  2. Feature Requests
  3. Improve Clone/Backup/Restore Speed
backupsclone
24 Posts 9 Posters 13.6k Views 9 Watching
  • jimcavoliJ
    jimcavoliJ
    jimcavoli
    Recently, I accidentally found myself studying this problem. I've relocated backups to GCS recently from DigitalOcean Spaces for one machine...suffice it to say I found the bottleneck in that process. Previously, it appeared to be some traffic management into spaces, and/or the fact that it was heading to the SFO2 region from NYC3 (you know...because...geography). After turning on backups into GCS in the awesome us multi-region automatic replication (nearline), it became very obvious that the main limiting factor was a 10MB/s cap on the disk speed at DO.
    Seriously; here's their graph over the last 7 days for Disk I/O performance (it's pretty obvious where the backups are):
    The main reason this even showed up is that GCS ingest is way faster from a bandwidth perspective:
    Too bad I don't have the old Spaces graph to show as well, but suffice it to say, it wasn't great. So the GCS switchover actually moved the first bottleneck, getting at the main root of the issue.
    I'll update on how things go one the server in question gets itself moved into a GCP instance - by my rough math, there should be a noticeable performance bump in at least backups, but likely systemwide once it transitions into the GCP volumes, which are rated at least 50% faster in the case of the small volumes, and in the big one (apps data), should have a network performance ceiling that is roughly 6x higher than the existing DO volumes. I know this is more on the production/operator side than the personal side of usage, and the problem of "throw more, bigger resources at it" is not one most folks can/would take on a NAS/local server and home internet connection, but it's some interesting data and an intriguing problem in any case.
    • jimcavoliJ jimcavoli
      #22
      @jimcavoli To add to the disk I/O, for the tar.gz backups I have noticed that gzip performance is quite poor on many of the cloud providers (because of the CPU). Initially, I thought this was just node being very slow (thought that seemed a bit unlikely because it is using zlib underneath like everyone else) but I remember comparing with tar and the performance was quite comparable - https://git.cloudron.io/cloudron/box/-/issues/691#note_10936 . That led me down the path of trying to see if there was a parallel zip implementation that uses multiple cores or some special cpu instructions. I found http://www.zlib.net/pigz/ but haven't really found time to test it.
      jimcavoliJ 1 Reply Last reply
        jimcavoliJ
        jimcavoliJ
        jimcavoli
        @girish Interesting, and not something I'd considered. That pigs option is similarly interesting, though seems to have gone silent since 2017. Curiously, it's a similar story with pbzip2 (the same idea for bzip2) as far as I can tell. Decent roundup of options for Ubuntu at https://askubuntu.com/questions/258202/multi-core-compression-tools in case you want to review. It will be interesting to see the GCP results for sure. I'll pull some metrics after the migration/restore as well as after the manual backup and see how it does across CPU/Disk/Network in the process.
        • jimcavoliJ
          jimcavoliJ
          jimcavoli
          Just to follow up, here's a sample of normal backups followed by a Cloudron upgrade, which itself triggered another backup run, and the corresponding relevant network and disk graphs:
          All in all, it's definitely fast-er but not insanely performant. CPU utilization vs load hints that it may in fact be down to inefficient utilization of cores to some extent, but there is definitely a fair bit more bottleneck coming from the network still.
          Nothing earth-shattering either way, and gains were more mild than I would have guessed, but all in all, not a bad outcome.
