  3. docker system df: Total number of images does not equal installed apps
docker
8 Posts 6 Posters 2.9k Views 6 Watching
  • C Offline
    C Offline
    ctrl
    Hello Team,
    I just ran docker system df. It outputs 16 images und 18 containers as a grand total although we only have 8 apps installed currently. Are the remaining images/containers some kind of cruft?
    root@my ~ # docker system df
    TYPE                TOTAL               ACTIVE              SIZE                RECLAIMABLE
    Images              16                  16                  8.133GB             1.45GB (17%)
    Containers          18                  17                  69.63kB             0B (0%)
    Local Volumes       42                  34                  378.4MB             70.35kB (0%)
    Build Cache         0                   0                   0B                  0B
    • MooCloud_MattM Offline
      MooCloud_Matt
      If u use Apps, that need more container, like nextcloud or wp, you need to count redis too, for exemple.
      And there are System Apps to, like Haraka for the email
      Matteo. R.
      Founder and Tech-Support Manager.
      MooCloud MSP
      Swiss Managed Service Provider
      • C Offline
        C Offline
        ctrl
        Thank you very much for the clarification!
        M 1 Reply Last reply
        • C ctrl
          M Offline
          M Offline
          malvim
          wrote on last edited by malvim
          @ctrl Yeah, I think if you run docker ps you'll be able to see what's going on a bit better. The apps use databases like mysql, mongodb, redis; There's also other addons like sftp, mail, turn, and graphite.
          C 1 Reply Last reply
          • M malvim
            C Offline
            C Offline
            ctrl
            @malvim
            Thanks a lot for the follow up!
            • xaddisonX Offline
              xaddisonX Offline
              xaddison
              On this note; where and how should docker prune be implemented? Or is it already somewhere in the Cloudron foundation?
              I was able to drop like 7 old containers outside of Cloudron with:
              sudo docker container prune -f && sudo docker image prune -f
              micmcM girishG 2 Replies Last reply
              • xaddisonX xaddison
                micmcM Offline
                micmcM Offline
                micmc
                @xaddison said in docker system df: Total number of images does not equal installed apps:
                You shouldn't mess with docker on the server where is your Cloudron installation, you shouldn't even update the server, to the risk of breaking your installation and / or some vital functions of it.
                If you want to keep playing docker you should do it on another server because Cloudron is meant to take care of all this by itself. My two cents of advice. 🙂
                (coming soon...)
                  girishG Do not disturb
                  @xaddison the prune is done automatically when needed in the code. Most likely the containers that got removed are the ones that were "stopped". Cloudron runs cron jobs of apps in containers, for example. They will be in stopped state after finishing a run but will be reused in the next run. As for images, not sure what it cleaned up. Do you have the output of what it removed?
