  3. SSL does not work normally
certificatescloudflare
7 Posts 3 Posters 3.3k Views 3 Watching
  • bangden07B
    bangden07B
    bangden07
    Either this is a bug or a mistake from me.
    SSL installation failed for my domain.
    But from my side. I only installed the application using the root domain correctly. If it's an error from the cloudron side then please help me to resolve this.
    <screenshot with email redacted>
      I think the error code of 429 indicates a LetsEncrypt rate-limit issue for that domain. Is this possible in your case?
      bangden07B 1 Reply Last reply
        bangden07B
        bangden07B
        bangden07
        @nebulon I am not sure. Because my domain renew 3x.
        If it exceeds the limit. How long is the limit released or renewed again?
          The various rate-limits are explained at https://letsencrypt.org/docs/rate-limits/
          It could also be a temporary issue on LetsEncrypt side, if you believe so, you can renew the certificates manually from the Cloudron dashboard's domain view.
            @bangden07 If you install/uninstall & try many apps in different subdomains, it's best to get a Let's Encrypt wild card cert. On Cloudron, you will get a wild card cert automatically, if you move to a supported DNS provider (like DO, Cloudflare, Route53 etc). Is that an option for you? When you get wildcard certs, you only get 1 cert and that' it.
            Also, if possible, please paste the raw logs instead of a picture next time. The reason is that it's better for SEO purposes and also I can redact stuff a bit better (for example, in the screenshot, you forgot to clear out your gmail info in one place, so I have removed the pic for now).
            • bangden07B
              bangden07B
              bangden07
              Waiting for the limit from Let's Encrypt is too long. Must wait 7 days to be able to create a new certificate. Okay, that doesn't matter, I've worked around this by using Universal SSL from Cloudflare and this works.
                @bangden07 Ah, that's a smart work around! I just noticed that you had SSL issues on the root domain. The wildcard cert only covers subdomains i.e *.foo.com but not foo.com. Cloudron still has to get normal certs for foo.com. I guess after a week, you can remove the cloudflare proxy.
