Nextcloud can't connect to Collabora
@staypath said in Nextcloud can't connect to Collabora:
When the container pings the public IPv4 of the host, the host responds to the ICMP packet, but it is responding to the private IP of the container (172.18.0.x). The packet doesn't seem to know how to get back to the container from the host.
If you happen to have another server, can you test this with a normal ubuntu and docker installation ? i.e just create server, install docker. Then from a container try to ping public IP.
FWIW, this works out of the box in all the VPS servers.
I just tried installing Collabora and hit this exact same issue.
This issue is marked as solved, but I'm not sure why as it doesn't appear to be actually solved.
@jdaviescoates actually so far reinstallation of collabora and resetting the app in nextcloud mostly solved this. It is however quite unclear still why this happens.
@nebulon I note the setting says:
URL (and Port) of Collabora Online-server
I wonder if we need to specify a port too?
Although I think in my case perhaps it's just because I've already connected Netxtcloud to OnlyOffice! I'm not sure it's actually possible to use both alongside eachother.
@jdaviescoates said in Nextcloud can't connect to Collabora:
Nope, that's not it. I just tried it with a Nextcloud that doesn't have OnlyOffice set-up and that couldn't connect either.
Sounds like perhaps it is possible https://help.nextcloud.com/t/install-both-onlyoffice-and-collabora/76180/3
OK, so actually the solution was maddeningly simple
You mustn't put a trailing slash because then it's not a FQDN
You have to put
collabora.domain.coop
or
https://collabora.domain.coopNOT
collabora.domain.coop/
nor
https://collabora.domain.coop/Then it works fine!
(And it is possible to have both OnlyOffice and Collabora installs. My files still default to opening in OnlyOffice but I've now got an extra Edit with Collabora Online Development Edition option in the 3 little dots menu for files)
@nebulon I guess something about trailing slashes could be added to the docs?
You have to put
or
nor
@jdaviescoates Oh good catch. I much prefer fixing the app itself than docs which nobody reads
cc @nebulon -
