  3. Node-RED - Flow-based programming for the Internet of Things
ideiot
33 Posts 14 Posters 17.4k Views 12 Watching
  • H hendrikvl
    I've been working on a Cloudron-app for Node-RED as well. Using node-red-docker and adapting it to Cloudron felt too complicated to me. So, as opposed to the app package that @staypath has been working on, I started with a Cloudron package from scratch.
    You can find my repo here: https://git.vereint-digital.de/hendrik/node-red-app
    Node-RED itself is simply installed through npm, so the code does not come bundled in the repo itself. Since Node-RED does rely on npm quite a lot anyhow, that seemed more straightforward to me. Plus it makes the Dockerfile really simple.
    The code of Node-RED itself (including three modules that are installed out of the box) is located in /app/code. The node-red userdir is in /app/data. So updates of node-red should work, but I've not been testing it long enough to tell.
    The app package uses the Cloudron sendmail and mongodb addons. Mails can be sent using node-red-contrib-sendmail and the database can be accessed using node-red-contrib-mongodb4. Both modules come preinstalled and are preconfigured using the environment variables that Cloudron exports.
    I must say though, that I do not feel too confident about my solution to send mails. I initially thought, that it would be easier to utilize a command line mail utility, but it turned out to be quite complex as well. In the end, I had to write my own script to act as mail utility, so that it matches the assumptions of node-red-contrib-sendmail. Writing a custom Node-RED module that uses Nodemailer and accesses the Cloudron environment variables probably would have been a better approach.
    For authorization, I currently use Cloudron proxyauth and only leave one route (/public) unprotected. Since custom user authentication can be implemented in Node-RED quite easily, it would be highly beneficial to have the authenticated user as part of the request headers, as discussed here. Implementing LDAP, as @staypath has done, also has its benefits though. I'm currently a bit indecisive which approach is preferable.
    I hope this is helpful to others, who want to use Node-RED on Cloudron. And maybe we get the discussion on including Node-RED in the app-store going again.
    @hendrikvl This is awesome! Thanks for working on this.
    Nice, as expected of any cloudron app email and db are auto-configured.
    Does node-red have a real concept of users and roles ? Meaning, can individual users create and manage separate flows? When LDAP is implemented, who provides the login page? Is this part of some plugin?
    H J 2 Replies Last reply
      H
      H
      hendrikvl
      @girish said in Node-RED - Flow-based programming for the Internet of Things:
      Both are not required to run Node-RED though. They are optional modules that can be used within flows that one wants to implement, but have no functionality for the core itself. Still, I thought that its useful to be able to access the functionality that Cloudron as a platform provides.
      I'm relatively new to Node-RED myself and can't tell with certainty. As far as I understand the documentation, one can differentiate between users and assign specific permissions for different methods of the API (create a flow, enable a module, etc.), but cannot differentiate between flows. Flows seem to be shared between users in any case. So it's not a real multi-user application, where each user can create their own flows. This post proposes to run multiple node-red instances if users shall be able to create independent flows.
      The login page seems to be the default one provided by Node-RED. It is only the authentication-scheme which is plugged in through an extra module.
      The LDAP-module does not seem to support different permissions though. Each user with valid credentials gets full permissions (see this line).
        jsilence
        @girish any update or estimate on when Node-Red may hit the official release?
        To (as a n00b) It looks like most of the heavy lifting has been done, nor?
        • J jsilence
          marcusquinnM
          marcusquinnM
          @jsilence It's a good question. We've been using it for a while. Bear in mind it doesn't have LDAP, but you might not need that for your use-case.
          • dsp76D
            dsp76D
            dsp76
            Node RED is not just about home automation. We use it regularly to integrate several Cloud Services.
            (Ask me about B2B marketing automation & low code business solutions, if thats interesting for you.)
            • N
              N
              NaPs
              Very interested into Node-red in cloudron! I can see several package proposal in this thread. What can I do to help it being integrated?
              • S
                S
                staypath
                Been a while since I built the Docker version of Node-RED for Cloudron, but it worked with Cloudron LDAP auth when I built it. My method had a single admin user that can access all Node-RED flows, so there's no concept of permissions. That works fine for me, but might not for others. I'd be willing to revisit and update my method to the latest Node-RED version to make sure everything still functions within Cloudron from a backup/restore perspective and with LDAP auth. I know @hendrikvl recommended using the npm approach vs. Docker approach, so it really depends on your needs.
                • S
                  S
                  staypath
                  Actually, looking at @hendrikvl version here: https://git.vereint-digital.de/hendrik/node-red-app. This approach seems simpler for sure. @hendrikvl is there any core Node-RED functionality missing using your method?
                  H 1 Reply Last reply
                  • S staypath
                    H
                    H
                    hendrikvl
                    @staypath Yes, I tried to keep things simple with my approach. I am not aware of any Node-RED core functionality that is not working. By using the Cloudron proxy as auth in front of Node-RED, it is single user only though and would be tricky to combine it with auth-mechanisms within Node-RED. This is probably the biggest downside to my approach.
                    Another thing, that I would do differently is the approach to send out e-mails. I wanted to make use of the per-app smtp settings that Cloudron provides and pre-provision that transparently into Node-RED. That lead to quite some "glue" in between that seemed somewhat disproportionate in the end.
                    I should update my repository to a newer Node-RED version by the way and will probably remove the e-mail part at that point.
                    • M
                      makemrproper
                      wrote on last edited by makemrproper
                      #30
                      Any hopes on seeing this live? A rules based visual code suite would be awesome to have.
                      My cloudron has been up 7 years. My self-hosted docker installs have a much shorter lifespan. This is why I am hoping you would add it here.
                      Cloudron fan
                      Paying Customer
                      • BrutalBirdieB
                        BrutalBirdieB
                        Why not n8n tho? It should be able to do the same.
                        M 1 Reply Last reply
                        • BrutalBirdieB BrutalBirdie
                          makemrproper
                          @BrutalBirdie I guess it suffices. However Node-Red has a minimal resource footprint, really broad ecosystem and the internet has embraced it with code examples et cetera. So Node-Red would enrich the catalog of Cloudron.
                          Cloudron fan
                          Paying Customer
                          • M makemrproper
                            marcusquinnM
                            marcusquinnM
                            @makemrproper We have an instance running on Cloudron @vladimir.d packaged it.
                            Just bear in mind Node-RED doesn't have users, so it's very much a simple shared utility, and you'd need multiple instances if you wanted to separate user access to various things.
