  2. Feature Requests
  3. MySQL tuning with my.cnf settings optimisation
mysqladdonsperformance
11 Posts 5 Posters 6.2k Views 5 Watching
  • marcusquinnM
    marcusquinnM
    I did a bunch of research on this a while back for MySQL my.cnf settings best-practice for optimal RAM & CPU usage, and wrote up here sample settings with typical VPS configs for reference here:
    • https://gitlab.com/d2c.io/wordpress-scalable-lemp-single-server/-/blob/master/configs/my.cnf - Reference
    There's a few things in there I think could be automated based on knowing the VPS RAM & CPU count.
    And a few things that could be admin panel settings, like enabling SQL Profiling and accessing the slow query logs for review.
    TBH, not looked into what you already do but maybe some ideas in here to test. Guessing similar applies to other DBs but I only looked at MySQL & InnoDB as our primary environment.
    Further Reading
    • https://www.wpintense.com/2017/06/12/installing-and-configuring-fastest-possible-wordpress-stack-digital-ocean/
    • http://www.mysqlcalculator.com/
    • https://bugs.mysql.com/bug.php?id=82577
    • https://launchpad.net/mysql-tuning-primer
    • https://www.percona.com/blog/2014/01/28/10-mysql-performance-tuning-settings-after-installation/
    • https://www.percona.com/resources/technical-presentations/optimizing-mysql-configuration-percona-mysql-university-montevideo
    • https://www.wpintense.com/2016/07/26/enable-slow-query-log-and-identify-slow-queries-percona-db/
    LonkleL rmdesR 2 Replies Last reply
    • marcusquinnM marcusquinn
      Further Reading
      LonkleL
      LonkleL
      Lonkle
      wrote on last edited by Lonkle
      @marcusquinn Bookmarked this as a resource, thanks for collecting all of this!
      • LonkleL Lonkle
        marcusquinnM
        marcusquinnM
        @Lonk Interesting isn't it. Often I get "received wisdom" saying defaults are usually best - but in this case, you might be scaling your VPS to 32 cores and still only using 1 without knowing it if you didn't sanity-check those defaults.
        fbartelsF 1 Reply Last reply
          fbartelsF
          fbartelsF
          fbartels
          @marcusquinn don't forget the good old http://mysqltuner.pl/
          LonkleL 1 Reply Last reply
            About a decade ago, there was an idea for a project to do this app wide.
            As in have a profiler be able to tune any App (via config files and runtime params) it was aware of dynamically during various user loads.
            Initially meant for cluster Apps, but easily applies to single apps too.
            Feedback loops handle all the parameters automagically.
              LonkleL
              LonkleL
              Lonkle
              @robi said in MySQL tuning with my.cnf settings optimisation:
              Did anything come of it?
              • fbartelsF fbartels
                LonkleL
                LonkleL
                Lonkle
                @fbartels said in MySQL tuning with my.cnf settings optimisation:
                Never saw this before, when do we run / apply it? Anytime or only during installation?
                • LonkleL Lonkle
                  @lonk It was architected but not implemented. Life happened.
                  Still a good idea.
                    Further Reading
                    rmdesR
                    rmdesR
                    rmdes
                    @marcusquinn In the cloudron context, where does my.cnf goes to be taken into account ?
                    • LonkleL Lonkle
                      fbartelsF
                      fbartelsF
                      fbartels
                      @lonk said in MySQL tuning with my.cnf settings optimisation:
                      Mysql tuning is best applied after a few days of database usage. Applications usually have different load patterns.
                        LonkleL
                        LonkleL
                        Lonkle
                        Gotcha, thanks for the tip! ☺️
