  2. IT-Tools
  3. IT-Tools and OIDC - Looping issue
Scheduled Pinned Locked Moved Solved IT-Tools
22 Posts 5 Posters 3.7k Views 5 Watching
  • T
    T
    Teiluj
    We have this app setup with Cloudron OIDC authentication.
    For a single user (as far as I know), attempting to log in result in a loop:
    • the user accesses the login page and press the login button
    • he is being redirected to the OIDC authentication
    • After authenticating, instead of access the IT-tools app, he is redirected to the login page again with for only option to press the login button.
    Other users appear unaffected.
    Installing a second iteration of the app with the same (simple) setup result in the same behavior.
    There is no apparent errors in the logs of the app.
    Has someone come across this already?
    any suggestions how to resolve this?
    Many thanks,
      Hello @teiluj
      For that single user, does his username have special characters?
      Does he have a first and last name in his profile or just a single string?
      T 1 Reply Last reply
        Hello @teiluj
        T
        T
        Teiluj
        Hi @james,
        This single user's username does not contain any special character - the username is literally a sequence of character aka a single string.
        It also follows the same naming scheme as other users for which the application works.
        This leaves me baffled for now.
        Many thanks,
          Hello @teiluj
          Since the @it-tools app uses Cloudron Proxyauth I assume this might be some strange caching issue.
          Can you ask the user to try it in a private browser window?
            Hello @teiluj
            T
            T
            Teiluj
            Hi @james - Yes, we have done this and no success. I also have to mention that this has been going on for this one user for months now.
              Hello @teiluj
              Is it just the @it-tools app or are other apps affected as well?
              • T
                T
                Teiluj
                Hi @james
                Currently the issue is only affecting that particular user, with that particular @it-tools app.
                • T Teiluj
                  Hi @james
                  Super Fan
                  @Teiluj have you tried impersonating that user? If you can reproduce yourself you might be able to get further insight.
                    T
                    T
                    Teiluj
                    Hi @jdaviescoates - Many thanks for your idea.
                    Impersonating the user present the same loop problem unfortunately.
                    jamesJ jdaviescoatesJ 2 Replies Last reply
                    • T Teiluj
                      Hello @Teiluj
                      Can you please share the details for that user so we can try to reproduce this issue?
                      • T Teiluj
                        Super Fan
                        @Teiluj there might be some clues in the browser console when doing it as the user?
                        • T
                          T
                          Teiluj
                          A short update: this seems to point at a server issue.
                          Using the same computer and the same browser, I installed the app on a different server, and was able to log into the app successfully, using the same user credentials (the user authentication comes from LDAP sync from a 3rd cloudron server)
                          I can also confirm that on that one server, where the user is having the issue, clearing the browser's cache or using a different browser/computer, does not solve the problem.
                          @james - Happy to share more details as far as possible, but considering the above, I doubt that this is easily reproducible.
                            T
                            T
                            Teiluj
                            @jdaviescoates Thanks for the suggestion - I cannot see anything of significance there either.
                            • T
                              T
                              Teiluj
                              ok - I was hoping that somehow the move to the fork would help with this, but actually, there is no change, still looping.
                              Any ideas how to go and troubleshoot this further?
                              Many thanks,
                                Hello @teiluj
                                You did not yet share the erroring user details like username, first and last name so we could try to reproduce it.
                                • T
                                  T
                                  Teiluj
                                  Hi @james - Thanks for your willing help.
                                  For security/confidentiality reasons, these are elements of information that are difficult to share on a public forum. I could eventually share this in a private context, but I can confirm that there is absolutely nothing special about both username and the name of the user. I hope that it makes sense.
                                  Just as a short recap about this:
                                  • the server where the application is installed has its user directory LDAP synced from another Cloudron. The user facing the issue is a synced user
                                  • The cloudron sso-enabled application used to work with this particular user, until it stopped and created this looping issue
                                  • it only happens for this user on this server for this app:
                                    • Other cloudron sso-enabled apps on this same server have no issue with this user.
                                    • Other users using the IT-Tools app on this same server have no looping issues
                                    • On the same server, with a newly/secondary installed IT-Tools app instance, the same user still faces the looping issue.
                                    • both the server log as well as the app log do not show anything of note regarding this. In fact, the event log of the app shows the user has "logged into" the app.
                                    • On another server, with the user directory also synced, with the IT-Tools app installed there, the same user does not experience the looping issue.
                                    • the looping error persists even when using different machines / different browsers / clearing the browser's cache, etc...
                                  I hope that this helps somehow.
                                  • T Teiluj
                                    Super Fan
                                    @Teiluj said in IT-Tools and OIDC - Looping issue:
                                    TBH I'd probably just be inclined to just use that instance 🙂
                                      T
                                      T
                                      Teiluj
                                      @jdaviescoates Thanks - Not the I have not though about this, but, at last, this could only be a temporary solution following our infrastructure setup.
                                      It also does not solve the underlying OIDC issue, which I very much find intriguing.
                                      • T
                                        T
                                        Teiluj
                                        So, I did not update the thread for a while, but I can confirm that for this same synced-in user, this is happening what ever the server the application is installed on.
                                        Only this user.
                                        No idea why, and how to debug this further - This is pretty annoying, since the user is me 😠
                                        Any idea how to go on about this?
                                        • J
                                          @teiluj if it's reproducible, you can write to us at support@cloudron.io and I can take a look.
                                          If I am understanding this correctly, you are saying you cannot log in at all in any app? And you keep OIDC login looping?
