is verified.
