  3. Backup failing with "copy code: 1, signal: null": "cannot create hard link" "operation not permitted"
backups
26 Posts 3 Posters 3.4k Views 3 Watching
    What I found so far is that the link operation is denied by the kernel. dmesg has the following lines:
    [563683.439933] audit: type=1702 audit(1601496162.706:33): op=linkat ppid=5039 pid=10646 auid=4294967295 uid=1001 gid=1001 euid=1001 suid=1001 fsuid=1001 egid=1001 sgid=1001 fsgid=1001 tty=(none) ses=4294967295 comm="cp" exe="/bin/cp" res=0
    [563683.439938] audit: type=1302 audit(1601496162.706:34): item=0 name="/path/dovecot-uidlist.lock" inode=2246683 dev=fc:20 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=NORMAL cap_fp=0000000000000000 cap_fi=0000000000000000 cap_fe=0 cap_fver=0
    The type= means this from audit.h
    1702 /* Suspicious use of file links */
    1302    /* Filename path information */
    And according to https://access.redhat.com/articles/4409591 it's triggering for some ANOM_LINK event type. So far, there is little to no information on what all this means.
    @girish this sounds to me like a resource or policy type exhaustion issue. Like when ulimit it too low or we run out of inodes.
    Is anything else running in the kernel, like SE Linux?
    Are we hitting limits on hardlinks with large enough backups? I believe the limit on ext4 is 65k
    It would be interesting to switch filesystems and see if it happens on xfs for example.
    Do you have an Object Store target option via S3?
      I think the 65k is the number of hardlinks on a file and not the hardlinks on a file system.
      The rabbit hole goes as deep as we want to 🙂
      I think I found the problem though of course I have to try it out. audit_log_path_denied here - https://elixir.bootlin.com/linux/latest/source/fs/namei.c#L955 is where the audit log is raised. I am no kernel expert but a casual reading of the comment "Allowed if owner and follower match" suggests that the owner of file and the linker is not matching. The symlinking process runs as user yellowtent.
      root@my:/cloudron-backups/snapshot/box/mail# find . -user root -type f
      ./blah/blah/dovecot-uidlist.lock
      ./blah/blah/1600972556.M892349P24001.69d0c668883d,S=6124,W=6234:2,S
      Bingo! For some reason, these 2 specific files are not owner yellowtent and are root. Looks like some bug/race in the code that creates snapshot. Curiously, both the files above are of 0 size, so maybe that's causing some strange event ordering.
        Yay, found the problem 🙂 Issue is that if a file disappears when we are creating the snapshot, the code errors. Usually files in the snapshot are chowned to the yellowtent user but on an error it ends up creating an empty file in the snapshot directory with the root permission. The hard linking code is run as yellowtent user, and thus symlinking fails. Phew!
          Yaay! .. and there was much rejoicing! 😉
          Nicely done.
          That root owned file would be concerning as a local root escalation. What else there runs as root while yellowtent is doing it's thing?
            Fixed with https://git.cloudron.io/cloudron/box/-/issues/741
            d19dotcaD 1 Reply Last reply
              d19dotcaD
              d19dotcaD
              d19dotca
              @girish that’s perfect, great detective work! Thanks Girish for working to solve that. I really appreciate it. I’ll keep an eye on it in my server you patched and see if the issue comes back. Thanks again! 🙂
              Dustin Dauncey
              www.d19.ca
