  2. GitLab
  3. Gitlab how to run container registry
Scheduled Pinned Locked Moved GitLab
gitlab
31 Posts 11 Posters 13.7k Views 17 Watching
    I went down the container registry rabbit hole. In the end, it seems that it provides gitlab's authentication layer for the docker registry i.e users/groups/projects have same permissions in the registry as of gitlab. It has a limitation that the registry and the gitlab have to be on the same server. There is some strange path sharing requirement that I don't completely understand - https://docs.gitlab.com/ce/administration/packages/container_registry.html#use-file-system
    I think an alternate approach is get Harbor working. It looks simple enough to deploy since it's a Go app and also has LDAP. This will then work with GitLab CI/CD (nice article). This won't bring in gitlab's auth into the registry though. Are people looking for something like that? (it seems something for big enterprises).
    @girish I just really need a private registry within cloudron.
    Have private code waiting to become a private app and this is a show stopper road block.
      marioM
      marioM
      mario
      @girish I definitely have a use case for this despite not being a super-huge enterprise, which is why I'm trying to get it done. And I will - it's just a matter of time 🙂
      I'm not against Harbor, etc. but I do need this to work which is why I'm on it 🙂
      • marioM mario
        @mario You left me a note somewhere on how to use the docker registry app with GitLab but I cannot find it anymore. Where did you put it?
        marioM 1 Reply Last reply
          marioM
          marioM
          mario
          @girish README inside the repo: https://git.cloudron.io/cloudron/docker-registry-app
          • marioM mario
            @mario 🤦 Sorry I missed the most obvious place, I was looking all over.
            ? 1 Reply Last reply
            • N niels referenced this topic on
              A Former User
              Need Help: Has anyone enabled container registry in the cloudron gitlab, I'm getting error 500 when making changes to the gitlab.yml file.
                registry:
                  enabled: true
                  host: registry.git.arsh.dev
                  port: 5005
                  api_url: http://localhost:5000/ # internal address to the registry, will be used by GitLab to directly communicate with API
                  key: config/registry.key
                  path: shared/registry
                  issuer: gitlab-issuer
              girishG 2 Replies Last reply
              • ? A Former User
                  registry:
                    enabled: true
                    port: 5005
                @arshsahzad said in Gitlab how to run container registry:
                This most likely means there is an error in the yml syntax. What error do you see in the logs ? You will find more logs in /run/gitlab (via web terminal).
                • ? A Former User
                    registry:
                      enabled: true
                      port: 5005
                  @arshsahzad Have you seen https://docs.cloudron.io/apps/docker-registry/#gitlab-integration already ?
                  ? 2 Replies Last reply
                    A Former User
                    wrote on last edited by [[global:former-user]]
                    #29
                    Hi @girish, I have not yet looked into the document, I will let you know...
                      A Former User
                      #30
                      Hi @girish, From the Docs:
                      1. Create a volume named registry-shared.
                      2. Attach volume name registry-shared to both GitLab and Docker Registry apps. Be sure to uncheck the Read Only checkbox.
                      3. Create folders containers and certs on the host filesystem inside the path that is assigned to the registry-shared volume.
                      4. Run the following commands inside the certs folder:
                      openssl req -nodes -newkey rsa:2048 -keyout registry-auth.key -out registry-auth.csr -subj "/CN=gitlab-issuer"
                      openssl x509 -in registry-auth.csr -out registry-auth.crt -req -signkey registry-auth.key -days 365000
                      chmod 777 registry-auth.key registry-auth.crt registry-auth.csr
                      5. Modify the permissions from root to cloudron inside the Docker Registry app for the created folders and files.
                      chown -R cloudron:cloudron /media/registry-shared/
                      6. Modify /app/data/config.yml of the Docker Registry app using the File manager by altering or adding the auth part to resemble the following:
                      auth:
                        token:
                          realm: https://<GITLAB_HOST>/jwt/auth
                          service: container_registry
                          rootcertbundle: /media/registry-shared/certs/registry-auth.crt
                      Change the 'rootdirectory' value inside the same config file to:
                      /media/registry-shared/containers
                      Save the file and restart the app.
                      7. Modify /app/data/gitlab.yml of the GitLab app by adding the following lines (some of them might already be there, so skip them):
                      production:
                        <<: *base
                        registry:
                          enabled: true
                          host: <DOCKER_REGISTRY_HOST>
                          port: 443
                          api_url: https://<DOCKER_REGISTRY_HOST>
                          key: /media/registry-shared/certs/registry-auth.key
                          path: /media/registry-shared/containers
                      1. I have created the directory in the host machine
                      /opt/registry-shared
                      1. Created two other folders (containers & certs) in the registry-shared directory
                      2. Generated keys in certs folders using the following cmd
                      • ? A Former User
                        auth:
                          token:
                        production:
                          <<: *base
                          registry:
                            enabled: true
                            port: 443
                        A Former User
                        1. Attach volume name registry-shared to both GitLab and Docker Registry apps. Be sure to uncheck the Read Only checkbox.
                        I'm not able to figure out, how to attach the bind mount to the running gitlab container and how to uncheck read only checkbox
